LG’s 38-inch monitor looks like it could be a dream screen for ultrawide fans
    LG has lifted the curtain on a bunch of monitors which it will show off at CES 2020, including a 38-inch ultrawide which has a seriously tempting spec.
    LG’s new 38-inch ultrawide has a curved screen with a resolution of 3,840 x 1,600, and it’s another big ‘Nano IPS’ monitor, meaning it gives you an IPS panel (with those vivid colors, and great viewing angles) along with a 1ms response time (normally IPS tech is much slower).
    [li]Alienware 55 OLED Gaming Monitor: How big is too big?[/li][li]These are the best ultrawide monitors for 2020[/li][li]And check out the 10 best gaming monitors of the year[/li][/ul]
    On top of that, you also get a 144Hz refresh rate, and the 38WN95C is officially Nvidia G-Sync compatible, so it’s easy to imagine how gamers who fancy a 21:9 panel might be salivating at this point. And ultrawide monitors are certainly proving more and more popular these days, for those who want a truly immersive and cinematic experience with the latest games.
    Furthermore, the LG 38WN95C also sports Thunderbolt 3 connectivity, and that IPS display is certified as covering 98% of the DCI P3 color space, meaning colors are highly realistic and true to life (plus on the HDR front, the display is also certified as VESA DisplayHDR 600).
    If you don’t want ultrawide, then LG has new UltraGear gaming monitors on offer, with a 27-inch model, 34-inch and 38-inch (pictured top). These are 4K screens, again with an IPS panel that has a 1ms response time, and a refresh rate of 144Hz; although in this case it can be overclocked to 160Hz.
    The main difference between these three models, aside from the size, is that the 34-inch will support VESA DisplayHDR 400, whereas the 27-inch and 38-inch are certified as VESA DisplayHDR 600.
    All these monitors are getting an upgraded stand, by the way, which LG says offers more stability than its previous design, not to mention it looks better (which never hurts). These screens support adaptive sync tech and are G-Sync compatible.
    [IMG alt=“LG UltraFine Ergo Display”]http://cdn.mos.cms.futurecdn.net/Sy3...4dkWBKmMr9.jpg
    Stands to reason
    Finally, the hardware manufacturer has something a little different in the form of the LG UltraFine Ergo Display, which as the name suggests, offers some ergonomic benefits – although considerably beyond what we normally see in the monitor world.
    This is a 32-inch 4K IPS monitor that’s on an arm attached to a stand which is essentially a cylinder that is clamped to your desk (see the image above). So the monitor effectively takes up no space, and using the flexible arm, it can be adjusted to all manner of different positions.
    In the workplace, this means you can even swivel it around to face in the opposite direction, to quickly show a colleague something on your screen, for instance.
    LG’s 32UN880 also promises excellent color reproduction and accuracy – it’s an UltraFine display after all – and the company notes that its ‘USB-C One Cable’ solution means you won’t have any clutter of leads, either. This is one minimalist monitor, that’s for sure.
    The full specs include a 4K resolution, as mentioned, a 5ms response time, 60Hz refresh rate, and it supports HDR10, as well as FreeSync.
    No pricing has been mentioned for any of these products yet, although we could hear more about the potential damage to your wallet – which may well be substantial in some cases here – at CES 2020.
    [li]CES 2020: Here’s what you can expect to see at the world’s biggest tech event[/li][/ul]
