Unreal Engine adopts ray tracing in major boost to Nvidia’s RTX graphics cards
    GeForce RTX graphics card owners have undoubtedly noticed the scarce level of support for ray tracing, but a lot more games could soon benefit from the tech with the news that the Unreal Engine has just adopted it.
    To be precise, the latest preview of Unreal Engine 4 (version 4.22) now incorporates ray tracing.
    The release notes state that a low-level layer has been implemented on top of UE DirectX 12 which “provides support for DXR and allows creating and using ray tracing shaders (ray generation shaders, hit shaders, etc) to add ray tracing effects”.
    [li]Nvidia GeForce RTX 2080: should you upgrade?[/li][li]Here’s how Nvidia is making Battlefield V a lot better on PC[/li][li]These are the best gaming monitors around[/li][/ul]
    A plethora of high-level ray tracing features are listed as supported including reflections, reflected shadows, soft shadows, ambient occlusion, real-time global illumination, translucency, and more. For the full list, check the notes here.
    Unreal support
    With support built into the Unreal Engine, developers using the tech for their games can make use of ray tracing, so the hope is that we shall see a vastly expanded catalogue of titles which play nice with Nvidia’s RTX cards in this respect.
    Games which support ray tracing are currently thin on the ground, although EA has introduced it to Battlefield V – along with DLSS, which promises massive frame rate boosts – plus Metro Exodus has also got support for both these technologies in the latest GeForce drivers from Nvidia (418.91). Metro Exodus is out tomorrow, although we’ve already reviewed it here (sadly, it’s not all good news).
    However, there are notable absences from the initial promised line-up back at the launch of Nvidia’s RTX cards, such as Shadow of the Tomb Raider, which still doesn’t benefit from ray tracing (or DLSS, which it’s also supposed to be getting).
    [li]These are the best graphics cards you can buy in 2019[/li][/ul]
    Via Wccftech
