Is Nikon about to unveil an APS-C mirrorless camera?
    • 54594
    Nikon’s full-frame mirrorless models, the Z7 and the Z6, have proved popular since their launch last year, and now rumors suggest the company could be planning to unveil a mirrorless APS-C model.
    NikonRumors claims the new model will be called the Z50, and will be supported at launch by a pair of new APS-C format (DX in Nikon terminology) lenses.
    The site says the camera will have a 20MP sensor, an articulating three-inch screen and an electronic viewfinder, and will offer 11fps shooting. The lenses that are rumored to be launching with it are a 16-55mm f/3.5-6.3 kit-type lens and a 50-230mm f/4.5-6.3 telephoto zoom lens.
    [li]These are the best mirrorless cameras for every budget[/li][li]Mirrorless vs DSLR – the key differences explained[/li][li]10 things to look for on your next mirrorless camera[/li][/ul]
    Mount options
    These aren’t the first rumors of Nikon launching a lower-cost or entry-level mirrorless camera, and it would make a lot of sense for Nikon to enter the mirrorless APS-C market, which until now it’s left to rivals Sony and Canon.
    If it does launch an APS-C model, it’ll be interesting to see whether Nikon uses the same mount across all its models, as Sony does, or splits them into distinct APS-C and full-frame categories with separate lenses, as Canon does.
    With relatively few specs to go on it’s not immediately obvious who a camera like the Z50 would be aimed at, but it’s likely to go head to head with the likes of the Sony A6600, or perhaps the Sony A6100 if Nikon is aiming for the entry-level market.
    September and October tend to be busy months for new launches as manufacturers look to cash in on the lucrative Christmas market, so watch this space.
    [li]These are the 12 best budget DSLRs, compacts and mirrorless cameras[/li][/ul]
