This is the cheapest 50-inch 4K monitor around, and it costs less than $200
    • 54687
    4K displays are enjoying a surge in popularity, coupled with low prices, but the Sceptre U515CV-U breaks new ground with a sale price of $199.99 at Walmart, down from $399.99.
    This is a 50-inch behemoth and by our calculation the one with the cheapest per-inch price we’ve seen. Don’t expect the sort of color reproduction and fidelity or smart features of more expensive models; as there is no HDR here.
    Need an affordable large format display? A single screen to replace existing full HD ones on a financial trading desk? Or even a visual display unit for a small business CCTV setup - all you need to know is that this is a bargain basement, cheap-as-chips TV that can seamlessly transform into a monitor.
    [li]Here are the cheapest 4K monitor in the UK[/li][li]These are the best business monitors[/li][li]Check out the best 5K and 8K monitors right now[/li][/ul]
    Cut-price
    Given the price, you won’t be surprised to see that this is a LED-based television with only three HDMI connections, one of which supports HDMI 2.0 for 4K resolution at 60Hz. It does support MHL connectivity plus has component/composite ports, a 3.5mm audio connector, an optical out and a USB port.
    Its two speakers deliver 10W each and Sceptre claims that this 4K display has a dynamic contrast ratio of 15,000:1. Oh and let’s not forget the VESA mount at the back which will allow you to fix it on a wall.
    For those not familiar with the brand, California-based Sceptre is one of the biggest TV sellers in the US, ahead of the likes of Vizio and TCL.
    [li]Best business monitors of 2020: top displays for work[/li][/ul]
