Leaked Sony sensor could open way for 100MP full-frame cameras with 6K video
    • 54687
    100 megapixel sensors aren’t new to the world of photography. A Sony-made 100MP back-illuminated (BSI) sensor is already being used in the Phase One iXM photography drone and the Phase One XF camera, but they’re both medium format. In September 2018, Fujifilm unveiled a 100MP body but that, too, would house a medium-format sensor.
    Currently, Canon is the only camera manufacturer rumored to be working on a full-frame 100MP sensor for its EOS R mirrorless camera. However, if a leaked product information document (first reported by AndroidLad on the EOSHD forum) holds true, then Sony could well be the first to release a 35mm full-frame 100MP sensor with 6K video recording capabilities.
    [li]Sensor sizes explained: from four-thirds to full frame[/li][li]Everything you need to know about SD cards[/li][li]192MP smartphone cameras could be coming[/li][/ul]
    Has the hi-res future arrived?
    “This sensor is designed for use in consumer use digital still camera. When using this for another application, Sony Semiconductor Solutions Corporation does not guarantee the quality and reliability of this product. Therefore, don’t use this for applications other than consumer use digital still camera.”
    According to the document, still images from the sensor would have a resolution of 12288 x 8192 (that’s a 12K equivalent in video), with a high-speed digital readout of 16-bit photos. The sensor would also offer 6K video recording in 12-bit using a pixel binning mode.
    It seems that Sony will make this sensor available to other manufacturers for use in consumer cameras.
    https://www.eoshd.com/2019/03/sony-develops-full-frame-100-megapixel-sensor-with-6k-video-for-consumer-cameras/’]
    Image: Androidlad (via EOSHD)
    To achieve the high-speed 16-bit readout, Sony seems to be using several analog-to-digital (ADC or A/D) converters, which could ensure that the sensor has better performance than the current Sony Alpha A7 III in terms of dynamic range and sensitivity.
    Storage woes
    RAW files from a camera using this 100MP sensor would be large, meaning a camera’s buffer and the speed of the card used would matter. However, with SD cards and microSD cards getting faster and now available in 1TB flavours, we’re hoping short-term storage won’t be an issue in the future, although it could prove expensive.
    That said, Nikon has already paved the way for the use of XQD cards in its high-end cameras, like the Nikon D850 and the Nikon Z series. But there’s currently limited support for PCI Express data transfer and XQD cards remain a pricey option with limited manufacturers. If consumer cameras go the hi-res way, though, we could see more competition that leads to a price drop.
    [li]Best full-frame camera 2019: 10 advanced DSLRs and mirrorless cameras[/li][/ul]
