DJI's next gadget launch could be a rugged remote control car
    • 54687
    Besides those drones that it keeps building, DJI has been keen to expand into other areas of hardware in recent years, and it looks as though a remote-controlled car could be next off the production line.
    That’s as per newly filed patents spotted by DroneDJ, detailing a rugged little buggy with an on-board camera – it’ll be just like shooting footage from a drone, except from the ground.
    According to the documents, the car will come with four wheels that rotate 360 degrees, giving the vehicle the ability to get over the most rugged terrain, and to turn around in tight spaces.
    [li]All you need to know about the Galaxy S11[/li][li]The Witcher has arrived on Netflix[/li][li]All you need to know about the Huawei P40[/li][/ul]
    Up on top is a camera that looks similar to the ones used in the Inspire drones. The car is also fitted with a variety of tech to minimize camera shake and to keep footage steady during movement.
    [IMG alt=“DJI patent”]http://cdn.mos.cms.futurecdn.net/Wdg...dRjnyFV5Q6.jpg
    It’s a move that would make sense for DJI, expanding its line of movie-making gadgets while potentially using the same cameras and batteries that it’s already making for use in its airborne drones.
    Serious filmmakers could deploy a roving remote control buggy and a drone together, enabling them to capture whatever was happening from a variety of different angles.
    Another patent uncovered at the same time hints that DJI is also busy preparing another dedicated gimbal device, one which could be used with a variety of other equipment (including a remote-controlled car) for super-stable footage.
    Of course, as with all of the patent applications that we feature, this is no guarantee that DJI will ever launch a product like this – but it does give a clear indication of what the company is thinking about developing.
    [li]These are our favorite drones of 2019[/li][/ul]
    Via SlashGear
