Best smart light bulbs: the best smart lights from Philips Hue to Hive
    Smart lighting is one area of the smart home that just about anyone can tackle. It requires little explanation, installation, and fiddling, and before you know it, you’re enjoying the lovely hues of your new smart bulbs, controlling them with just your phone or your voice.
    Smart lighting is great because of the options you have at your disposal: You can control them with just your phone or your voice. You can change tone, brightness and even color. There’s so many options with smart lights, you may wonder what took you so long to make the switch.
    Even if you don’t pay a ton of attention to smart lighting, you have likely heard of Philips Hue. It’s definitely the biggest name in the smart lighting game, but that doesn’t mean it’s the only horse in the race – far from it.
    There are some truly excellent offerings from companies such as Lifx if you’re looking for more of a talking-point; Hive if you’re on a budget; or Nanoleaf if you’d rather your lighting be part of your home’s decor.
    Each system comes with its own pros and cons, so here we’ll talk you through the brands you should be aware of, plus which smart lighting solution will be the best fit for you and your home.
    Best smart light bulbs at a glance:
    [ol]
    [li]Philips Hue Color Ambience[/li][li]LIFX A19[/li][li]Nanoleaf Light Panels[/li][li]Hive Active Light[/li][li]Sengled Element Classic Starter Kit[/li][li]LIFX Mini Color[/li][li]IKEA Tradfri[/li][li]Eufy Lumos[/li][/ol]
    [IMG alt="eaV3kfiKqe8HZw8guGnRxS" width="420px" height="1px"]https://cdn.mos.cms.futurecdn.net/eaV3kfiKqe8HZw8guGnRxS.jpg[/IMG]
    [IMG alt="7NgatBatcARKf9cPMU5iUR" width="500px" height="500px"]https://cdn.mos.cms.futurecdn.net/7NgatBatcARKf9cPMU5iUR.jpg[/IMG]
    Image Credit: Philips Hue
    There’s a very good reason why Philips Hue is the biggest name in the smart lighting scene: it’s without a doubt one of the greatest offerings to the market. The lights produce the most natural tones of any smart lighting we’ve used, the app is easy to use, and installation is a doddle.
    That said, you can’t use the Hue lights without the hub, meaning the only way to get started is with a starter kit that’s going to set you back considerably more than just a light bulb would.
    It’s also worth noting that there are a variety of different lighting kits and bulbs available in the Hue range, so you’ve got the choice of White (which just does white light), Color (which offers over 16 million colors), and Ambient variants of both (which gives you the option of dimmer, softer tones).
    They all work from the same hub, so you don’t need a new hub for each lighting set, but it’s worth doing your research and really thinking about what you need before you invest.
    [li]Read the full review: Philips Hue[/li][/ul]
    [IMG alt="6b99wQE7YmZpnmoGDtnDWd" width="690px" height="388px"]https://cdn.mos.cms.futurecdn.net/6b99wQE7YmZpnmoGDtnDWd.jpg[/IMG]
    Image Credit: LIFX
    Lifx is an interesting proposition in the smart lighting market. It doesn’t try to replicate the standard warm glow of a filament bulb, instead focusing on bright and vibrant colors.
    If you’re looking for a feature light, something that’s going to bathe your room in a warm red or deep purple glow, this is the one for you. With a fun color wheel and brightness settings that go from 1-100%, the customization options are so varied that they can get overwhelming at times.
    But this is no gimmick light. While turning it on for the first time may give you a bit of a shock, the light it emits is actually very warm, and a real pleasure to sit in.
    Like Hue, there are a number of options with Lifx bulbs, including a ‘+’ version of its bulbs, which include a night mode that enhances the night vision of indoor security cameras by emitting a low-frequency light.
    [li]Read the full review: Lifx[/li][/ul]
    [IMG alt="4DuW75HBtkMtbyK2Wq7jCb" width="690px" height="388px"]https://cdn.mos.cms.futurecdn.net/4DuW75HBtkMtbyK2Wq7jCb.jpg[/IMG]
    Image Credit: Nanoleaf
    You like light but hate light bulbs. We get you. They’re so bulb-y. So maybe Nanoleaf is going to be more up your street.
    The Nanoleaf Light Panels (formerly known as Aurora) take the concept of lighting and turn it base-over-apex. Using a collection triangular panels, you create a dynamic shape on your wall (or ceiling, or both) that can shift through over 16 million different colors.
    What’s more, with the separate Rhythm Module, the Nanoleaf can even respond to audio cues from the room it’s in, so it can respond to music, putting you in the centre of your own music video.
    If you’d rather decide what the light panels are going to do in advance, you can choose from a vast repository of user-created scenes that run through different aesthetically-pleasing configurations.
    The original set comes with nine panels, but you have the option to add more, and there are even corner clips to enable you to create configurations that bend around corners, creeping around walls and even onto your ceiling if you so wish.
    [li]Read the full review: Nanoleaf Light Panels[/li][/ul]
    [IMG alt="Dqmzjf9PzpuQRtsgcdX3XV" width="690px" height="388px"]https://cdn.mos.cms.futurecdn.net/Dqmzjf9PzpuQRtsgcdX3XV.jpg[/IMG]
    Image Credit: Hive
    Unlike the other lights in this roundup, the Hive Active Light is one that we recommend specifically if you’re already in the Hive ecosystem. If you’re the proud owner of a Hive Thermostat, plug, motion sensor, or Hive View camera, you’ll know that all Hive devices can all be controlled from a single app, streamlining the smart home control process.
    Because all the devices in the Hive ecosystem need a hub to work (you can either get a basic hub or the Hub 360, which doubles as a security system and is much prettier), you won’t need a separate hub for your lighting.
    An added bonus is that Hive recently announced that Philips’ Hue bulbs can be integrated into the Hive ecosystem, so if you’ve got this far down the list but are still thinking about the Hue range, you can go back and buy them now.
    Like the other ranges Hive has a variety bulbs, with some that change color and some that just do white. The light from them is very pleasant, although the bulbs do ‘pulse’ slightly if you turn them on using a light switch, so you need to leave the switch in the ‘on’ position and turn the lights on and off using the app.
    [li]Read the full review: Hive Active Light[/li][/ul]
    [IMG alt="HMw7B95Jvz4EQZEAyY6Aoj" width="690px" height="388px"]https://cdn.mos.cms.futurecdn.net/HMw7B95Jvz4EQZEAyY6Aoj.jpg[/IMG]
    Image Credit: Sengled
    If you’re looking for the cheapest way into smart lights, you should look at the Sengled Element Classic series of light bulbs. These bulbs should set you back less than $20/£20 once you’ve bought the kit and while they’re only available in a basic white color, they’re everything you need to get started in the world of smart lights and include compatibility with most of the major smart home systems - Amazon Alexa and Echo Plus, Google Assistant, and IFTTT included.
    That being said, the Sengled lightbulbs are a bit cheap and the app itself isn’t the most user-friendly or robust we’ve ever come across. There’s a major disparity between the Philips Hue and LIFX bulbs and Sengled’s – but, at a tenth of the cost, this is one of the best basic bulbs money can buy.
    [IMG alt="MfUw4ubb7BJWSofTNpZF2K" width="690px" height="388px"]https://cdn.mos.cms.futurecdn.net/MfUw4ubb7BJWSofTNpZF2K.png[/IMG]
    Image Credit: LIFX
    While we’re on the subject of cheap, versatile smart lights, we’d be remiss if we didn’t mention the LIFX Mini. It’s the smallest member of the LIFX family, but also the most affordable jumping off point for fresh smart home owners.
    What separates the mini from the full-size fixtures is, most obviously, the size of the bulb and how much light it’s able to put off. Still, if you’re not looking to light up a massive living room and are putting them in, say, your bathroom, these should work.
    Each bulb can output 16 million colors – choosable from a scroll wheel inside the LIFX app– or, if you want to control your lights hands-free, the Mini supports Amazon Alexa, Apple HomeKit, Google Assistant and IFTTT.
    The LIFX is well-rounded, relatively good for the price and, well, cheap.
    [IMG alt="L2FgYwfnFeP5ffSS6Eerf6" width="690px" height="388px"]https://cdn.mos.cms.futurecdn.net/L2FgYwfnFeP5ffSS6Eerf6.jpg[/IMG]
    Image Credit: IKEA
    IKEA has dipped its toe into the smart home market with the Tradfri range of smart bulbs. Sure they might not be packed with as many features and colours as leading brands, like Philips and LIFX, but they provide a simple, easy-to-use system that’ll integrate well into IKEA furniture.
    You can get both white and color options and they fit into E14 and E27 fittings. There are also panel lights and spotlights in the range too and you can select the ones that fit directly into IKEA cupboards, sideboards and other panels.
    We like this range because it’s affordable, simple and easy-to-use. To take advantage of some of the more advanced features, you will need to sync up the bulb to a separate device so it can access your router, but there are lots of options available, including Alexa support.
    Image Credit: Eufy
    Eufy (owned by Anker) is really making a name for itself as a robovac brand, producing some of the best iRobot competitors. But it’s also trying its hand at smart bulbs too.
    It may be early days for Eufy’s smart bulb offering – there’s currently only one bulb to choose from – but it’s still a simple-to-use and solid offering. This is especially the case if you’re not sure about smart home tech and want an easy, affordable option to give it a go.
    [li]Now you’ve got your lighting all sorted, check out our guide to the best security camera: keep an eye on your home from your smartphone[/li][/ul]
