Best mesh Wi-Fi routers 2020: the best wireless mesh routers for large homes
    Make network issues a thing of the past with the best mesh Wi-Fi routers 2020 has to offer. Thanks to their multi-node setup, these routers are designed to give you a much more reliable and robust signal to every corner of your space. So, if you’re dealing with spotty, unreliable connections or dead spots in your home or office, they’re your most cost-effective solution.
    Unlike typical wireless routers with just a single device providing coverage, the best mesh Wi-Fi routers can have several nodes that you can place around the area you want covered. These nodes take on the job of covering those areas the main router can’t reach, giving you a stable and uninterrupted connection throughout your space. That makes them ideal when you’re trying to cover a large space or a busy, multiple-device household as well.
    Chase your network blues away by investing in one of the best mesh Wi-Fi routers of 2020. Whether it’s the best value, the easiest to set up, or even the most aesthetically pleasing you’re looking for, one of our top picks might just be the answer to your problems.
    [li]We found the best Wi-Fi 6 routers on the market right now[/li][li]For the best Wi-Fi extenders, check out our top picks[/li][/ul]
    Best mesh Wi-Fi routers at a glance
    [ol]
    [li]Google Nest Wifi [/li][li]Google Wifi[/li][li]Netgear Orbi[/li][li]Netgear Orbi WiFi 6[/li][li]Netgear Orbi AC1200[/li][li]TP-Link Deco M5[/li][li]Ubiquiti Amplifi HD[/li][li]Linksys Velop[/li][/ol]
    [IMG alt=“Google Nest Wifi”]https://cdn.mos.cms.futurecdn.net/y2...3TuPCvGUom.jpg
    The Google Nest Wifi kicks things up a notch. (Image credit: Google)
    1. Google Nest Wifi
    Google Wifi and Home together at long last
    Speed: 802.11a/b/g/n/ac 2.4 GHz/5 GHz simultaneous dual-band | Connectivity: Dual Gigabit Ethernet ports | Features: Advanced security chip, Nest Wifi point with Google Assistant, privacy control
    Excellent design
    Smart speaker(s) included
    Even simpler controls
    No major performance gains
    Not worth replacing existing mesh
    What’s better than the best mesh router? Well, a mesh router with a smart speaker, that’s what. Especially if you’re a smart home fiend, you will appreciate the pure genius of this upgrade in Google’s Wifi line. The Google Nest Wifi kicks things up a notch, taking Google Wifi’s incredible yet simple design and performance then merges it with the convenience of a smart speaker so you’ve got a two-in-one device in an even sleeker and more attractive package. And, if you’re tired of the color white, this one also comes in Mist and Sand colors. As far as the best mesh Wi-Fi routers go, the original Google Wifi is still the one to beat. This one just gives it that extra oomph.
    Read the full review: Google Nest Wifi
    [IMG alt=“Google Wifi”]https://cdn.mos.cms.futurecdn.net/Cy...HKoED7FjUd.jpg
    With Google WiFi, Google has taken dominion over the mesh WiFi world. (Image credit: Google)
    2. Google Wifi
    The best Wi-Fi Mesh system from the future
    Speed: 802.11ac 5GHz down: 101.41 Mbps, 2.4GHz down: 47.53 Mbps | Connectivity: 2 x Gigabit Ethernet ports per Wifi point (1 WAN and 1 LAN port each) | Included mesh nodes: 1-3 | Features: AC1200 2 x 2 Wave 2 Wi-Fi, TX beamforming, Bluetooth Smart ready
    Simple set-up
    Inexpensive
    Limited hardware control
    The Google Wifi tops, possibly, the best wireless mesh routers we’ve ever used, and we’re not saying that casually. In fact, we’d even go so far as to say that it may be the best wireless mesh router, at least to date. Not only does it have the power to push fast Wi-Fi throughout your house – an even more impressive feat considering its diminutive size, but it’s also fairly cheap and not that hard to set up. Setting up is so simple that all you have to do to configure Google Wifi is to download an app to your smartphone, scan some QR codes and just place the nodes where you want around your house. With Google WiFi, the company has taken dominion over the mesh WiFi world.
    Read the full review: Google Wifi
    [IMG alt=“Netgear Orbi”]https://cdn.mos.cms.futurecdn.net/Zt...KoKU8o4dwS.jpg
    The Netgear Orbi boast more than enough Ethernet ports. (Image credit: Netgear)
    3. Netgear Orbi
    Expensive, but powerful
    Speed: 802.11ac 5GHz down: 90.14 Mbps, 2.4GHz down: 93.69 Mbps | Connectivity: 4 x 10/100/1000Mbps Gigabit Ethernet ports (1 WAN + 3 LAN for Router, 4 LAN for Satellite), 1 x USB 2.0 port | Included mesh nodes: 2-4 | Features: 4GB flash memory, 512MB RAM, AC3000, MU-MIMO ready
    Excellent performance
    Nice design
    Expensive
    If you have deep pockets, then check out the Netgear Orbi, which may be one of the best mesh Wi-Fi routers money can buy this year. Instead of something like the Google WiFi, which uses three identical nodes to create the network, you’ll get one main router and several satellite nodes to plug into power outlets around your home. In addition, the Orbi touts more than enough Ethernet ports, making it an exceptional option for anyone with a number of devices that need a hardwired connection. This mesh router is the best choice for consumers who use their network mostly for gaming, particularly across multiple devices.
    Read the full review: Netgear Orbi
    [IMG alt=“Netgear Orbi WiFi 6”]https://cdn.mos.cms.futurecdn.net/ee...nU4ELhVfKN.jpg
    The Orbi WiFi 6 is your best bet when it comes to getting the best mesh Wi-Fi routers. (Image credit: Netgear)
    4. Netgear Orbi WiFi 6
    Netgear brings Wi-Fi 6 to its Orbi mesh range
    Speed: WiFi 6 (IEEE 802.11ax) tri-band with 1x 2.4GHz (1200Mbps), 2x 5GHz (2400Mbps) | Connectivity: 2.5Gbps WAN, 4x Gigabit Ethernet; satellite - 4x Gigabit Ethernet | Features: Beamforming implicit and explicit for 2.4GHz/5GHz bands
    Excellent Wi-Fi range and speed
    Simple set-up, and easy-to-use app
    Seriously expensive
    Little support for Wi-Fi 6 right now
    If you’re ready to jump on the Wi-Fi 6 bandwagon, the Orbi WiFi 6 is your best bet when it comes to getting the best mesh Wi-Fi routers. It’s not by any means a casual purchase, with its steep price tag, but if you’re looking to upgrade to a faster and more reliable router to cover a massive space – like your countryside mansion, perhaps, or your crowded smart home – then this one’s absolutely worth the money. Plus, it’s easy and straightforward to setup, making it great for people who don’t have too much experience with Wi-Fi networks.
    Read the full review: Netgear Orbi WiFi 6
    [IMG alt=“Netgear Orbi Whole Home Mesh WiFi System”]https://cdn.mos.cms.futurecdn.net/AR...ZAUgJnqu9B.jpg
    The tri-band Orbi Whole Home AC1200 offers solid performance at a reasonable price. (Image credit: Netgear)
    5. Netgear Orbi Whole Home Mesh WiFi System
    Fast, affordable, tri-band mesh Wi-Fi
    Speed: IEEE 802.11ac dual-band with 1x 2.4GHz (400Mbps), 1x 5GHz (866Mbps) | Connectivity: 2 x Gigabit Ethernet | Features: Beamforming implicit and explicit for 2.4GHz/5GHz bands
    Affordable dual-band mesh Wi-Fi system
    Good performance
    Free parental controls are limited
    Only one Ethernet port for wired connections
    The tri-band Orbi Whole Home AC1200 offers solid performance at a reasonable price, and will be a good choice for most small and medium-size homes that need to improve their Wi-Fi coverage. It’s simple to set-up and use for newcomers, although Netgear’s decision to use Disney’s subscription-based Circle service for parental controls is discouraging, considering that rival routers and mesh systems have often provided better parental controls for free. The lack of Ethernet ports for wired connections as well as more advanced features in the Orbi app might turn off experienced users as well.
    [IMG alt=“TP-Link Deco M5”]https://cdn.mos.cms.futurecdn.net/qJ...iBYvqxZVGM.jpg
    The TP-Link Deco M5 is an affordable way to spread Wi-Fi throughout your home. (Image credit: TP-Link)
    6. TP-Link Deco M5
    The affordable Wi-Fi Mesh option
    Speed: 802.11ac 5GHz down: 76.69 Mbps | Connectivity: 2 x Gigabit ports per Deco M5 unit, 1 x USB Type-C port, Bluetooth 4.2 | Included mesh nodes: 1-3 | Features: Quad-core CPU, MU-MIMO ready, Router-based antivirus, Alexa compatibility
    Incredible value
    Easy to configure
    Slower than compeition
    If you’re looking for a way to spread Wi-Fi throughout your home without having to spend a lot of dough, then look into the TP-Link Deco M5. It’s not as speedy as some of the other best mesh Wi-Fi routers on this list, but if you’re not too concerned about getting the maximum theoretical throughput, which you probably won’t be able to take full advantage of anyway, this shouldn’t be too much of an issue. Setup, similar to the other devices here, is a breeze, even if you’re not tech-savvy. The TP-Link Deco M5 is among the best wireless mesh routers for those who don’t want to get too technical.
    Read the full review: TP-Link Deco M5
    [IMG alt=“Ubiquiti Amplifi HD”]https://cdn.mos.cms.futurecdn.net/mr...cnpy5F3yFA.jpg
    You’ll find a lot to love in the Ubiquiti Amplifi HD. (Image credit: Ubiquiti)
    7. Ubiquiti Amplifi HD
    Style backed by power
    Speed: 802.11AC 5GHz down: 74.1Mbps | Connectivity: 1 x Gigabit WAN, 4 x Gigabit LAN | Mesh nodes: 1 x router, 2 x nodes | Features: Modular network coverage, modern design, LCD touchscreen
    Modern aesthetic
    Extremely powerful
    Expensive
    If you love Apple’s design philosophy, enjoy having attractive gadgets set up around your home and have more than enough extra money sitting around, then the Ubiquiti Amplifi HD is the perfect mesh router for you. You’ll find a lot to love with this device, especially if you live in a large house and can take advantage of the full power that this mesh Wi-Fi setup provides, as it’s capable of a very large amount of throughput. You might find that the value diminishes quite a bit when you live in a smaller space however, since there are more affordable alternatives on hand for small to medium homes. The Ubiquiti Amplifi HD may be pricey, but you’re paying for a piece of tech that both exudes style and a ton of substance. That’s more than enough to justify the price tag, making this a great addition to the best wireless mesh routers list.
    Read the full review: Ubiquiti Amplifi HD
    [IMG alt=“Linksys Velop”]https://cdn.mos.cms.futurecdn.net/Ps...iY9rrW4CS4.jpg
    There’s something to be said about the simplicity that the Linksys Velop delivers. (Image credit: Linksys)
    8. Linksys Velop
    Paying for simplicity
    Speed: 802.11ac 5GHz down: 117.46Mbps | Connectivity: 2 x Gigabit Ethernet ports per unit (1 WAN and 1 LAN port each) | Included mesh nodes: 1-3 | Features: Guided setup, Modular, Easy parental controls, Auto-fix
    Simple r
    Simple setup
    Expensive
    While it’s expensive and not quite as powerful as the other Wi-Fi mesh routers on this list, there’s something to be said about the simplicity that the Linksys Velop offers. It might come with a heftier price than the competition, but the Velop will appeal to people who need to create a Wi-Fi network and want to avoid setting it up. More tech-savvy users will most likely look elsewhere – why spend money when you can do the work yourself for free? However, for most users, the Linksys Velop is among the best wireless mesh routers because of the convenience it offers from the start. It’s also completely modular, so you only have to pick up as many nodes as you actually need – one node will cover up to 2,000 square feet.
    Read the full review: Linksys Velop
    [li]These are the best routers of 2020[/li][/ul]
