Please help - machine has slowed to a snails pace
  • Malnutrition
    PCHF Moderator
    • 7041
    #16
    Remove Edge if you do not use it with Geek Uninstaller.
    O&O Shutup Ten
    Move it to your documents folder.
    Right click run as admin.
    Go to actions, apply all settings.
    Create the restore point when prompted.
    Follow thru the prompts, and reboot if needed to apply the settings.
    Download Tweaky:
    Unzip to your desktop.
    [COLOR=rgb(243, 121, 52)]Under Misc:
    [li]Disable Telemtry & Data Collection[/li][/ul]
    [COLOR=rgb(243, 121, 52)]Under Functionality:
    [li]Disable Cortana[/li][li]Uninsall One Drive[/li][li]Disable Driver Updates[/li][li]Disable P2P Delivery optimization.[/li][/ul]
    Then Click Apply Tweaks.
    [HEADING=2]New FRST Fix is attached below, please run it as before. [/HEADING]
    [HEADING=2]Attach the new fixlog and let me know how the machine is running now.[/HEADING][/COLOR][/COLOR]
    • khval94
      • Jul 2021
      • 63
      #17
      There we go. Now it’s cruising along. Thank you so much Mal!
      How would you reccommend maintaining this from here?
      • Malnutrition
        PCHF Moderator
        • 7041
        #18
        I believe that it was windows updates that was reverting some of the settings we changed, now that you have followed the instructions you should only be getting security patches from updates. None of the others are really needed unless you run into a specific issue where a program will not run without a certain update. So long as security updates are installed regular, which they will be; you will be fine with just this setting!
        Let’s make one final check to ensure that your programs are updated.
        Security Check Scan.
        Download Security Check to your desktop.
        [li]Right click it run as administrator.[/li][li]When the program completes, the tool will automatically open a log file.[/li][li]Please Copy and paste that log here in your next post.[/li][li]There will be items listed in red when you post this log, those items need to be updated.[/li][/ul]
        Copy and paste this log for me.
        Also, you can run this tool to ensure that the only thing that connects to the internet is what you allow.
        Simple Wall download.
        Once installed:
        Go to Block List
        Ms Spying and Telemetry Block it.
        • khval94
          • Jul 2021
          • 63
          #19
          “URL was not found”
          • Malnutrition
            PCHF Moderator
            • 7041
            #20
            Link fixed.
            • khval94
              • Jul 2021
              • 63
              #21
              SecurityCheck by glax24 & Severnyj v.1.4.0.58 [15.08.24]
              WebSite: www.safezone.cc
              DateLog: 20.11.2024 15:01:37
              Path starting: C:\Users\khval\AppData\Local\Temp\SecurityCheck\Se curityCheck.exe
              Log directory: C:\SecurityCheck
              IsAdmin: True
              User: khval
              VersionXML: 12.86is-20.11.2024
              Windows 11 Core (x64) Release: 23H2 (10.0.22631.4460) Lang: English(0409)
              Installation date OS: 08.06.2023 16:28:00
              LicenseStatus: Windows(R), Core edition The machine is permanently activated.
              LicenseStatus: Office 19, Office19HomeStudent2019R_Retail edition The machine is permanently activated.
              Boot Mode: Normal
              Default Browser: C:\Program Files\BraveSoftware\Brave-Browser\Application\brave.exe
              SystemDrive: C: FS: [NTFS] Capacity: [930.3 Gb] Used: [125.5 Gb] Free: [804.8 Gb]
              ------------------------------- [ Windows ] -------------------------------
              User Account Control enabled (Level 4)
              Never check for updates
              Security Center (wscsvc) - The service is running
              Remote Registry (RemoteRegistry) - The service has stopped
              SSDP Discovery (SSDPSRV) - The service is running
              Remote Desktop Services (TermService) - The service has stopped
              Windows Remote Management (WS-Management) (WinRM) - The service has stopped
              ---------------------------- [ Antivirus_WMI ] ----------------------------
              Windows Defender (enabled and up to date)
              --------------------------- [ FirewallWindows ] ---------------------------
              Windows Defender Firewall (mpssvc) - The service is running
              --------------------------- [ AntiSpyware_WMI ] ---------------------------
              Windows Defender (disabled and up to date)
              ---------------------- [ AntiVirusFirewallInstall ] -----------------------
              simplewall v.3.8.4
              --------------------------- [ OtherUtilities ] ----------------------------
              Microsoft Edge WebView2 Runtime v.130.0.2849.80 Warning! Download Update
              Uninstall old version and install new one.
              Microsoft Visual C++ 2015-2022 Redistributable (x86) - 14.40.33810 v.14.40.33810.0 Warning! Download Update
              Microsoft Visual C++ 2015-2022 Redistributable (x64) - 14.40.33810 v.14.40.33810.0 Warning! Download Update
              ------------------------------- [ Backup ] --------------------------------
              Microsoft OneDrive v.22.045.0227.0004 Warning! Download Update
              -------------------------- [ IMAndCollaborate ] ---------------------------
              Zoom Workplace v.6.1.12 (46889) Warning! Download Update
              Telegram Desktop v.5.1.7 Warning! Download Update
              -------------------------------- [ Media ] --------------------------------
              Audacity 3.6.1 v.3.6.1 Warning! Download Update
              VLC media player v.3.0.8 Warning! Download Update
              --------------------------- [ AdobeProduction ] ---------------------------
              Adobe Acrobat (64-bit) v.24.004.20272
              ------------------------------- [ Browser ] -------------------------------
              Mozilla Firefox (x64 en-US) v.129.0.1 Warning! Download Update
              Brave v.131.1.73.91
              ------------------ [ AntivirusFirewallProcessServices ] -------------------
              C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24090.11-0\MsMpEng.exe v.4.18.24090.11
              C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24090.11-0\NisSrv.exe v.4.18.24090.11
              Microsoft Defender Antivirus Service (WinDefend) - The service is running
              Microsoft Defender Antivirus Network Inspection Service (WdNisSvc) - The service is running
              ---------------------------- [ UnwantedApps ] -----------------------------
              Google Video Support Plugin v.19.12.1000.0 Warning! Suspected Adware! If this program is not familiar to you it is recommended to uninstall it and execute PC scanning using Malwarebytes Anti-Malware and Malwarebytes AdwCleaner. Before uninstallation and scanning it is necessary to consult in the forum where cure is provided for you!!!
              System Ninja version 4.0.1 v.4.0.1 Warning! Suspected demo version of anti-spyware, driver updater or optimizer. If this program is not familiar to you it is recommended to uninstall it and execute PC scanning using Malwarebytes Anti-Malware. Possible you became a victim of fraud or social engineering. Computer experts no longer recommend this program.
              ----------------------------- [ End of Log ] ------------------------------
              • Malnutrition
                PCHF Moderator
                • 7041
                #22
                Update if possible:
                Download KpRM
                Save to Desktop
                Check Delete Tools’
                Check Delete Restore points.
                Create Restore point.
                Click delete quarantines.
                Then click run.
                I’ll mark solved so long as you are ok with that.
                • khval94
                  • Jul 2021
                  • 63
                  #23
                  Absolutely. You’re the best Mal! I truly appreciate you and this community.
                  I’d love to make a donation but i’d prefer to use crypto - does PCHF have a bitcoin/crypto wallet I can send some coins to?
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #24
                    I am not sure about that. I’ll have to ask jmarket I will close this thread as solved.
                    Tell a friend or two about us.
                    I’ll send you a PM if the forum accepts Bitcoin.
                    • jmarket
                      PCHF Owner
                      • 7697
                      • CachyOS
                      • Intel Arc A770 (16 GB)
                      #25
                      Hello,
                      I will send you a DM
