Best CPU cooler 2021: top CPU coolers for your PC
    As tempting as it may be to skip getting the best CPU cooler so you can spend more money on the sexier internals, you shouldn’t. The best graphics card, best processor, and best motherboard, after all, need a powerful CPU cooler to stay cool and keep working optimally. And, if you’re blowing all that cash on the PC components and getting a cheap cooler, you might burn your money.
    The best CPU cooler is an integral part of building a PC, whether it’s a gaming PC you’re after or just a budget one. Don’t worry; that doesn’t mean that you need to splurge and get the most expensive CPU cooler you can find. There are affordable options out there that can be just as effective in meeting your computer’s cooling needs and overclocking demands.
    In fact, that’s what we’re here for. We gathered the best CPU coolers 2021 has to offer to narrow your choices and help you find the best value. Keep it cool, no matter your need, with one of our picks below. And make sure to check out our price comparison tool to find the best deal before pressing that buy button.
    [HEADING=1]The best CPU cooler at a glance[/HEADING]
    [ol]
    [li]Noctua NH-D15[/li][li]Cooler Master Hyper 212 RGB Black Edition[/li][li]Noctua NH-L9[/li][li]NZXT Kraken Z-3[/li][li]Corsair iCUE H115i Elite Capellix[/li][li]Cooler Master MasterLiquid ML240P Mirage[/li][li]Cooler Master MasterLiquid ML120R RGB[/li][li]Arctic Liquid Freezer 120[/li][li]Corsair Hydro Series H5 SF[/li][li]NoFan CR-95C[/li][li]MasterLiquid ML360 Sub-Zero[/li][/ol]
    [IMG alt=“Noctua NH-D15”]https://cdn.mos.cms.futurecdn.net/74...UHHwRh42fL.jpg
    Image Credit: Noctua
    [HEADING=2]1. Noctua NH-D15[/HEADING]
    Best CPU cooler
    Type: Fan and heatsink | Compatibility: Intel LGA 775 – LGA 2066; AMD AM2 – AM3+, FM1 – FM2+ | Rotation frequency: Up to 1500 RPM | Noise volume: 19.20dbA – 24.60dbA | Dimensions (W x D x H): 160 x 150 x 135mm | Weight: 2.91 pounds (1.32kg)
    Whisper quiet
    Six-year manufacturer’s warranty
    Too big for some PC builds
    The Noctua NH-D15 is one of the best CPU coolers you can buy in 2019 simply because it performs just as well as – if not better – than some liquid coolers, while costing a fraction of the price. You might not be too familiar with Noctua’s name, as they’re relatively small in the CPU cooler world, but its business is revolves around designing coolers, so you know that when you buy one of their products, you’re getting a product by people who really know their craft. On top of delivering a fantastic cooling performance, the NH-D15 is nearly silent as well.
    [IMG alt=“Cooler Master Hyper 212 RGB Black Edition”]https://cdn.mos.cms.futurecdn.net/qx...HCCQ8fuMZK.jpg
    (Image credit: Cooler Master)
    [HEADING=2]2. Cooler Master Hyper 212 RGB Black Edition[/HEADING]
    Better than ever before
    Type: Fan and heatsink | Compatibility: Intel LGA 1150 – LGA 2066; AMD AM2 – AM4, FM1 – FM2+ | Rotation frequency: 650 - 2,000 RPM | Noise volume: 8 - 30 dBA | Dimensions (W x D x H): 120 x 79.6 x 158.8 mm | Weight: 1.54 pounds (700g)
    Improved performance
    Easy installation
    Quiet fan
    RGB lighting just ok
    Cooler Master’s Hyper 212 CPU RGB cooler is back with a vengeance, and sporting a sleek gun-metal black brushed aluminum finish to boot. It’s not only jet black look that’s upping this CPU cooler’s cool factor – though it does help what with that aluminum top cover and nickel plated jet black fins to complete the look. It’s also easily one of the best CPU coolers on the market with its stacked fin array that ensures least airflow resistance, four heat pipes that boast Direct Contact Technology to better battle the heat, and a wide speed range for fine-tuning cooling performance and silent operation.
    [IMG alt=“Noctua NH-L9”]https://cdn.mos.cms.futurecdn.net/KZ...yNMNQ9Z2fL.jpg
    [HEADING=2]3. Noctua NH-L9[/HEADING]
    Best low-profile CPU cooler
    Type: Fan and heatsink | Compatibility: Intel LGA 1156/1155/1151; AMD AM2/AM2+/AM3/FM1/FM2 | Rotation frequency: Up to 2500 RPM | Noise volume: 14.8dbA – 23.6dbA | Dimensions (W x D x H): 206 x 184 x 37mm | Weight: 1.03 pounds (0.47kg)
    Ultra compact
    Only 92mm fan
    Noctua is an Austrian manufacturer that does one thing, and one thing only: make the best CPU coolers and fans. What this means is that even though the Noctua NH-L9 is tiny, it is still more than capable of insane cooling with no compromises. This is a fantastic cooler for anyone with a smaller build, or even if you’re using a ton of large components, and you’re not comfortable with liquid cooling.
    [IMG alt=“NZXT Kraken Z-3”]https://cdn.mos.cms.futurecdn.net/2n...WRVnQndaWa.jpg
    (Image credit: NZXT)
    [HEADING=2]4. NZXT Kraken Z-3[/HEADING]
    Personalize your all-in-one liquid cooler
    Type: Fan and heatsink | Compatibility: Intel Socket LGA 1151 – 2066, Intel Core i9 / Core i3 – i7, AMD Socket AM4, TR4, AMD Ryzen 3 – Ryzen Threadripper | Rotation frequency: 500-1,800 + 300 RPM | Noise volume: 21-38dBA | Dimensions (W x D x H): 143 x 315 x 30mm
    Total customization
    Superior performance
    Premium price
    Whether you’re going for 360MM or 280MM, the NZXT Kraken Z-3 is an excellent choice if you’re looking for liquid cooling. First of all, thanks to its vibrant 2.36-inch LCD screen that’s capable of displaying 24-bit color, this liquid cooler allows total customization so you can fine-tune settings as well as display your favorite images and animated gifs. More importantly, it delivers impressive liquid cooling performance and is easy to install.
    [IMG alt=“Corsair iCUE H115i Elite Capellix”]https://cdn.mos.cms.futurecdn.net/wU...mrhqa5Qodd.jpg
    (Image credit: Corsair)
    [HEADING=2]5. Corsair iCUE H115i Elite Capellix[/HEADING]
    Brighter is better
    Type: Liquid cooling system | Compatibility: Intel 1200, 1150, 1151, 1155, 1156, 1366, 2011, 2066, AMD AM4, AM3, AM2, sTRX4, sTR4 | Rotation frequency: Up to 2,000 | Noise volume: 36dBA | Dimensions (W x D x H): 322 x 137 x 27mm
    Insane performance
    Brighter RGB lighting
    Only minor improvement over predecessor
    The Corsair iCUE H115i Elite Capellix continues Corsair’s tradition of outstanding liquid coolers. It couples excellent cooling, thanks to its split-flow copper cold plate and its low-noise centrifugal pump, with bright RGB lighting, due to the use of Capellix LEDs. And, the RGB lighting is, in true Corsair style, customizable through the company’s proprietary iCue software. If you want a powerful liquid cooling system that looks good too, the Corsair iCUE H115i Elite is a perfect choice.
    [IMG alt=“Cooler Master MasterLiquid ML240P Mirage”]https://cdn.mos.cms.futurecdn.net/Dt...cmJFHp8tL4.jpg
    [HEADING=2]6. Cooler Master MasterLiquid ML240P Mirage[/HEADING]
    Cool and hypnotic
    Type: Liquid cooling | Compatibility: Intel LGA 775 – LGA 2066; AMD AM2 – AM4, FM1 – FM2+ | Rotation frequency: up to 2000 ±10% RPM | Noise volume: 27dbA | Dimensions (W x D x H): 277 x 120 x 27 mm | Weight: 2.11 pounds (1,237g)
    Threadripper support
    Gorgeous RGB lighting
    Pricey
    With the Cooler Master MasterLiquid ML240P Mirage in your gaming rig, you won’t only end up playing for hours on end without worrying about thermal throttling or overheating. You might just an hour or so admiring your CPU, especially if you have one of those glass-window cases, as this CPU cooler is indeed hypnotically pretty. It’s mostly thanks to its transparent pump design that lets you see the impeller spinning while bathed in different RGB lighting, like a colorful spinning wheel at a funhouse. Performance-wise, it definitely deserves a spot in our best CPU coolers list, with its PPS+ glass fiber housing and nozzle that provides temperature and liquid resistance, EPDM rubber O-Ring that helps eliminate liquid emission, and a low-resistance radiator that increases flow rate, heat exchange efficiency and cooling performance.
    [IMG alt=“Cooler Master MasterLiquid ML120R RGB”]https://cdn.mos.cms.futurecdn.net/5e...XcivgL5J25.jpg
    Image Credit: Cooler Master
    [HEADING=2]7. Cooler Master MasterLiquid ML120R RGB[/HEADING]
    The best compact liquid cooler
    Type: Liquid cooling system | Compatibility: Intel LGA 775 – LGA 2066; AMD AM2 – AM4, FM1 – FM2+ | Rotation frequency: Up to 2000 RPM | Noise volume: 6dbA – 30dbA | Dimensions (W x D x H): 83.6 x 71.8 x 52.7mm
    Luminous RGB lighting
    Premium build
    A little expensive
    There isn’t a single component that can’t be improved through RGB, and Cooler Master is well aware – jumping on the RGB bandwagon with the MasterLIquid ML 120R RGB. What’s more, it integrates some of the first addressable LEDs seen on a liquid cooler. This all-in-one liquid cooling solution isn’t just about aesthetics – it features an oxidation free pump and an efficient radiator. This means that not only will it last longer – but it’ll keep your CPU cooler, and all without giving up too much case real estate, which is why it’s made our best CPU coolers list.
    [IMG alt=“Arctic Liquid Freezer 120”]https://cdn.mos.cms.futurecdn.net/iU...qV2z9zo7Cg.jpg
    Image Credit: Arctic
    [HEADING=2]8. Arctic Liquid Freezer 120[/HEADING]
    Best budget liquid-cooler
    Type: Liquid cooling system | Compatibility: Intel LGA 2011 – 2066; AMD AM2 – AM3+, FM1 – FM2 | Rotation frequency: Up to 1350 RPM | Noise volume: 22.5dBA | Dimensions (W x D x H): 120 x 120 x 25mm | Weight: 2.65 pounds (1.2kg)
    Strong performance
    Inexpensive
    Somewhat noisey
    Few features
    For less than 70 big ones in both US dollars and British sterling, the Arctic Liquid Freezer 120 is a deal you can’t pass up if you’re on the prowl for a liquid cooler that won’t break the bank. While it lacks the bells and whistles of pricier, more extravagant liquid coolers, like the NZXT Kraken, the Arctic Liquid cooler is enough to get you by, not to mention it’s still a massive step up from the classic fan and heatsink pairing. So, while you can’t expect RGB lighting or software – or even hardware-based fan control, the 120mm variant of the Arctic Liquid Freezer makes our best CPU coolers list as it will keep your system refrigerated at a (mostly) quiet volume.
    [li]This product is only available in the US and UK at the time of this writing. Australian readers: check out a fine alternative in the Corsair Hydro Series H5 SF [/li][/ul]
    [IMG alt=“Corsair Hydro Series H5 SF”]https://cdn.mos.cms.futurecdn.net/UJ...DZ9EskD5eL.jpg
    Image Credit: Corsair
    [HEADING=2]9. Corsair Hydro Series H5 SF[/HEADING]
    Best low-profile CPU liquid-cooler
    Type: Liquid cooling system | Compatibility: Intel LGA 115x; AMD FM2 – FM2+ | Rotation frequency: Up to 1,800 RPM | Noise volume: 36dBA – 42dBA | Dimensions (W x D x H): 167 x 57 x 84mm | Weight: 2 pounds (0.91kg)
    Guaranteed leak-free tubing
    Compact, all-in-one form factor
    Blower style cooler
    Even if your budget will allow you to really go all-out on a serious liquid cooling solutions, if you have a smaller PC case, you’ll likely not have enough space. That’s where something like the Corsair Hydro H5 SF comes into play. Even on the smallest PC cases, you’re able to use this CPU cooler to keep your CPU chilled, even if you have some beastly overclocks happening. Plus, because it’s a closed loop, you don’t even need to worry about maintenance. Set it up, and let it do its thing – you won’t be disappointed.
    [IMG alt=“NoFan CR-95C”]https://cdn.mos.cms.futurecdn.net/mS...2XKLtjtD2Y.jpg
    Image Credit: NoFan
    [HEADING=2]10. NoFan CR-95C[/HEADING]
    Best fanless CPU cooler
    Type: Passively cooled heatsink | Compatibility: Intel LGA 775 – 1156; AMD AM2 – AM3+; FM1 | Noise volume: 0dBA | Dimensions (W x H x D): 180 x 148 x 180mm | Weight: 1.6 pounds (0.73kg)
    You won’t hear a peep
    Works well with low-power CPUs
    Exorbitantly massive
    95W TDP limitation
    Rounding out our best CPU coolers list is the NoFan CR-95C. You’ve probably never heard of NoFan – unless you’re already neck deep into the rabbit hole that is silent PC assembly. The South Korean component company specializes in helping enthusiasts reach that 0dBA silent sweet spot. In doing so, of course, will severely limit your set-up in terms of power, with its CR-95C fanless solution being limited in compatibility to processors whose TDP fall below 95W. Still, the NoFan CR-95C is worth a shot if you want to build a low-power computer that completely blends into the background.
    [li] This Product is only available in the US at the time of this writing. UK and Australian readers: check out a fine alternative in the Noctua NH-L9 [/li][/ul]
    [IMG alt=“MasterLiquid ML360 Sub-Zero”]https://cdn.mos.cms.futurecdn.net/Le...CVHobPvDUN.jpg
    (Image credit: CoolerMaster)
    [HEADING=2]11. MasterLiquid ML360 Sub-Zero[/HEADING]
    Best CPU cooler for overclocking
    Type: Liquid cooler | Compatibility: LGA1200 | Noise volume: < 35 dBA pump, 8 - 26 dBA fan | Dimensions (W x H x D): 394 x 119.6 x 27.2 mm radiator, 57.3 x 57.3 x 92.2 mm pump, 120 x 120 x 25 mm fan
    For Intel’s high-TDP chips
    Has a condensation barrier
    Loud pump
    Powered by Intel’s Cryo Cooling Technology, the MasterLiquid ML360 Sub-Zero from Cooler Master allows increased performance for Intel’s high-TDP chips by letting them reach higher frequencies at lower voltages. This liquid cooler boasts a 360mm radiator and fans that are able to spin at low rpm while delivering a high air pressure to air flow ratio. Whether you’re a hardcore gamer who loves to overclock or a content creator with demanding processing needs, this is the best CPU cooler for you.
