Couple of PC issues...PC running slow and PC will not restart
  • Ginger-Overlord
    • Jul 2024
    • 61
    Hi,
    Using my PC today and it suddenly started running very slowly. It was very lethargic and programs would take a few seconds to start and webpages would continually load. I rebooted the PC and things were fine for a short while before they began to slow down again. I had a look at the Task Manager and there is a ‘antimalware service executable’ that appears to be taking up a lot of memory, but I am unable to stop it. Also, I am unable to reset my PC, when I select ‘restart’ my PC just shuts down. I’m concerned that changes I made to my PC settings to stop ‘antimalware service executable’ from running in the background are not working as my PC will not reset.
    Any ideas?
    Anyones help is greatly appriciated.
    Cheers,
    Ginger-Overlord
  • Ginger-Overlord
    • Jul 2024
    • 61
    Hi,
    It appears now that my PC will only remain on for about 5mins before shutting down!
    Thanks,
    Ginger-Overlord
      Restart your PC into Safe Mode or Clean Boot.
      We have a Resource on this topic here; https://pchelpforum.net/r/clean-boot...safe-mode.227/
      Click on the History tab to get the Download link.
      Booting that way should stop the auto 5mins shutdown and give you time to make changes.
      • Ginger-Overlord
        • Jul 2024
        • 61
        Hi,
        Thanks for your reply.
        Weird. I started my PC today and everything is…back to normal. I still have my doubts about it as it was acting very suspiciously yesterday.
        Anyway, the PC has been on for about 15mins now so I have ran a report from the MiniToolBox (below)
        Here are my PC specs
        Please advise if there is anything else I could run a report for that may help you
        Thanks for your continued help.
        [ATTACH type=“full” alt=“pc.PNG”]13961[/ATTACH]
        [spoiler]MiniToolBox by Farbar Version: 13-05-2022
        Ran by chredge (administrator) on 16-07-2024 at 07:10:27
        Running from “C:\Users\chredge\Desktop”
        Model: MS-7758 Manufacturer: MSI
        Boot Mode: Normal
        Windows IP Configuration
        Proxy is not enabled.
        No Proxy Server is set.
        “Reset IE Proxy Settings”: IE Proxy Settings were reset.
        “Reset FF Proxy Settings”: Firefox Proxy settings were reset.
        127.0.0.1 platform.wondershare.com0.0.0.0 incoming.telemetry.mozilla.org
        Realtek PCIe GbE Family Controller = Ethernet 6 (Connected)
        [HEADING=1]----------------------------------[/HEADING]
        [HEADING=1]IPv4 Configuration[/HEADING]
        pushd interface ipv4
        reset
        set global defaultcurhoplimit=64 dhcpmediasense=enabled
        set interface interface=“Local Area Connection* 1” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Local Area Connection 2” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Local Area Connection” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Ethernet” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Ethernet 2” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Ethernet 3” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Ethernet 4” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Ethernet 5” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set interface interface=“Ethernet 6” forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
        set subinterface interface=?ó??? subinterface=ethernet_32769 mtu=1404
        popd
        [HEADING=1]End of IPv4 configuration[/HEADING]
        [HEADING=1]Windows IP Configuration
        Host Name . . . . . . . . . . . . : MysteryMachine
        Ethernet adapter Ethernet 6:
        Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller #5
        Physical Address. . . . . . . . . : D4-3D-7E-02-49-07
        Link-local IPv6 Address . . . . . : fe80::5d85:1b3d:fa4e:8702%21(Preferred)
        IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
        Lease Obtained. . . . . . . . . . : Tuesday, 16 July, 2024 6:56:55 AM
        Lease Expires . . . . . . . . . . : Wednesday, 17 July, 2024 6:56:54 AM
        DHCPv6 IAID . . . . . . . . . . . : 383008126
        DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-69-1B-8E-D4-3D-7E-02-49-07
        DNS Servers . . . . . . . . . . . : 194.168.4.100
        194.168.8.100
        Server: cache1.service.virginmedia.net
        Address: 194.168.4.100
        Addresses: 2a00:1450:4009:821::200e
        172.217.16.238
        Pinging google.com [172.217.16.238] with 32 bytes of data:
        Reply from 172.217.16.238: bytes=32 time=21ms TTL=116
        Ping statistics for 172.217.16.238:
        Minimum = 21ms, Maximum = 21ms, Average = 21ms
        Addresses: 2001:4998:44:3507::8000
        2001:4998:44:3507::8001
        2001:4998:124:1507::f001
        2001:4998:124:1507::f000
        2001:4998:24:120d::1:0
        2001:4998:24:120d::1:1
        74.6.143.25
        98.137.11.163
        74.6.143.26
        74.6.231.21
        74.6.231.20
        98.137.11.164
        Pinging yahoo.com [74.6.231.20] with 32 bytes of data:
        Reply from 74.6.231.20: bytes=32 time=129ms TTL=48
        Reply from 74.6.231.20: bytes=32 time=130ms TTL=48
        Ping statistics for 74.6.231.20:
        Minimum = 129ms, Maximum = 130ms, Average = 129ms
        Reply from 127.0.0.1: bytes=32 time<1ms TTL=64
        Minimum = 0ms, Maximum = 0ms, Average = 0ms[/HEADING]
        [HEADING=1]Interface List
        21…d4 3d 7e 02 49 07 …Realtek PCIe GbE Family Controller #5
        1…Software Loopback Interface 1[/HEADING]
        [HEADING=1]IPv4 Route Table[/HEADING]
        [HEADING=1]Active Routes:
        0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.10 25
        192.168.0.0 255.255.255.0 On-link 192.168.0.10 281
        192.168.0.10 255.255.255.255 On-link 192.168.0.10 281
        192.168.0.255 255.255.255.255 On-link 192.168.0.10 281
        224.0.0.0 240.0.0.0 On-link 192.168.0.10 281
        255.255.255.255 255.255.255.255 On-link 192.168.0.10 281[/HEADING]
        [HEADING=1]Persistent Routes:
        None
        IPv6 Route Table[/HEADING]
        1 331 ::1/128 On-link
        21 281 fe80::/64 On-link
        21 281 fe80::5d85:1b3d:fa4e:8702/128
        On-link
        1 331 ff00::/8 On-link
        21 281 ff00::/8 On-link[/HEADING]
        None
        Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
        Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
        Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
        Catalog5 04 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
        Catalog5 05 C:\WINDOWS\SysWOW64\NLAapi.dll [71168] (Microsoft Corporation)
        Catalog5 06 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog5 07 C:\WINDOWS\SysWOW64\winrnr.dll [34304] (Microsoft Corporation)
        Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [325608] (Microsoft Corporation)
        x64-Catalog5 01 C:\Windows\System32\napinsp.dll [70144] (Microsoft Corporation)
        x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
        x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
        x64-Catalog5 04 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
        x64-Catalog5 05 C:\Windows\System32\NLAapi.dll [97280] (Microsoft Corporation)
        x64-Catalog5 06 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog5 07 C:\Windows\System32\winrnr.dll [49152] (Microsoft Corporation)
        x64-Catalog9 01 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 02 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 03 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 04 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 05 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 06 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 07 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 08 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 09 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 10 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 11 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 12 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 13 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        x64-Catalog9 14 C:\Windows\System32\mswsock.dll [419584] (Microsoft Corporation)
        Application errors:[/HEADING]
        [HEADING=1]Error: (07/16/2024 06:57:34 AM) (Source: Report Server Windows Service (MSSQLSERVER)) (EventID: 107) (User: )
        Description: Report Server Windows Service (MSSQLSERVER) cannot connect to the report server database.
        Error: (07/16/2024 06:57:33 AM) (Source: Report Server Windows Service (MSSQLSERVER)) (EventID: 113) (User: )
        Description: The report server cannot create the Cache Flushes/Sec performance counter.
        Description: The report server cannot create the Total Cache Flushes performance counter.
        Description: The report server cannot create the Snapshot Updates/Sec performance counter.
        Description: The report server cannot create the Total Snapshot Updates performance counter.
        Description: The report server cannot create the Events/Sec performance counter.
        Description: The report server cannot create the Total Events performance counter.
        Description: The report server cannot create the Delivers/Sec performance counter.
        Description: The report server cannot create the Total Deliveries performance counter.
        Description: The report server cannot create the Total App Domain Recycles performance counter.
        System errors:[/HEADING]
        [HEADING=1]Error: (07/16/2024 06:56:57 AM) (Source: SNMP) (EventID: 1500) (User: )
        Description: The SNMP Service encountered an error while accessing the registry key SYSTEM\CurrentControlSet\Services\SNMP\Parameters\ TrapConfiguration.
        Error: (07/16/2024 06:55:10 AM) (Source: SNMP) (EventID: 1500) (User: )
        Error: (07/15/2024 10:34:56 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
        Description: The MsDtsServer110 service failed to start due to the following error:
        %%1053 = The service did not respond to the start or control request in a timely fashion.
        Error: (07/15/2024 10:34:56 PM) (Source: Service Control Manager) (EventID: 7009) (User: )
        Description: A timeout was reached (45000 milliseconds) while waiting for the MsDtsServer110 service to connect.
        Error: (07/15/2024 10:34:14 PM) (Source: SNMP) (EventID: 1500) (User: )
        Error: (07/15/2024 10:33:22 PM) (Source: EventLog) (EventID: 6008) (User: )
        Description: The previous system shutdown at 10:30:06 PM on ‎7/‎15/‎2024 was unexpected.
        Error: (07/15/2024 10:25:11 PM) (Source: SNMP) (EventID: 1500) (User: )
        Error: (07/15/2024 02:48:28 PM) (Source: SNMP) (EventID: 1500) (User: )
        Error: (07/15/2024 02:44:53 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
        Description: The GoogleUpdaterService128.0.6537.0 service failed to start due to the following error:
        Description: The GoogleUpdaterInternalService128.0.6537.0 service failed to start due to the following error:
        Windows Defender:[/HEADING]
        [HEADING=1]Date: 2024-07-15 22:08:23
        Description:
        Microsoft Defender Antivirus scan has been stopped before completion.
        Scan Type: Antimalware
        Scan Parameters: Quick Scan
        Date: 2024-07-15 06:51:24
        Description:
        Date: 2024-07-11 22:17:15
        Description:
        Date: 2024-07-11 22:12:45
        Description:
        Date: 2024-07-10 13:37:08
        Description:
        Event[0]:
        Date: 2023-09-19 08:03:47
        Description:
        Microsoft Defender Antivirus has encountered an error trying to update security intelligence.
        New security intelligence Version:
        Previous security intelligence Version: 1.397.1208.0
        Update Source: Microsoft Update Server
        Security intelligence Type: AntiVirus
        Update Type: Full
        Current Engine Version:
        Previous Engine Version: 1.1.23080.2005
        Error code: 0x80240438
        Error description: An unexpected problem occurred while checking for updates. For information on installing or troubleshooting updates, see Help and Support.
        CodeIntegrity Errors:[/HEADING]
        [HEADING=1]Date: 2024-07-16 07:07:30
        Description:
        Code Integrity determined that a process (\Device\HarddiskVolume1\Windows\System32\svchost. exe) attempted to load \Device\HarddiskVolume1\Program Files\Malwarebytes\Anti-Malware\mbamsi64.dll that did not meet the Windows signing level requirements.
        Date: 2024-07-16 06:55:37
        Description:
        Code Integrity determined that a process (\Device\HarddiskVolume1\Windows\System32\SIHClien t.exe) attempted to load \Device\HarddiskVolume1\Program Files\Malwarebytes\Anti-Malware\mbamsi64.dll that did not meet the Windows signing level requirements.
        Date: 2022-12-03 17:26:27
        Description:
        Code Integrity determined that a process (\Device\HarddiskVolume1\Program Files\Mozilla Firefox\firefox.exe) attempted to load \Device\HarddiskVolume1\Program Files\Mozilla Firefox\mozavcodec.dll that did not meet the Microsoft signing level requirements.
        Description:
        Code Integrity determined that a process (\Device\HarddiskVolume1\Program Files\Mozilla Firefox\firefox.exe) attempted to load \Device\HarddiskVolume1\Program Files\Mozilla Firefox\mozavutil.dll that did not meet the Microsoft signing level requirements.
        1394 OHCI Compliant Host Controller (Legacy) (HKLM-x32...{B12878BB-DA05-4F25-96E7-E0200428B220}) (Version: 0.0.1 - Microsoft Corporation)
        AMD Software (HKLM...\AMD Catalyst Install Manager) (Version: 23.7.2 - Advanced Micro Devices, Inc.)
        AppNHost 1.0.5.1 (HKLM-x32...{A8CB86C7-CD4C-4C4F-AF6A-33D1CAC63562}) (Version: 1.0.5.1 - Mixesoft Project)
        Branding64 (HKLM...{2A677A6A-43E8-4FE3-A273-07B0E27DADAE}) (Version: 1.00.0008 - Advanced Micro Devices, Inc.) Hidden
        Canon IJ Scan Utility (HKLM-x32...\Canon_IJ_Scan_Utility) (Version: - Canon Inc.)
        Canon MG2500 series MP Drivers (HKLM...{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MG2500_series) (Version: 1.02 - Canon Inc.)
        Canon MG2500 series User Registration (HKLM-x32...\Canon MG2500 series User Registration) (Version: - ‭Canon Inc.)
        Canon My Printer (HKLM-x32...\CanonMyPrinter) (Version: 3.3.0 - Canon Inc.)
        Dual-Core Optimizer (HKLM-x32...{9FD6F1A8-5550-46AF-8509-271DF0E768B5}) (Version: 1.1.4.0169 - AMD)
        Epic Games Launcher (HKLM-x32...{53041896-BE90-4A26-9954-9E9FDC7D4495}) (Version: 1.1.229.0 - Epic Games, Inc.)
        Epic Online Services (HKLM-x32...{4757C19B-4CE3-418C-91D2-E15E938091FB}) (Version: 2.0.39.0 - Epic Games, Inc.)
        GDR 5343 for SQL Server 2012 (KB3045321) (64-bit) (HKLM...\KB3045321) (Version: 11.2.5343.0 - Microsoft Corporation)
        GDR 5388 for SQL Server 2012 (KB3194719) (64-bit) (HKLM...\KB3194719) (Version: 11.2.5388.0 - Microsoft Corporation)
        Google Chrome (HKLM-x32...\Google Chrome) (Version: 126.0.6478.127 - Google LLC)
        Google Earth Pro (HKLM...{3470AD08-85F2-4B1D-8487-FC4750732087}) (Version: 7.3.6.9796 - Google)
        Google Update Helper (HKLM-x32...{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
        HWiNFO64 (HKLM...\HWiNFO64_is1) (Version: 8.02 - Martin Malik, REALiX s.r.o.)
        Imaging And Configuration Designer (HKLM-x32...{E0F2B4CC-8551-9304-84E0-73535C1AA953}) (Version: 10.1.17134.1 - Microsoft) Hidden
        Imaging Designer (HKLM-x32...{E1A52E1E-7F37-2A0D-3F17-F4B349EB9EA2}) (Version: 10.1.17134.1 - Microsoft) Hidden
        Imaging Tools Support (HKLM-x32...{0EAC56B8-9CC7-C9E0-A0FB-62A6787D2699}) (Version: 10.1.17134.1 - Microsoft) Hidden
        ImgBurn (HKLM-x32...\ImgBurn) (Version: 2.5.8.0 - LIGHTNING UK!)
        Intel(R) Management Engine Components (HKLM-x32...{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 8.0.10.1464 - Intel Corporation)
        Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32...{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 1.0.4.225 - Intel Corporation)
        Kits Configuration Installer (HKLM-x32...{C690B2D9-0AA8-8CDA-965D-FED648C3EF9C}) (Version: 10.1.17134.1 - Microsoft) Hidden
        Launcher Prerequisites (x64) (HKLM-x32...{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
        LibreOffice 7.1.5.2 (HKLM...{4F0D0C39-A2CD-4908-AA4C-A1CC9BDCD71A}) (Version: 7.1.5.2 - The Document Foundation)
        Live! Cam Sync HD VF0770 Driver (1.00.07.00) (HKLM...\Creative VF0770) (Version: - Creative Technology Ltd.)
        Malwarebytes version 5.1.6.117 (HKLM...{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}is1) (Version: 5.1.6.117 - Malwarebytes)
        MediaHuman Audio Converter version 1.9.4 (HKLM-x32...\MediaHuman Audio Converter_is1) (Version: 1.9.4 - MediaHuman)
        Microsoft Camera Codec Pack (HKLM...{D553E8CC-5C56-4B06-AC1A-A443DFF31092}) (Version: 6.3.9723.0 - Microsoft Corporation)
        Microsoft Help Viewer 1.1 (HKLM...\Microsoft Help Viewer 1.1) (Version: 1.1.40219 - Microsoft Corporation)
        Microsoft SQL Server 2008 Setup Support Files (HKLM...{B40EE88B-400A-4266-A17B-E3DE64E94431}) (Version: 10.1.2731.0 - Microsoft Corporation)
        Microsoft SQL Server 2012 (64-bit) (HKLM...\Microsoft SQL Server SQLServer2012) (Version: - Microsoft Corporation)
        Microsoft SQL Server 2012 Data-Tier App Framework (HKLM...{DC5602AF-666C-4A56-92C3-B8D675003775}) (Version: 11.1.2818.0 - Microsoft Corporation)
        Microsoft SQL Server 2012 Management Objects (x64) (HKLM...{FA0A244E-F3C2-4589-B42A-3D522DE79A42}) (Version: 11.0.2100.60 - Microsoft Corporation)
        Microsoft SQL Server 2012 Native Client (HKLM...{2B9EE1FE-105F-4093-A40E-C1BF12F873B7}) (Version: 11.2.5388.0 - Microsoft Corporation)
        Microsoft SQL Server 2012 Setup (English) (HKLM...{C23DBA16-E075-41BE-AE2E-C1B0DD0B4535}) (Version: 11.2.5388.0 - Microsoft Corporation)
        Microsoft SQL Server 2012 Transact-SQL Compiler Service (HKLM...{FA73FAE6-BAE5-4928-8CBB-00D311B6DFD3}) (Version: 11.2.5388.0 - Microsoft Corporation)
        Microsoft SQL Server 2012 Transact-SQL ScriptDom (HKLM...{E721A8AA-2632-4798-B439-6D4C8A689BB8}) (Version: 11.2.5058.0 - Microsoft Corporation)
        Microsoft SQL Server 2012 T-SQL Language Service (HKLM...{CC8B009A-98C9-497F-99AF-CEBE35D8C0CF}) (Version: 11.0.2100.60 - Microsoft Corporation)
        Microsoft System CLR Types for SQL Server 2012 (x64) (HKLM...{DEB263CA-0386-4648-8382-FB78DBFA2C5F}) (Version: 11.2.5058.0 - Microsoft Corporation)
        Microsoft Update Health Tools (HKLM...{1FC1A6C2-576E-489A-9B4A-92D21F542136}) (Version: 3.74.0.0 - Microsoft Corporation)
        Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
        Microsoft Visual C++ 2005 Redistributable (x64) (HKLM...{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}) (Version: 8.0.61000 - Microsoft Corporation)
        Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM...{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
        Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM...{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
        Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
        Microsoft Visual Studio Tools for Applications x64 Runtime 3.0 (HKLM...{F14401A9-F0A0-33CC-8444-F60823A60DEB}) (Version: 10.0.40220 - Microsoft Corporation)
        Microsoft VSS Writer for SQL Server 2012 (HKLM...{3E0DD83F-BE4C-4478-86A0-AD0D79D1353E}) (Version: 11.2.5058.0 - Microsoft Corporation)
        Mozilla Firefox (x64 en-GB) (HKLM...\Mozilla Firefox 128.0 (x64 en-GB)) (Version: 128.0 - Mozilla)
        Mozilla Maintenance Service (HKLM...\MozillaMaintenanceService) (Version: 120.0.1 - Mozilla)
        MUSTEK 1248UB V1.2 (HKLM-x32...{514C5488-192E-4C40-ACE5-CD28ECEED0E3}) (Version: 1.00.0000 - mustek) Hidden
        MUSTEK 1248UB V1.2 (HKLM-x32...\InstallShield
        NirSoft Wireless Network Watcher (HKLM-x32...\NirSoft Wireless Network Watcher) (Version: - )
        NVIDIA PhysX System Software 9.17.0524 (HKLM...{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
        OpenAL (HKLM-x32...\OpenAL) (Version: - )
        Origin (HKLM-x32...\Origin) (Version: 9.12.2.60376 - Electronic Arts, Inc.)
        paint.net (HKLM...{A89BF790-0679-403A-9CC7-4015DBF4FEBA}) (Version: 5.0.13 - dotPDN LLC)
        PC VGA Camer@ Plus (HKLM-x32...{A59AB961-BE82-41E0-B0FB-648DFA6DDEA4}) (Version: 1.0.0.19 - Aecotech)
        PCSX2 - Playstation 2 Emulator (HKLM-x32...\pcsx2) (Version: 1.6.0 - PCSX2 Team)
        PDF Settings CS5 (HKLM-x32...{A78FE97A-C0C8-49CE-89D0-EDD524A17392}) (Version: 10.0 - Adobe Systems Incorporated) Hidden
        Pegasun System Utilities (HKLM-x32...{BFDC3B26-7DB0-43D3-BC84-7E9649C157EA}_is1) (Version: 7.1 - Pegasun)
        PixInsight Core for Windows (HKLM-x32...\PCL64) (Version: - )
        Prerequisites for SSDT (HKLM-x32...{9169C939-ED01-446A-BD0C-29873BAF4E48}) (Version: 11.0.2100.60 - Microsoft Corporation)
        Qtracker (HKLM-x32...\Qtracker) (Version: 4.92 - )
        Realtek Ethernet Controller Driver (HKLM-x32...{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.053.1001.2021 - Realtek)
        Realtek High Definition Audio Driver (HKLM-x32...{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8036 - Realtek Semiconductor Corp.)
        Samsung Magician (HKLM-x32...{29AE3F9F-7158-4ca7-B1ED-28A73ECDB215}_is1) (Version: 5.1.0.1120 - Samsung Electronics)
        Samsung USB Driver for Mobile Phones (HKLM...{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.7.43.0 - Samsung Electronics Co., Ltd.)
        Secure Download Manager (HKLM-x32...{E040B65B-8683-4228-8C33-D44A141E40EA}) (Version: 3.1.60 - Kivuto Solutions Inc.)
        Service Pack 2 for SQL Server 2012 (KB2958429) (64-bit) (HKLM...\KB2958429) (Version: 11.2.5058.0 - Microsoft Corporation)
        Shotcut (HKLM-x32...\Shotcut) (Version: 20.04.12 - Meltytech, LLC)
        SlimComputer (HKLM-x32...{80BDBB4C-163E-4F4B-9533-59A7ED62A695}) (Version: 1.1.4130 - Slimware Utilities, Inc.)
        Speccy (HKLM...\Speccy) (Version: 1.32 - Piriform)
        SQL Server 2012 Analysis Services (HKLM...{9674CB74-4808-4B59-B79D-9AB501F23279}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Analysis Services (HKLM...{FB1349FD-D102-4722-9F0A-2543670FF7FB}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 BI Development Studio (HKLM...{656E214E-B73F-458C-AD64-ED316F008207}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 BI Development Studio (HKLM...{EE1B54D1-BFBC-4C19-8D66-E0AF3E967896}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Client Tools (HKLM...{6B3840D6-4B8F-4E74-9202-9CE36DA94E99}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Client Tools (HKLM...{7842C220-6E9A-4D5A-AE70-0E138271F883}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Common Files (HKLM...{1D411379-9CE0-4B13-A19B-72D3222DD620}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Common Files (HKLM...{202AAF1F-69AA-442A-B59F-6B54B1AD07C6}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Data quality client (HKLM...{3C50A8F3-6BB8-44E8-9B8B-D3696561DF2E}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Data quality client (HKLM...{80162C08-0FA6-4656-9685-AD88C6527F0B}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Data quality service (HKLM...{1ABA92B0-CD1F-478B-A351-415F79B2A9E6}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Data quality service (HKLM...{38661DD1-576D-48CA-A188-F97819D5B5FB}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
        SQL Server 2012 Database Engine Services (HKLM...{18B2A97C-92C3-4AC7-BE72-F823E0BC895B}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Database Engine Services (HKLM...{84FBCA4A-D650-4B0D-8094-EC0671FA9B91}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Database Engine Shared (HKLM...{54FF8FAB-DE27-4187-82F1-EBAE6AEE869A}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Database Engine Shared (HKLM...{6603C2CE-3C54-4F1D-92F9-8390CD4CCCA8}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Documentation Components (HKLM...{7272DF1C-2F88-43AC-A481-84DD67DF9746}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
        SQL Server 2012 Documentation Components (HKLM...{B3192F55-2CE8-4C8E-9E40-D3B4998276B2}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
        SQL Server 2012 Documentation Components (HKLM...{CECA0188-BD7A-43EF-B1F7-DDF719099C46}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
        SQL Server 2012 Full text search (HKLM...{34A7A77A-A23D-44ED-B3B6-EC8198BE2622}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Integration Services (HKLM...{22BCA430-2A68-4678-9824-184F3839948F}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Integration Services (HKLM...{36BF5D42-BF68-4E0C-A165-A4C6E9841F4A}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Management Studio (HKLM...{26BFF1F1-5C03-4C55-9C7C-FD65889AFA70}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Management Studio (HKLM...{A7037EB2-F953-4B12-B843-195F4D988DA1}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Reporting Services (HKLM...{DCCB1789-1DA0-4E3A-A52F-7815B602CC98}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 Reporting Services (HKLM...{FCD81E1A-6ED6-4F19-A572-82FFE102654E}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server 2012 SQL Data Quality Common (HKLM...{D307B5CF-D1F0-48A4-8DA3-54765F535208}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        SQL Server Browser for SQL Server 2012 (HKLM-x32...{4B9E6EB0-0EED-4E74-9479-F982C3254F71}) (Version: 11.2.5058.0 - Microsoft Corporation)
        Sql Server Customer Experience Improvement Program (HKLM...{BED1EA3D-592D-4305-9D1F-20F03726EFC1}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
        Steam (HKLM-x32...{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
        swMSM (HKLM-x32...{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
        TechPowerUp GPU-Z (HKLM-x32...\TechPowerUp GPU-Z) (Version: - TechPowerUp)
        TemWebRTCPlugin (HKLM-x32...{00A96020-0597-4602-9E6F-FDACD74483B4}) (Version: 0.8.902 - Temasys)
        the Free Unix Spectrum Emulator (Fuse) 1.6.0 (HKLM-x32...\Fuse) (Version: 1.6.0 - )
        Toolkit Documentation (HKLM-x32...{563689A6-D95B-EA6D-665F-97959643E0DB}) (Version: 10.1.17134.1 - Microsoft) Hidden
        Ubisoft Connect (HKLM-x32...\Uplay) (Version: 137.0.10799 - Ubisoft)
        UE4 Prerequisites (x64) (HKLM...{36EAD5CF-44EF-4FCF-8BE1-D96C4835D7A4}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
        UE4 Prerequisites (x64) (HKLM-x32...{2890ae6b-90e9-448d-b3e6-97e43c21e2fd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
        UEV Tools on amd64 (HKLM...{45B55BB8-B09F-6204-E1A1-1443C81DCDA9}) (Version: 10.1.17134.1 - Microsoft) Hidden
        Update for Windows 10 for x64-based Systems (KB5001716) (HKLM...{85C69797-7336-4E83-8D97-32A7C8465A3B}) (Version: 8.94.0.0 - Microsoft Corporation)
        User State Migration Tool (HKLM-x32...{E224B062-6D80-A746-F08C-9847DF1B5144}) (Version: 10.1.17134.1 - Microsoft) Hidden
        Visual Studio 2010 Prerequisites - English (HKLM...{662014D2-0450-37ED-ABAE-157C88127BEB}) (Version: 10.0.40219 - Microsoft Corporation)
        VLC media player (HKLM...\VLC media player) (Version: 3.0.10 - VideoLAN)
        VobSub v2.23 (Remove Only) (HKLM-x32...\VobSub) (Version: - )
        Windows Driver Package - Google, Inc. (WinUSB) AndroidUsbDeviceClass (01/27/2014 9.0.0000.00000) (HKLM...\9CA77E2A8332A0824C54DA611BBE4CA24AB1F750) (Version: 01/27/2014 9.0.0000.00000 - Google, Inc.)
        Winki (HKLM-x32...{81CF5153-38CF-41e2-AC3C-3D477C987D96}_is1) (Version: 3.2.123 - MSI)
        WinRAR 5.70 (64-bit) (HKLM...\WinRAR archiver) (Version: 5.70.0 - win.rar GmbH)
        WP_CPTT_NT-x86-fre (HKLM-x32...{E6F4B9E6-6C5C-9EE0-1CEC-23F80B1960F5}) (Version: 10.1.17134.1 - Microsoft) Hidden
        WPT Redistributables (HKLM-x32...{EEB65046-3AB2-821A-12BD-F0C0490D46D2}) (Version: 10.1.17134.1 - Microsoft) Hidden
        WPTx64 (HKLM-x32...{C7B318E4-43EF-AA14-637F-6C6EDF59917D}) (Version: 10.1.17134.1 - Microsoft) Hidden
        XviD MPEG4 Video Codec (remove only) (HKLM-x32...\XviD MPEG4 Video Codec) (Version: - )
        ZX-Paintbrush (HKLM-x32...{59EBF467-993A-48CC-98AE-34510EE8A1F0}) (Version: 2.4.0.1 - Claus Jahn)
        Packages:[/HEADING]
        AMD Link → C:\Program Files\WindowsApps\AdvancedMicroDevicesInc-2.AMDLink_10.23.30003.0_x64__0a9344xs7nr4m [2024-01-25] (Advanced Micro Devices Inc.)
        DuckDuckGo → C:\Program Files\WindowsApps\DuckDuckGo.DesktopBrowser_0.56.1 .0_x64__ya2fgkz3nks94 [2023-11-05] (DuckDuckGo)
        Microsoft Advertising SDK for XAML → C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.18 11.1.0_x64__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
        Microsoft Advertising SDK for XAML → C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.18 11.1.0_x86__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
        PDF X → C:\Program Files\WindowsApps\6760NGPDFLab.PDFX_1.4.1.0_x64__s be4t8mqwq93a [2024-07-10] (NG PDF Lab) [Startup Task]
        Windows App Studio Installer → C:\Program Files\WindowsApps\Microsoft.WindowsAppStudioInstal ler_1.0.18.0_x86__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
        Windows Package Manager Source (winget) → C:\Program Files\WindowsApps\Microsoft.Winget.Source_2023.128 .1438.590_neutral__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation)
        Percentage of memory in use: 29%
        Total physical RAM: 16332.88 MB
        Available physical RAM: 11485.1 MB
        Total Virtual: 32716.88 MB
        Available Virtual: 25964.89 MB
        1 Drive c: () (Fixed) (Total:465.26 GB) (Free:228.16 GB) NTFS
        3 Drive f: (Storage1) (Fixed) (Total:465.75 GB) (Free:218.52 GB) NTFS
        User accounts for \MYSTERYMACHINE
        Administrator chredge DefaultAccount
        Guest WDAGUtilityAccount
        ========================= Minidump Files ==================================
        No minidump file found
        ========================= Restore Points ==================================
        29-06-2024 17:59:21 Scheduled Checkpoint
        09-07-2024 05:44:53 Scheduled Checkpoint
        **** End of log ****[/spoiler]
          Is it completely back to normal - the slowness is gone, and it restarts OK?
          The antimalware service executable is the MsMpEng.exe program which is Windows Defender.
          But infections can disguise themselves as that as well.
          Would you like this thread moved to the Am I Infected thread so our resident security expert can check you PC for gremlins?
          • Ginger-Overlord
            • Jul 2024
            • 61
            Hi Bruce,
            Yes, please move to the Am I Infected thread.
            It appears to be back to normal but I would like it to be investigated in case there is something sinister happening.
            Thanks again for your help.
            Ginger-Overlord
              @Malnutrition - your magic please (y)
              • Malnutrition
                PCHF Moderator
                • 7041
                Please follow the instructions here. https://pchelpforum.net/t/prework-pl...235/post-11788
                Attach both Frst and addition.txt logs for review.
                • Ginger-Overlord
                  • Jul 2024
                  • 61
                  Hi there,
                  Turned my PC on this morning and things seemed fine for a while, then it started to lag again, then eventually shut itself down. Seems like I’m back to square one.
                  I’ll attempt to get them logs posted on here later, when I finish work.
                  Thanks again.
                  • Malnutrition
                    PCHF Moderator
                    • 7041
                    #10
                    Ok. Logs will be the only way forward. I’ll check this thread when I return home from work myself. ???
                    • Ginger-Overlord
                      • Jul 2024
                      • 61
                      #11
                      Hi,
                      I’m on the PC now and it seems OK again…for the moment. Here are my logs, FRST first:
                      Code:
                      Additional scan result of Farbar Recovery Scan Tool (x64) Version: 16.07.2024
                      Ran by chredge (17-07-2024 17:16:36)
                      Running from C:\Users\chredge\Desktop
                      Microsoft Windows 10 Home Version 22H2 19045.4651 (X64) (2021-04-22 17:10:26)
                      Boot Mode: Normal
                      Administrator (S-1-5-21-3466739526-2485095647-408758403-500 - Administrator - Disabled)
                      chredge (S-1-5-21-3466739526-2485095647-408758403-1009 - Administrator - Enabled) => C:\Users\chredge
                      DefaultAccount (S-1-5-21-3466739526-2485095647-408758403-503 - Limited - Disabled)
                      Guest (S-1-5-21-3466739526-2485095647-408758403-501 - Limited - Disabled)
                      HomeGroupUser$ (S-1-5-21-3466739526-2485095647-408758403-1002 - Limited - Enabled)
                      WDAGUtilityAccount (S-1-5-21-3466739526-2485095647-408758403-504 - Limited - Disabled)
                      AV: Windows Defender (Enabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
                      1394 OHCI Compliant Host Controller (Legacy) (HKLM-x32\...\{B12878BB-DA05-4F25-96E7-E0200428B220}) (Version: 0.0.1 - Microsoft Corporation)
                      Ace Stream Media 3.1.20.2 (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\AceStream) (Version: 3.1.20.2 - Ace Stream Media) <==== ATTENTION
                      Adobe Photoshop CS5.1 (HKLM-x32\...\{9158FF30-78D7-40EF-B83E-451AC5334640}) (Version: 12.1 - Adobe Systems Incorporated)
                      AMD Software (HKLM\...\AMD Catalyst Install Manager) (Version: 23.7.2 - Advanced Micro Devices, Inc.)
                      AppNHost 1.0.5.1 (HKLM-x32\...\{A8CB86C7-CD4C-4C4F-AF6A-33D1CAC63562}) (Version: 1.0.5.1 - Mixesoft Project)
                      Branding64 (HKLM\...\{2A677A6A-43E8-4FE3-A273-07B0E27DADAE}) (Version: 1.00.0008 - Advanced Micro Devices, Inc.) Hidden
                      Canon IJ Scan Utility (HKLM-x32\...\Canon_IJ_Scan_Utility) (Version: - Canon Inc.)
                      Canon MG2500 series MP Drivers (HKLM\...\{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MG2500_series) (Version: 1.02 - Canon Inc.)
                      Canon MG2500 series User Registration (HKLM-x32\...\Canon MG2500 series User Registration) (Version: - <U+202D>Canon Inc.)
                      Canon My Printer (HKLM-x32\...\CanonMyPrinter) (Version: 3.3.0 - Canon Inc.)
                      Dual-Core Optimizer (HKLM-x32\...\{9FD6F1A8-5550-46AF-8509-271DF0E768B5}) (Version: 1.1.4.0169 - AMD)
                      Epic Games Launcher (HKLM-x32\...\{53041896-BE90-4A26-9954-9E9FDC7D4495}) (Version: 1.1.229.0 - Epic Games, Inc.)
                      Epic Online Services (HKLM-x32\...\{4757C19B-4CE3-418C-91D2-E15E938091FB}) (Version: 2.0.39.0 - Epic Games, Inc.)
                      GDR 5343 for SQL Server 2012 (KB3045321) (64-bit) (HKLM\...\KB3045321) (Version: 11.2.5343.0 - Microsoft Corporation)
                      GDR 5388 for SQL Server 2012 (KB3194719) (64-bit) (HKLM\...\KB3194719) (Version: 11.2.5388.0 - Microsoft Corporation)
                      Google Chrome (HKLM-x32\...\Google Chrome) (Version: 126.0.6478.128 - Google LLC)
                      Google Earth Pro (HKLM\...\{3470AD08-85F2-4B1D-8487-FC4750732087}) (Version: 7.3.6.9796 - Google)
                      Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
                      HP Webcam HD 2300 Software (HKLM-x32\...\{74E6771A-47B5-433E-A96F-15E29F70F920}) (Version: 1.00.0000 - Hewlett-Packard)
                      HWiNFO64 (HKLM\...\HWiNFO64_is1) (Version: 8.02 - Martin Malik, REALiX s.r.o.)
                      Imaging And Configuration Designer (HKLM-x32\...\{E0F2B4CC-8551-9304-84E0-73535C1AA953}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Imaging Designer (HKLM-x32\...\{E1A52E1E-7F37-2A0D-3F17-F4B349EB9EA2}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Imaging Tools Support (HKLM-x32\...\{0EAC56B8-9CC7-C9E0-A0FB-62A6787D2699}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      ImgBurn (HKLM-x32\...\ImgBurn) (Version: 2.5.8.0 - LIGHTNING UK!)
                      Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 8.0.10.1464 - Intel Corporation)
                      Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 1.0.4.225 - Intel Corporation)
                      Intel® Trusted Connect Service Client (HKLM\...\{171C7193-1BB5-4619-BF23-E962598CAB13}) (Version: 1.23.943.1 - Intel Corporation) Hidden
                      Java 8 Update 161 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180161F0}) (Version: 8.0.1610.12 - Oracle Corporation)
                      Java 8 Update 162 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180162F0}) (Version: 8.0.1620.12 - Oracle Corporation)
                      Kits Configuration Installer (HKLM-x32\...\{C690B2D9-0AA8-8CDA-965D-FED648C3EF9C}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
                      LibreOffice 7.1.5.2 (HKLM\...\{4F0D0C39-A2CD-4908-AA4C-A1CC9BDCD71A}) (Version: 7.1.5.2 - The Document Foundation)
                      Live! Cam Sync HD VF0770 Driver (1.00.07.00) (HKLM\...\Creative VF0770) (Version: - Creative Technology Ltd.)
                      Malwarebytes version 5.1.6.117 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 5.1.6.117 - Malwarebytes)
                      MediaHuman Audio Converter version 1.9.4 (HKLM-x32\...\MediaHuman Audio Converter_is1) (Version: 1.9.4 - MediaHuman)
                      Microsoft .NET Framework 4 Multi-Targeting Pack (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}) (Version: 4.0.30319 - Microsoft Corporation)
                      Microsoft .NET Framework 4.5.1 (HKLM\...\{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}) (Version: 4.5.50938 - Microsoft Corporation) Hidden
                      Microsoft Camera Codec Pack (HKLM\...\{D553E8CC-5C56-4B06-AC1A-A443DFF31092}) (Version: 6.3.9723.0 - Microsoft Corporation)
                      Microsoft DVD App Installation for Microsoft.WindowsDVDPlayer_2019.6.13291.0_neutral_~_8wekyb3d8bbwe (x64) (HKLM\...\{25E80DAA-FD87-DCE5-202C-CC02F6673002}) (Version: 1.0.0.0 - Microsoft Corporation) Hidden
                      Microsoft Edge (HKLM-x32\...\Microsoft Edge) (Version: 126.0.2592.102 - Microsoft Corporation)
                      Microsoft Edge WebView2 Runtime (HKLM-x32\...\Microsoft EdgeWebView) (Version: 126.0.2592.102 - Microsoft Corporation)
                      Microsoft Games for Windows - LIVE (HKLM-x32\...\{2C9EE786-1DDB-4C98-8FA4-B1B9B5A66B77}) (Version: 3.1.186.0 - Microsoft Corporation)
                      Microsoft Games for Windows - LIVE Redistributable (HKLM-x32\...\{832D9DE0-8AFC-4689-9819-4DBBDEBD3E4F}) (Version: 3.5.92.0 - Microsoft Corporation)
                      Microsoft Help Viewer 1.1 (HKLM\...\{E5748D30-7E6D-3A8E-BFE6-C1D02C6DDABB}) (Version: 1.1.40219 - Microsoft Corporation) Hidden
                      Microsoft Help Viewer 1.1 (HKLM\...\Microsoft Help Viewer 1.1) (Version: 1.1.40219 - Microsoft Corporation)
                      Microsoft HEVC Media Extension Installation for Microsoft.HEVCVideoExtension_1.0.2512.0_x64__8wekyb3d8bbwe (x64) (HKLM\...\{B0169E83-757B-EF66-E2F0-391944D785BC}) (Version: 1.0.0.0 - Microsoft Corporation) Hidden
                      Microsoft Report Viewer 2012 Runtime (HKLM-x32\...\{9CCE40CE-A9E6-4916-8729-B008558EEF3F}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft Security Client (HKLM\...\{D9FCBAAE-DB72-488B-96D0-0AA3C892C0D6}) (Version: 4.8.0204.0 - Microsoft Corporation) Hidden
                      Microsoft SQL Server 2008 R2 Management Objects (HKLM-x32\...\{83F2B8F4-5CF3-4BE9-9772-9543EAE4AC5F}) (Version: 10.51.2500.0 - Microsoft Corporation)
                      Microsoft SQL Server 2008 Setup Support Files (HKLM\...\{B40EE88B-400A-4266-A17B-E3DE64E94431}) (Version: 10.1.2731.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 (64-bit) (HKLM\...\Microsoft SQL Server SQLServer2012) (Version: - Microsoft Corporation)
                      Microsoft SQL Server 2012 Data-Tier App Framework (HKLM\...\{DC5602AF-666C-4A56-92C3-B8D675003775}) (Version: 11.1.2818.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Management Objects (HKLM-x32\...\{DA1C1761-5F4F-4332-AB9D-29EDF3F8EA0A}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Management Objects (x64) (HKLM\...\{FA0A244E-F3C2-4589-B42A-3D522DE79A42}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Native Client (HKLM\...\{2B9EE1FE-105F-4093-A40E-C1BF12F873B7}) (Version: 11.2.5388.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Policies (HKLM-x32\...\{DC487E40-046E-42A9-9C7C-5D2B1A7EB211}) (Version: 11.2.5058.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 RsFx Driver (HKLM\...\{9F616548-62E3-4C12-9E35-74A650BC199C}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      Microsoft SQL Server 2012 Setup (English) (HKLM\...\{C23DBA16-E075-41BE-AE2E-C1B0DD0B4535}) (Version: 11.2.5388.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Transact-SQL Compiler Service (HKLM\...\{FA73FAE6-BAE5-4928-8CBB-00D311B6DFD3}) (Version: 11.2.5388.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 Transact-SQL ScriptDom (HKLM\...\{E721A8AA-2632-4798-B439-6D4C8A689BB8}) (Version: 11.2.5058.0 - Microsoft Corporation)
                      Microsoft SQL Server 2012 T-SQL Language Service (HKLM\...\{CC8B009A-98C9-497F-99AF-CEBE35D8C0CF}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft SQL Server Data Tools – Database Projects – Web installer entry point (HKLM-x32\...\{F3BBC56F-2282-4464-952F-A89772181F30}) (Version: 10.3.20116.0 - Microsoft Corporation)
                      Microsoft SQL Server System CLR Types (HKLM-x32\...\{C3F6F200-6D7B-4879-B9EE-700C0CE1FCDA}) (Version: 10.51.2500.0 - Microsoft Corporation)
                      Microsoft System CLR Types for SQL Server 2012 (HKLM-x32\...\{E2082604-4BA5-44BB-BBFB-AF0F3CB8C6AB}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Microsoft System CLR Types for SQL Server 2012 (x64) (HKLM\...\{DEB263CA-0386-4648-8382-FB78DBFA2C5F}) (Version: 11.2.5058.0 - Microsoft Corporation)
                      Microsoft Update Health Tools (HKLM\...\{1FC1A6C2-576E-489A-9B4A-92D21F542136}) (Version: 3.74.0.0 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
                      Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
                      Microsoft Visual C++ 2010 x86 Runtime - 10.0.40219 (HKLM-x32\...\{5D9ED403-94DE-3BA0-B1D6-71F4BDA412E6}) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.50727 (HKLM-x32\...\{15134cb0-b767-4960-a911-f2d16ae54797}) (Version: 11.0.50727.1 - Microsoft Corporation)
                      Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
                      Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.50727 (HKLM-x32\...\{22154f09-719a-4619-bb71-5b3356999fbf}) (Version: 11.0.50727.1 - Microsoft Corporation)
                      Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.50727 (HKLM\...\{AC53FC8B-EE18-3F9C-9B59-60937D0B182C}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 (HKLM\...\{37B8F9C7-03FB-3253-8781-2517C99D7C00}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.50727 (HKLM\...\{A2CB1ACB-94A2-32BA-A15E-7D80319F7589}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 (HKLM\...\{CF2BEA3C-26EA-32F8-AA9B-331F7E34BA97}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.50727 (HKLM-x32\...\{FDB30193-FDA0-3DAA-ACCA-A75EEFE53607}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 (HKLM-x32\...\{B175520C-86A2-35A7-8619-86DC379688B9}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.50727 (HKLM-x32\...\{2F73A7B2-E50E-39A6-9ABC-EF89E4C62E36}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 (HKLM-x32\...\{BD95A8CD-1D9F-35AD-981A-3E7925026EBB}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40660 (HKLM-x32\...\{ef6b00ec-13e1-4c25-9064-b2f383cb8412}) (Version: 12.0.40660.0 - Microsoft Corporation)
                      Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40660 (HKLM-x32\...\{61087a79-ac85-455c-934d-1fa22cc64f36}) (Version: 12.0.40660.0 - Microsoft Corporation)
                      Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.40660 (HKLM\...\{5740BD44-B58D-321A-AFC0-6D3D4556DD6C}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.40660 (HKLM\...\{CB0836EC-B072-368D-82B2-D3470BF95707}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.40660 (HKLM-x32\...\{7DAD0258-515C-3DD4-8964-BD714199E0F7}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.40660 (HKLM-x32\...\{E30D8B21-D82D-3211-82CC-0F0A5D1495E8}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.29.30133 (HKLM-x32\...\{295d1583-fdb9-414b-a4c8-da539362a26b}) (Version: 14.29.30133.0 - Microsoft Corporation)
                      Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.24.28127 (HKLM-x32\...\{e31cb1a4-76b5-46a5-a084-3fa419e82201}) (Version: 14.24.28127.4 - Microsoft Corporation)
                      Microsoft Visual C++ 2019 X64 Additional Runtime - 14.29.30133 (HKLM\...\{E699E009-1C3C-4E50-9B57-2B39F0954C7F}) (Version: 14.29.30133 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2019 X64 Minimum Runtime - 14.29.30133 (HKLM\...\{6CD9E9ED-906D-4196-8DC3-F987D2F6615F}) (Version: 14.29.30133 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2019 X86 Additional Runtime - 14.24.28127 (HKLM-x32\...\{EAC73207-74BD-4B13-AACF-8C0E751FA4E8}) (Version: 14.24.28127 - Microsoft Corporation) Hidden
                      Microsoft Visual C++ 2019 X86 Minimum Runtime - 14.24.28127 (HKLM-x32\...\{2E72FA1F-BADB-4337-B8AE-F7C17EC57D1D}) (Version: 14.24.28127 - Microsoft Corporation) Hidden
                      Microsoft Visual Studio 2010 Shell (Integrated) - ENU (HKLM-x32\...\{012D26C3-E12A-3BDA-8ECE-DF14E721A507}) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual Studio 2010 Shell (Isolated) - ENU (HKLM-x32\...\{D64B6984-242F-32BC-B008-752806E5FC44}) (Version: 10.0.40219 - Microsoft Corporation)
                      Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\{9495AEB4-AB97-39DE-8C42-806EEF75ECA7}) (Version: 10.0.50908 - Microsoft Corporation) Hidden
                      Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
                      Microsoft Visual Studio Tools for Applications Design-Time 3.0 (HKLM-x32\...\{5A03C202-08B4-3F1D-9A60-A4F53EF1B636}) (Version: 10.0.40220 - Microsoft Corporation)
                      Microsoft Visual Studio Tools for Applications x64 Runtime 3.0 (HKLM\...\{F14401A9-F0A0-33CC-8444-F60823A60DEB}) (Version: 10.0.40220 - Microsoft Corporation)
                      Microsoft Visual Studio Tools for Applications x86 Runtime 3.0 (HKLM-x32\...\{191A6F65-6878-398D-A272-EF011B80F371}) (Version: 10.0.40220 - Microsoft Corporation)
                      Microsoft VSS Writer for SQL Server 2012 (HKLM\...\{3E0DD83F-BE4C-4478-86A0-AD0D79D1353E}) (Version: 11.2.5058.0 - Microsoft Corporation)
                      Microsoft_VC80_ATL_x86 (HKLM-x32\...\{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_ATL_x86_x64 (HKLM\...\{925D058B-564A-443A-B4B2-7E90C6432E55}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_CRT_x86 (HKLM-x32\...\{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_CRT_x86_x64 (HKLM\...\{4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_MFC_x86 (HKLM-x32\...\{D1A19B02-817E-4296-A45B-07853FD74D57}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_MFC_x86_x64 (HKLM\...\{C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_MFCLOC_x86 (HKLM-x32\...\{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}) (Version: 8.0.50727.4053 - Adobe) Hidden
                      Microsoft_VC80_MFCLOC_x86_x64 (HKLM\...\{1E9FC118-651D-4934-97BE-E53CAE5C7D45}) (Version: 80.50727.4053 - Adobe) Hidden
                      Microsoft_VC90_ATL_x86 (HKLM-x32\...\{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_ATL_x86_x64 (HKLM\...\{8557397C-A42D-486F-97B3-A2CBC2372593}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_CRT_x86 (HKLM-x32\...\{08D2E121-7F6A-43EB-97FD-629B44903403}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_CRT_x86_x64 (HKLM\...\{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_MFC_x86 (HKLM-x32\...\{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_MFC_x86_x64 (HKLM\...\{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_MFCLOC_x86 (HKLM-x32\...\{B6D38690-755E-4F40-A35A-23F8BC2B86AC}) (Version: 1.00.0000 - Adobe) Hidden
                      Microsoft_VC90_MFCLOC_x86_x64 (HKLM\...\{90BF0360-A1DB-4599-A643-95AB90A52C1E}) (Version: 1.00.0000 - Adobe) Hidden
                      Mozilla Firefox (x64 en-GB) (HKLM\...\Mozilla Firefox 128.0 (x64 en-GB)) (Version: 128.0 - Mozilla)
                      Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 120.0.1 - Mozilla)
                      MUSTEK 1248UB V1.2 (HKLM-x32\...\{514C5488-192E-4C40-ACE5-CD28ECEED0E3}) (Version: 1.00.0000 - mustek) Hidden
                      MUSTEK 1248UB V1.2 (HKLM-x32\...\InstallShield_{514C5488-192E-4C40-ACE5-CD28ECEED0E3}) (Version: 1.00.0000 - mustek)
                      NirSoft Wireless Network Watcher (HKLM-x32\...\NirSoft Wireless Network Watcher) (Version: - )
                      NVIDIA PhysX System Software 9.17.0524 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
                      OpenAL (HKLM-x32\...\OpenAL) (Version: - )
                      Origin (HKLM-x32\...\Origin) (Version: 9.12.2.60376 - Electronic Arts, Inc.)
                      paint.net (HKLM\...\{A89BF790-0679-403A-9CC7-4015DBF4FEBA}) (Version: 5.0.13 - dotPDN LLC)
                      PC VGA Camer@ Plus (HKLM-x32\...\{A59AB961-BE82-41E0-B0FB-648DFA6DDEA4}) (Version: 1.0.0.19 - Aecotech)
                      PCSX2 - Playstation 2 Emulator (HKLM-x32\...\pcsx2) (Version: 1.6.0 - PCSX2 Team)
                      PDF Settings CS5 (HKLM-x32\...\{A78FE97A-C0C8-49CE-89D0-EDD524A17392}) (Version: 10.0 - Adobe Systems Incorporated) Hidden
                      Pegasun System Utilities (HKLM-x32\...\{BFDC3B26-7DB0-43D3-BC84-7E9649C157EA}_is1) (Version: 7.1 - Pegasun)
                      PixInsight Core for Windows (HKLM-x32\...\PCL64) (Version: - )
                      Prerequisites for SSDT (HKLM-x32\...\{9169C939-ED01-446A-BD0C-29873BAF4E48}) (Version: 11.0.2100.60 - Microsoft Corporation)
                      Qtracker (HKLM-x32\...\Qtracker) (Version: 4.92 - )
                      Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.053.1001.2021 - Realtek)
                      Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8036 - Realtek Semiconductor Corp.)
                      RegiStax 5 (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\RegiStax 5) (Version: - )
                      RegiStax 6 (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\RegiStax 6) (Version: - )
                      RegiStax 6.1.0.8 update (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\RegiStax 6.1.0.8 update) (Version: - )
                      Samsung Magician (HKLM-x32\...\{29AE3F9F-7158-4ca7-B1ED-28A73ECDB215}_is1) (Version: 5.1.0.1120 - Samsung Electronics)
                      Samsung USB Driver for Mobile Phones (HKLM\...\{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.7.43.0 - Samsung Electronics Co., Ltd.)
                      Secure Download Manager (HKLM-x32\...\{E040B65B-8683-4228-8C33-D44A141E40EA}) (Version: 3.1.60 - Kivuto Solutions Inc.)
                      Service Pack 2 for SQL Server 2012 (KB2958429) (64-bit) (HKLM\...\KB2958429) (Version: 11.2.5058.0 - Microsoft Corporation)
                      Shotcut (HKLM-x32\...\Shotcut) (Version: 20.04.12 - Meltytech, LLC)
                      SlimComputer (HKLM-x32\...\{80BDBB4C-163E-4F4B-9533-59A7ED62A695}) (Version: 1.1.4130 - Slimware Utilities, Inc.)
                      Speccy (HKLM\...\Speccy) (Version: 1.32 - Piriform)
                      SQL Server 2012 Analysis Services (HKLM\...\{9674CB74-4808-4B59-B79D-9AB501F23279}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Analysis Services (HKLM\...\{FB1349FD-D102-4722-9F0A-2543670FF7FB}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 BI Development Studio (HKLM\...\{656E214E-B73F-458C-AD64-ED316F008207}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 BI Development Studio (HKLM\...\{EE1B54D1-BFBC-4C19-8D66-E0AF3E967896}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Client Tools (HKLM\...\{6B3840D6-4B8F-4E74-9202-9CE36DA94E99}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Client Tools (HKLM\...\{7842C220-6E9A-4D5A-AE70-0E138271F883}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Common Files (HKLM\...\{1D411379-9CE0-4B13-A19B-72D3222DD620}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Common Files (HKLM\...\{202AAF1F-69AA-442A-B59F-6B54B1AD07C6}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Data quality client (HKLM\...\{3C50A8F3-6BB8-44E8-9B8B-D3696561DF2E}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Data quality client (HKLM\...\{80162C08-0FA6-4656-9685-AD88C6527F0B}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Data quality service (HKLM\...\{1ABA92B0-CD1F-478B-A351-415F79B2A9E6}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Data quality service (HKLM\...\{38661DD1-576D-48CA-A188-F97819D5B5FB}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
                      SQL Server 2012 Database Engine Services (HKLM\...\{18B2A97C-92C3-4AC7-BE72-F823E0BC895B}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Database Engine Services (HKLM\...\{84FBCA4A-D650-4B0D-8094-EC0671FA9B91}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Database Engine Shared (HKLM\...\{54FF8FAB-DE27-4187-82F1-EBAE6AEE869A}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Database Engine Shared (HKLM\...\{6603C2CE-3C54-4F1D-92F9-8390CD4CCCA8}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Documentation Components (HKLM\...\{7272DF1C-2F88-43AC-A481-84DD67DF9746}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
                      SQL Server 2012 Documentation Components (HKLM\...\{B3192F55-2CE8-4C8E-9E40-D3B4998276B2}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
                      SQL Server 2012 Documentation Components (HKLM\...\{CECA0188-BD7A-43EF-B1F7-DDF719099C46}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
                      SQL Server 2012 Full text search (HKLM\...\{34A7A77A-A23D-44ED-B3B6-EC8198BE2622}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Integration Services (HKLM\...\{22BCA430-2A68-4678-9824-184F3839948F}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Integration Services (HKLM\...\{36BF5D42-BF68-4E0C-A165-A4C6E9841F4A}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Management Studio (HKLM\...\{26BFF1F1-5C03-4C55-9C7C-FD65889AFA70}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Management Studio (HKLM\...\{A7037EB2-F953-4B12-B843-195F4D988DA1}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Reporting Services (HKLM\...\{DCCB1789-1DA0-4E3A-A52F-7815B602CC98}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 Reporting Services (HKLM\...\{FCD81E1A-6ED6-4F19-A572-82FFE102654E}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server 2012 SQL Data Quality Common (HKLM\...\{D307B5CF-D1F0-48A4-8DA3-54765F535208}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      SQL Server Browser for SQL Server 2012 (HKLM-x32\...\{4B9E6EB0-0EED-4E74-9479-F982C3254F71}) (Version: 11.2.5058.0 - Microsoft Corporation)
                      Sql Server Customer Experience Improvement Program (HKLM\...\{BED1EA3D-592D-4305-9D1F-20F03726EFC1}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
                      Steam (HKLM-x32\...\{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
                      swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
                      TechPowerUp GPU-Z (HKLM-x32\...\TechPowerUp GPU-Z) (Version: - TechPowerUp)
                      TemWebRTCPlugin (HKLM-x32\...\{00A96020-0597-4602-9E6F-FDACD74483B4}) (Version: 0.8.902 - Temasys)
                      the Free Unix Spectrum Emulator (Fuse) 1.6.0 (HKLM-x32\...\Fuse) (Version: 1.6.0 - )
                      Toolkit Documentation (HKLM-x32\...\{563689A6-D95B-EA6D-665F-97959643E0DB}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Ubisoft Connect (HKLM-x32\...\Uplay) (Version: 137.0.10799 - Ubisoft)
                      UE4 Prerequisites (x64) (HKLM\...\{36EAD5CF-44EF-4FCF-8BE1-D96C4835D7A4}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
                      UE4 Prerequisites (x64) (HKLM-x32\...\{2890ae6b-90e9-448d-b3e6-97e43c21e2fd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
                      UEV Tools on amd64 (HKLM\...\{45B55BB8-B09F-6204-E1A1-1443C81DCDA9}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Update for Windows 10 for x64-based Systems (KB5001716) (HKLM\...\{85C69797-7336-4E83-8D97-32A7C8465A3B}) (Version: 8.94.0.0 - Microsoft Corporation)
                      User State Migration Tool (HKLM-x32\...\{E224B062-6D80-A746-F08C-9847DF1B5144}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Visual Studio 2010 Prerequisites - English (HKLM\...\{662014D2-0450-37ED-ABAE-157C88127BEB}) (Version: 10.0.40219 - Microsoft Corporation)
                      Visual Studio C++ 10.0 Runtime (HKLM-x32\...\{4412F224-3849-4461-A3E9-DEEF8D252790}) (Version: 10.0.0 - TomTom International B.V.)
                      VLC media player (HKLM\...\VLC media player) (Version: 3.0.10 - VideoLAN)
                      VobSub v2.23 (Remove Only) (HKLM-x32\...\VobSub) (Version: - )
                      Windows Assessment and Deployment Kit - Windows 10 (HKLM-x32\...\{d794748d-72e9-45d7-9ab7-83d6c4c80f7f}) (Version: 10.1.17134.1 - Microsoft Corporation)
                      Windows Deployment Customizations (HKLM-x32\...\{A28EBA01-553B-4346-F8F2-E780592F0BB8}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Windows Deployment Tools (HKLM-x32\...\{C4443D4E-AC00-CF0E-9519-C9111E83ADBB}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Windows Driver Package - Google, Inc. (WinUSB) AndroidUsbDeviceClass (01/27/2014 9.0.0000.00000) (HKLM\...\9CA77E2A8332A0824C54DA611BBE4CA24AB1F750) (Version: 01/27/2014 9.0.0000.00000 - Google, Inc.)
                      Windows Live ID Sign-in Assistant (HKLM\...\{CE52672C-A0E9-4450-8875-88A221D5CD50}) (Version: 7.250.4311.0 - Microsoft Corporation) Hidden
                      Windows PE ARM ARM64 (HKLM-x32\...\{C80B2DA8-46D4-EFFC-8054-D2C663C468D7}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Windows PE ARM ARM64 wims (HKLM-x32\...\{1C15FC16-76B9-E297-905C-0A99FBC5DA1F}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Windows PE x86 x64 (HKLM-x32\...\{346FC109-E9A8-2224-5726-843C7283E4F7}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Windows PE x86 x64 wims (HKLM-x32\...\{64FF0563-D6F1-C8E4-56F8-F678D1158C58}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Windows System Image Manager on amd64 (HKLM-x32\...\{90D52AE3-4CAB-C97A-84D9-9DF0348BBDCA}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      Winki (HKLM-x32\...\{81CF5153-38CF-41e2-AC3C-3D477C987D96}_is1) (Version: 3.2.123 - MSI)
                      WinRAR 5.70 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.70.0 - win.rar GmbH)
                      WP_CPTT_NT-x86-fre (HKLM-x32\...\{E6F4B9E6-6C5C-9EE0-1CEC-23F80B1960F5}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      WPT Redistributables (HKLM-x32\...\{EEB65046-3AB2-821A-12BD-F0C0490D46D2}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      WPTx64 (HKLM-x32\...\{C7B318E4-43EF-AA14-637F-6C6EDF59917D}) (Version: 10.1.17134.1 - Microsoft) Hidden
                      XviD MPEG4 Video Codec (remove only) (HKLM-x32\...\XviD MPEG4 Video Codec) (Version: - )
                      ZX-Paintbrush (HKLM-x32\...\{59EBF467-993A-48CC-98AE-34510EE8A1F0}) (Version: 2.4.0.1 - Claus Jahn)
                      Packages:
                      AMD Link -> C:\Program Files\WindowsApps\AdvancedMicroDevicesInc-2.AMDLink_10.23.30003.0_x64__0a9344xs7nr4m [2024-01-25] (Advanced Micro Devices Inc.)
                      DuckDuckGo -> C:\Program Files\WindowsApps\DuckDuckGo.DesktopBrowser_0.56.1.0_x64__ya2fgkz3nks94 [2023-11-05] (DuckDuckGo)
                      Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x64__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
                      Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x86__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
                      PDF X -> C:\Program Files\WindowsApps\6760NGPDFLab.PDFX_1.4.1.0_x64__sbe4t8mqwq93a [2024-07-10] (NG PDF Lab) [Startup Task]
                      Windows App Studio Installer -> C:\Program Files\WindowsApps\Microsoft.WindowsAppStudioInstaller_1.0.18.0_x86__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
                      ==================== Custom CLSID (Whitelisted): ==============
                      ShellIconOverlayIdentifiers: [ OneDrive1] -> {BBACC218-34EA-4666-9D7A-C78F2274A524} => -> No File
                      ShellIconOverlayIdentifiers: [ OneDrive2] -> {5AB7172C-9C11-405C-8DD5-AF20F3606282} => -> No File
                      ShellIconOverlayIdentifiers: [ OneDrive3] -> {A78ED123-AB77-406B-9962-2A5D9D2F7F30} => -> No File
                      ShellIconOverlayIdentifiers: [ OneDrive4] -> {F241C880-6982-4CE5-8CF7-7085BA96DA5A} => -> No File
                      ShellIconOverlayIdentifiers: [ OneDrive5] -> {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E} => -> No File
                      ShellIconOverlayIdentifiers: [ OneDrive6] -> {9AA2F32D-362A-42D9-9328-24A483E2CCC3} => -> No File
                      ShellIconOverlayIdentifiers: [ OneDrive7] -> {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => -> No File
                      ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive1] -> {BBACC218-34EA-4666-9D7A-C78F2274A524} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive2] -> {5AB7172C-9C11-405C-8DD5-AF20F3606282} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive3] -> {A78ED123-AB77-406B-9962-2A5D9D2F7F30} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive4] -> {F241C880-6982-4CE5-8CF7-7085BA96DA5A} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive5] -> {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive6] -> {9AA2F32D-362A-42D9-9328-24A483E2CCC3} => -> No File
                      ShellIconOverlayIdentifiers-x32: [ OneDrive7] -> {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => -> No File
                      ContextMenuHandlers1: [AimersoftUltimateFileOpreation] -> {8E1459F9-DF5B-42A1-9217-32EDD944778F} => -> No File
                      ContextMenuHandlers1: [AimersoftVideoConverterFileOpreation] -> {1AACB93E-AA97-47F1-BD02-8D2AF2815436} => -> No File
                      ContextMenuHandlers1: [cm_64bit] -> {69E19770-EA24-49e2-B997-405EDBEF4C05} => -> No File
                      ContextMenuHandlers1: [IObitUnstaler] -> {B19ED566-D419-470b-B111-3C89040BC027} => -> No File
                      ContextMenuHandlers1: [MagicISO] -> {DB85C504-C730-49DD-BEC1-7B39C6103B7A} => C:\Program Files (x86)\MagicISO\misosh64.dll -> No File
                      ContextMenuHandlers1: [WinRAR] -> {B41DB860-64E4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext.dll [2019-02-24] (win.rar GmbH -> Alexander Roshal)
                      ContextMenuHandlers1-x32: [WinRAR32] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext32.dll [2019-02-24] (win.rar GmbH -> Alexander Roshal)
                      ContextMenuHandlers2: [cm_64bit] -> {69E19770-EA24-49e2-B997-405EDBEF4C05} => -> No File
                      ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2023-09-02] (Malwarebytes Inc. -> Malwarebytes)
                      ContextMenuHandlers4: [cm_64bit] -> {69E19770-EA24-49e2-B997-405EDBEF4C05} => -> No File
                      ContextMenuHandlers4: [IObitUnstaler] -> {B19ED566-D419-470b-B111-3C89040BC027} => -> No File
                      ContextMenuHandlers4: [MagicISO] -> {DB85C504-C730-49DD-BEC1-7B39C6103B7A} => C:\Program Files (x86)\MagicISO\misosh64.dll -> No File
                      ContextMenuHandlers4: [PowerISO] -> {967B2D40-8B7D-4127-9049-61EA0C2C6DCE} => -> No File
                      ContextMenuHandlers5: [ACE] -> {5E2121EE-0300-11D4-8D3B-444553540000} => C:\Program Files\AMD\CNext\CNext\atiacm64.dll [2022-11-30] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
                      ContextMenuHandlers5: [Gadgets] -> {6B9228DA-9C15-419e-856C-19E768A13BDC} => -> No File
                      ContextMenuHandlers6: [Fast Explorer] -> {693BE9C0-BEC3-11D2-B4C1-C33BBD3AD64B} => -> No File
                      ContextMenuHandlers6: [IObitUnstaler] -> {B19ED566-D419-470b-B111-3C89040BC027} => -> No File
                      ContextMenuHandlers6: [MagicISO] -> {DB85C504-C730-49DD-BEC1-7B39C6103B7A} => C:\Program Files (x86)\MagicISO\misosh64.dll -> No File
                      ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2023-09-02] (Malwarebytes Inc. -> Malwarebytes)
                      ContextMenuHandlers6: [PowerISO] -> {967B2D40-8B7D-4127-9049-61EA0C2C6DCE} => -> No File
                      ContextMenuHandlers6: [WinRAR] -> {B41DB860-64E4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext.dll [2019-02-24] (win.rar GmbH -> Alexander Roshal)
                      ContextMenuHandlers6-x32: [WinRAR32] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext32.dll [2019-02-24] (win.rar GmbH -> Alexander Roshal)
                      ==================== Codecs (Whitelisted) ====================
                      HKLM\...\Drivers32: [VIDC.FPS1] => C:\WINDOWS\system32\frapsv64.dll [105984 2015-09-05] (Beepa P/L) [File not signed]
                      HKLM\...\Drivers32: [VIDC.FPS1] => C:\Windows\SysWOW64\frapsvid.dll [94208 2015-09-05] (Beepa P/L) [File not signed]
                      HKLM\...\Drivers32: [vidc.XVID] => C:\Windows\SysWOW64\xvidvfw.dll [139264 2004-07-03] () [File not signed]
                      HKLM\...\Drivers32: [msacm.voxacm160] => C:\Windows\SysWOW64\vct3216.acm [82944 2003-05-22] (Voxware, Inc.) [File not signed]
                      HKLM\...\Drivers32: [msacm.scg726] => C:\Windows\SysWOW64\scg726.acm [13239 2000-03-14] (SHARP Corporation) [File not signed]
                      HKLM\...\Drivers32: [msacm.alf2cd] => C:\Windows\SysWOW64\alf2cd.acm [38912 2003-05-22] (NCT Company) [File not signed]
                      HKLM\...\Drivers32: [msacm.ac3acm] => C:\Windows\SysWOW64\AC3ACM.acm [81920 2004-02-04] (fccHandler) [File not signed]
                      HKLM\...\Drivers32: [msacm.lame] => C:\Windows\SysWOW64\lame.ax [245760 2005-08-01] () [File not signed]
                      HKLM\...\Drivers32: [vidc.dvsd] => C:\Windows\SysWOW64\mcdvd_32.dll [261632 2003-05-22] (MainConcept) [File not signed]
                      HKLM\...\Drivers32: [vidc.mpg4] => C:\Windows\SysWOW64\mpg4c32.dll [413760 2002-08-20] (Microsoft Corporation) [File not signed]
                      HKLM\...\Drivers32: [vidc.mp42] => C:\Windows\SysWOW64\mpg4c32.dll [413760 2002-08-20] (Microsoft Corporation) [File not signed]
                      HKLM\...\Drivers32: [vidc.mp43] => C:\Windows\SysWOW64\mpg4c32.dll [413760 2002-08-20] (Microsoft Corporation) [File not signed]
                      HKLM\...\Drivers32: [vidc.DIVX] => C:\Windows\SysWOW64\DivX.dll [638976 2003-05-22] (DivXNetworks, Inc.) [File not signed]
                      HKLM\...\Drivers32: [vidc.VP60] => C:\Windows\SysWOW64\vp6vfw.dll [438272 2004-12-10] (On2.com) [File not signed]
                      HKLM\...\Drivers32: [vidc.VP61] => C:\Windows\SysWOW64\vp6vfw.dll [438272 2004-12-10] (On2.com) [File not signed]
                      HKLM\...\Drivers32: [vidc.VP62] => C:\Windows\SysWOW64\vp6vfw.dll [438272 2004-12-10] (On2.com) [File not signed]
                      HKLM\...\Drivers32: [vidc.LAGS] => C:\Windows\SysWOW64\lagarith.dll [216064 2011-12-07] () [File not signed]
                      Shortcut: C:\Users\chredge\Desktop\wireless network watcher\Shortcuts\Valley Benchmark 1.0.lnk -> C:\Program Files (x86)\Unigine\Valley Benchmark 1.0\valley.bat (No File)
                      ShortcutWithArgument: C:\Users\chredge\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Chrome Apps\DBandT Helper.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome_proxy.exe (Google LLC) -> --profile-directory="Profile 2" --app-id=mpnidfjngpijmjaloelmomppgpebokim
                      ShortcutWithArgument: C:\Users\chredge\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts\9501e18d7c2ab92e\Christopher (veolia.com) - Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google LLC) -> --profile-directory="Profile 2"
                      ==================== Loaded Modules (Whitelisted) =============
                      2012-12-23 21:04 - 2012-03-26 18:12 - 000073728 ____R (Intel Corporation) [File not signed] C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.dll
                      2021-04-22 18:05 - 2021-04-22 18:05 - 000113664 _____ (Microsoft Corporation) [File not signed] C:\WINDOWS\WinSxS\amd64_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.6229_none_8a167c0b2edeae4c\ATL80.DLL
                      ==================== Alternate Data Streams (Whitelisted) ========
                      AlternateDataStreams: C:\ProgramData\Reprise:wupeogjxlctlfudivq`qsp`29hfm [0]
                      AlternateDataStreams: C:\Users\Public\AppData:CSM [472]
                      ==================== Safe Mode (Whitelisted) ==================
                      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
                      HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
                      ==================== Association (Whitelisted) =================
                      ==================== Internet Explorer (Whitelisted) ==========
                      HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = www.google.com
                      HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page =
                      HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL =
                      HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL =
                      HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
                      HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Local Page =
                      SearchScopes: HKLM-x32 -> DefaultScope value is missing
                      BHO-x32: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files (x86)\Java\jre1.8.0_162\bin\ssv.dll [2018-05-02] (Oracle America, Inc. -> Oracle Corporation)
                      BHO-x32: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files (x86)\Java\jre1.8.0_162\bin\jp2ssv.dll [2018-05-02] (Oracle America, Inc. -> Oracle Corporation)
                      ==================== Hosts content: =========================
                      2019-08-17 06:55 - 2020-02-08 17:49 - 000001088 _____ C:\WINDOWS\system32\drivers\etc\hosts
                      127.0.0.1 platform.wondershare.com
                      0.0.0.0 incoming.telemetry.mozilla.org
                      ==================== Other Areas ===========================
                      HKLM\System\CurrentControlSet\Control\Session Manager\Environment\\Path -> C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\AMD\ATI.ACE\Core-Static;C:\adb;C:\Program Files\Microsoft SQL Server\110\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\110\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\PrivateAssemblies\;C:\Program Files (x86)\Microsoft SQL Server\110\DTS\Binn\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\ProgramData\chocolatey\bin;;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\Control Panel\Desktop\\Wallpaper -> C:\Users\chredge\Desktop\microsoft_nostalgic_windows_wallpaper_4k.jpg
                      HKU\S-1-5-80-1770670200-1234090253-3451813168-4041049723-2370973757\Control Panel\Desktop\\Wallpaper ->
                      HKU\S-1-5-80-2872255330-672591203-888807865-2791174282-1554802921\Control Panel\Desktop\\Wallpaper ->
                      HKU\S-1-5-80-2885764129-887777008-271615777-1616004480-2722851051\Control Panel\Desktop\\Wallpaper ->
                      HKU\S-1-5-80-3263513310-3392720605-1798839546-683002060-3227631582\Control Panel\Desktop\\Wallpaper ->
                      HKU\S-1-5-80-3880718306-3832830129-1677859214-2598158968-1052248003\Control Panel\Desktop\\Wallpaper ->
                      DNS Servers: 194.168.4.100 - 194.168.8.100
                      HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Microsoft\Windows\CurrentVersion\AppHost => (EnableWebContentEvaluation: 0)
                      HKLM\software\microsoft\Windows\CurrentVersion\Telephony\Providers => ProviderFileName2 -> ndptsp.tsp (No File)
                      Windows Firewall is enabled.
                      MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^HP Button Manager.lnk => C:\Windows\pss\HP Button Manager.lnk.CommonStartup
                      MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^What's my computer doing.lnk => C:\Windows\pss\What's my computer doing.lnk.CommonStartup
                      MSCONFIG\startupreg: AdobeAAMUpdater-1.0 => "C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe"
                      MSCONFIG\startupreg: Chromium => "c:\users\chredge\appdata\local\chromium\application\chrome.exe" --auto-launch-at-startup --profile-directory="Default" --restore-last-session
                      MSCONFIG\startupreg: MicrosoftEdgeAutoLaunch_3B3BB905A374F1CF0D310AB30E4EDE63 => "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start
                      MSCONFIG\startupreg: SwitchBoard => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
                      HKLM\...\StartupApproved\StartupFolder: => "Watch.lnk"
                      HKLM\...\StartupApproved\StartupFolder: => "What's my computer doing.lnk"
                      HKLM\...\StartupApproved\Run: => "SecurityHealth"
                      HKLM\...\StartupApproved\Run: => "SamsungRapidApp"
                      HKLM\...\StartupApproved\Run: => "AdobeAAMUpdater-1.0"
                      HKLM\...\StartupApproved\Run: => "Logitech Download Assistant"
                      HKLM\...\StartupApproved\Run: => "RtsCM"
                      HKLM\...\StartupApproved\Run32: => "cmsc"
                      HKLM\...\StartupApproved\Run32: => "AdobeCS5.5ServiceManager"
                      HKLM\...\StartupApproved\Run32: => "AdobeCS6ServiceManager"
                      HKLM\...\StartupApproved\Run32: => "CanonQuickMenu"
                      HKLM\...\StartupApproved\Run32: => "LogMeIn Hamachi Ui"
                      HKLM\...\StartupApproved\Run32: => "SwitchBoard"
                      HKLM\...\StartupApproved\Run32: => "IObit Malware Fighter"
                      HKLM\...\StartupApproved\Run32: => "Dropbox"
                      HKLM\...\StartupApproved\Run32: => "PlaysTV"
                      HKLM\...\StartupApproved\Run32: => "AdobeAAMUpdater-1.0"
                      HKLM\...\StartupApproved\Run32: => "RtsCM"
                      HKLM\...\StartupApproved\Run32: => "Wondershare Helper Compact.exe"
                      HKLM\...\StartupApproved\Run32: => "Adobe ARM"
                      HKLM\...\StartupApproved\Run32: => "Fitbit Connect"
                      HKLM\...\StartupApproved\Run32: => "Redirector"
                      HKLM\...\StartupApproved\Run32: => "ConnectionCenter"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\StartupFolder: => "Citrix Receiver.lnk"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "OneDrive"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "appnhost"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "CCleaner Monitoring"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "TomTomHOME.exe"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "AdobeBridge"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "uTorrent"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "Chromium"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "AceStream"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "EpicGamesLauncher"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "CCleaner Smart Cleaning"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "Fitbit Connect"
                      HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "vidnotifier.exe"
                      ==================== FirewallRules (Whitelisted) ================
                      FirewallRules: [UDP Query User{DAA5DB73-4052-479F-B0A6-24FB388378F1}C:\program files (x86)\steam\steamapps\common\deep rock galactic\fsd\binaries\win64\fsd-win64-shipping.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\deep rock galactic\fsd\binaries\win64\fsd-win64-shipping.exe => No File
                      FirewallRules: [TCP Query User{12BCA495-6C92-4E63-80D9-C87A62B12EFA}C:\program files (x86)\steam\steamapps\common\deep rock galactic\fsd\binaries\win64\fsd-win64-shipping.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\deep rock galactic\fsd\binaries\win64\fsd-win64-shipping.exe => No File
                      FirewallRules: [UDP Query User{C32E4855-1C39-4A73-B459-1357CA8A3AAF}C:\program files (x86)\call of duty modern warfare\modernwarfare.exe] => (Allow) C:\program files (x86)\call of duty modern warfare\modernwarfare.exe => No File
                      FirewallRules: [TCP Query User{FF8E08C0-7683-4AF0-9E0B-2E939E6522DB}C:\program files (x86)\call of duty modern warfare\modernwarfare.exe] => (Allow) C:\program files (x86)\call of duty modern warfare\modernwarfare.exe => No File
                      FirewallRules: [{A5A387CE-60A9-47D2-858F-FF5F5A867BF2}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve Corp. -> Valve Corporation)
                      FirewallRules: [{B45FFF36-8BD2-4088-8EFF-E2A1267ECC52}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7x64\steamwebhelper.exe (Valve Corp. -> Valve Corporation)
                      FirewallRules: [UDP Query User{78016A53-190B-440B-BBBC-1F5EA3A62B31}C:\program files (x86)\qtracker\qtracker.exe] => (Allow) C:\program files (x86)\qtracker\qtracker.exe (Ronald E. Mercer) [File not signed]
                      FirewallRules: [TCP Query User{6CB6F6C2-9ACE-4CD0-AFED-7747D071EE74}C:\program files (x86)\qtracker\qtracker.exe] => (Allow) C:\program files (x86)\qtracker\qtracker.exe (Ronald E. Mercer) [File not signed]
                      FirewallRules: [UDP Query User{7AB173E6-26C0-4BCB-8386-6ED42715A83A}C:\users\chredge\desktop\openarena-0.8.8\openarena.exe] => (Allow) C:\users\chredge\desktop\openarena-0.8.8\openarena.exe () [File not signed]
                      FirewallRules: [TCP Query User{998595D1-4A45-478A-A1EB-4365F00808A8}C:\users\chredge\desktop\openarena-0.8.8\openarena.exe] => (Allow) C:\users\chredge\desktop\openarena-0.8.8\openarena.exe () [File not signed]
                      FirewallRules: [{06CA678B-033C-4D2D-AE0C-A2C131D34B41}] => (Allow) C:\Users\chredge\AppData\Roaming\ACEStream\engine\ace_engine.exe (INNOVATIVE DIGITAL TECHNOLOGIES LLC -> Innovative Digital Technologies)
                      FirewallRules: [{1E9AF00C-F14A-4529-BA16-F017CE7521FC}] => (Allow) C:\Users\chredge\AppData\Roaming\ACEStream\engine\ace_engine.exe (INNOVATIVE DIGITAL TECHNOLOGIES LLC -> Innovative Digital Technologies)
                      FirewallRules: [{F16C9550-FF25-43F6-B2E3-C326A56E530C}] => (Allow) C:\Windows\SysWOW64\muzapp.exe (Musiccity Co.Ltd.) [File not signed]
                      FirewallRules: [{C07C0AFA-25DA-4F18-A225-342B944FF738}] => (Allow) C:\Windows\SysWOW64\muzapp.exe (Musiccity Co.Ltd.) [File not signed]
                      FirewallRules: [UDP Query User{8AE40270-3EDD-4124-840E-5E16F6BC1FB7}C:\program files (x86)\steam\steamapps\common\grand theft auto v\gta5.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\grand theft auto v\gta5.exe => No File
                      FirewallRules: [TCP Query User{20F52FCE-1081-4A54-ACA5-6BF775FF692F}C:\program files (x86)\steam\steamapps\common\grand theft auto v\gta5.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\grand theft auto v\gta5.exe => No File
                      FirewallRules: [{AE945C2B-C7E9-48B4-970F-25F90844E287}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\Grand Theft Auto V\GTAVLauncher.exe => No File
                      FirewallRules: [{37600027-4102-4872-BDD2-9AC184482607}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\Grand Theft Auto V\GTAVLauncher.exe => No File
                      FirewallRules: [UDP Query User{C28774B5-C54C-4FB4-8D87-5B5126F8200C}C:\windows\microsoft.net\framework\v2.0.50727\vbc.exe] => (Block) C:\windows\microsoft.net\framework\v2.0.50727\vbc.exe (Microsoft Corporation -> Microsoft Corporation)
                      FirewallRules: [TCP Query User{089CEDDF-E4CB-4DD2-A91C-4F1C6938F286}C:\windows\microsoft.net\framework\v2.0.50727\vbc.exe] => (Block) C:\windows\microsoft.net\framework\v2.0.50727\vbc.exe (Microsoft Corporation -> Microsoft Corporation)
                      FirewallRules: [{23F73AC9-43A7-4903-9AAB-1AD8064A7BBA}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe (Valve Corp. -> Valve Corporation)
                      FirewallRules: [{0808F055-1FE7-4613-B994-2AC6B0E421F3}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe (Valve Corp. -> Valve Corporation)
                      FirewallRules: [TCP Query User{9791AB8D-A287-44A1-998E-E81FD126C583}C:\program files (x86)\bitlord\bitlord.exe] => (Block) C:\program files (x86)\bitlord\bitlord.exe (House of Life) [File not signed]
                      FirewallRules: [UDP Query User{DEC71C29-B12B-40F2-80CD-473FDCEF153B}C:\program files (x86)\bitlord\bitlord.exe] => (Block) C:\program files (x86)\bitlord\bitlord.exe (House of Life) [File not signed]
                      FirewallRules: [TCP Query User{668F70CF-F4D7-4F7E-8668-1169392C5391}C:\program files (x86)\epic games\launcher\engine\binaries\win64\epicwebhelper.exe] => (Block) C:\program files (x86)\epic games\launcher\engine\binaries\win64\epicwebhelper.exe (Epic Games Inc. -> Epic Games, Inc.)
                      FirewallRules: [UDP Query User{65B945B7-5306-4657-8950-8BB42B08B16B}C:\program files (x86)\epic games\launcher\engine\binaries\win64\epicwebhelper.exe] => (Block) C:\program files (x86)\epic games\launcher\engine\binaries\win64\epicwebhelper.exe (Epic Games Inc. -> Epic Games, Inc.)
                      FirewallRules: [{7EA52A89-72DE-42EF-AF1B-88D88B25A151}] => (Allow) C:\Users\chredge\AppData\Local\Mozilla Firefox\firefox.exe => No File
                      FirewallRules: [{2E8B619A-CF34-4020-A5AD-12B7236A8243}] => (Allow) C:\Program Files\WindowsApps\DuckDuckGo.DesktopBrowser_0.56.1.0_x64__ya2fgkz3nks94\WindowsBrowser\WebView2\msedgewebview2.exe (Duck Duck Go, Inc. -> Microsoft Corporation)
                      FirewallRules: [{3621FAFB-8E8B-453D-99B4-C9FD2627AE7A}] => (Allow) C:\Program Files\WindowsApps\DuckDuckGo.DesktopBrowser_0.56.1.0_x64__ya2fgkz3nks94\WindowsBrowser\WebView2\msedgewebview2.exe (Duck Duck Go, Inc. -> Microsoft Corporation)
                      FirewallRules: [{C382FDEC-E3F5-4317-88B4-1601038892BD}] => (Allow) C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
                      FirewallRules: [TCP Query User{CB0AB420-C938-4AED-83E8-9651C1B7B756}C:\program files\mozilla firefox\firefox.exe] => (Block) C:\program files\mozilla firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
                      FirewallRules: [UDP Query User{130B8B32-2EBC-41A9-8D46-EA29A2044F40}C:\program files\mozilla firefox\firefox.exe] => (Block) C:\program files\mozilla firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
                      FirewallRules: [{9D6C8437-0FA7-4AD6-8835-56AB6D836242}] => (Allow) C:\Program Files (x86)\Microsoft\EdgeWebView\Application\126.0.2592.102\msedgewebview2.exe (Microsoft Corporation -> Microsoft Corporation)
                      FirewallRules: [{64738077-F7F5-430E-9AB4-3CB8C2DB3FA1}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google LLC -> Google LLC)
                      29-06-2024 18:59:21 Scheduled Checkpoint
                      09-07-2024 06:44:53 Scheduled Checkpoint
                      ==================== Faulty Device Manager Devices ============
                      ==================== Event log errors: ========================
                      Application errors:
                      Error: (07/17/2024 05:14:35 PM) (Source: Report Server Windows Service (MSSQLSERVER)) (EventID: 107) (User: )
                      Description: Report Server Windows Service (MSSQLSERVER) cannot connect to the report server database.
                      Error: (07/17/2024 05:14:35 PM) (Source: Report Server Windows Service (MSSQLSERVER)) (EventID: 113) (User: )
                      Description: The report server cannot create the Cache Flushes/Sec performance counter.
                      Description: The report server cannot create the Total Cache Flushes performance counter.
                      Description: The report server cannot create the Snapshot Updates/Sec performance counter.
                      Description: The report server cannot create the Total Snapshot Updates performance counter.
                      Description: The report server cannot create the Events/Sec performance counter.
                      Description: The report server cannot create the Total Events performance counter.
                      Description: The report server cannot create the Delivers/Sec performance counter.
                      System errors:
                      Error: (07/17/2024 05:13:57 PM) (Source: SNMP) (EventID: 1500) (User: )
                      Description: The SNMP Service encountered an error while accessing the registry key SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration.
                      Error: (07/17/2024 05:13:54 PM) (Source: EventLog) (EventID: 6008) (User: )
                      Description: The previous system shutdown at 7:48:15 AM on ‎7/‎17/‎2024 was unexpected.
                      Error: (07/17/2024 06:23:29 AM) (Source: SNMP) (EventID: 1500) (User: )
                      Error: (07/16/2024 10:49:28 PM) (Source: SNMP) (EventID: 1500) (User: )
                      Error: (07/16/2024 07:33:16 PM) (Source: SNMP) (EventID: 1500) (User: )
                      Error: (07/16/2024 06:56:57 AM) (Source: SNMP) (EventID: 1500) (User: )
                      Error: (07/16/2024 06:55:10 AM) (Source: SNMP) (EventID: 1500) (User: )
                      Error: (07/15/2024 10:34:56 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
                      Description: The MsDtsServer110 service failed to start due to the following error:
                      The service did not respond to the start or control request in a timely fashion.
                      Windows Defender:
                      Date: 2024-07-16 22:08:07
                      Description:
                      Microsoft Defender Antivirus scan has been stopped before completion.
                      Scan Type: Antimalware
                      Scan Parameters: Quick Scan
                      Date: 2024-07-15 22:08:23
                      Description:
                      Date: 2024-07-15 06:51:24
                      Description:
                      Date: 2024-07-11 22:17:15
                      Description:
                      Date: 2024-07-11 22:12:45
                      Description:
                      Event[0]:
                      Date: 2023-09-19 08:03:47
                      Description:
                      Microsoft Defender Antivirus has encountered an error trying to update security intelligence.
                      New security intelligence Version:
                      Previous security intelligence Version: 1.397.1208.0
                      Update Source: Microsoft Update Server
                      Security intelligence Type: AntiVirus
                      Update Type: Full
                      Current Engine Version:
                      Previous Engine Version: 1.1.23080.2005
                      Error code: 0x80240438
                      Error description: An unexpected problem occurred while checking for updates. For information on installing or troubleshooting updates, see Help and Support.
                      CodeIntegrity:
                      Date: 2024-07-17 17:17:17
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume1\Windows\System32\svchost.exe) attempted to load \Device\HarddiskVolume1\Program Files\Malwarebytes\Anti-Malware\mbamsi64.dll that did not meet the Windows signing level requirements.
                      Date: 2024-07-17 06:23:57
                      Description:
                      Code Integrity determined that a process (\Device\HarddiskVolume1\Windows\System32\SIHClient.exe) attempted to load \Device\HarddiskVolume1\Program Files\Malwarebytes\Anti-Malware\mbamsi64.dll that did not meet the Windows signing level requirements.
                      BIOS: American Megatrends Inc. V2.4 06/19/2012
                      Motherboard: MSI Z77A-G41 (MS-7758)
                      Processor: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
                      Percentage of memory in use: 25%
                      Total physical RAM: 16332.88 MB
                      Available physical RAM: 12125.09 MB
                      Total Virtual: 32716.88 MB
                      Available Virtual: 27209.26 MB
                      Drive c: () (Fixed) (Total:465.26 GB) (Free:226.26 GB) (Model: Samsung SSD 850 EVO 500GB) NTFS ==>[drive with boot components (obtained from BCD)]
                      Drive f: (Storage1) (Fixed) (Total:465.75 GB) (Free:218.52 GB) (Model: Hitachi HDT721050SLA360) NTFS
                      \\?\Volume{03a9c944-0000-0000-0000-c05074000000}\ () (Fixed) (Total:0.5 GB) (Free:0.07 GB) NTFS
                      ==================== MBR & Partition Table ====================
                      Disk: 0 (MBR Code: Windows 7/8/10) (Size: 465.8 GB) (Disk ID: 03A9C944)
                      Partition 1: (Active) - (Size=465.3 GB) - (Type=07 NTFS)
                      Partition 2: (Not Active) - (Size=511 MB) - (Type=27)
                      Disk: 1 (MBR Code: Windows 7/8/10) (Size: 465.8 GB) (Disk ID: 658D658D)
                      Partition 1: (Active) - (Size=465.8 GB) - (Type=07 NTFS)
                      ==================== End of Addition.txt =======================
                      Here is the addition.txt log:
                      Boot Mode: Normal
                      Packages:
                      Application errors:
                      System errors:
                      Windows Defender:
                      Description:
                      Description:
                      Description:
                      Description:
                      Description:
                      Event[0]:
                      Description:
                      Update Type: Full
                      CodeIntegrity:
                      Description:
                      Description:
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #12
                        Uninstall the following with GeekUninstaller.
                        Java 8 Update 161
                        Copy the content of the code box below.
                        [COLOR=rgb(184, 49, 47)]Do not copy the word code!!!
                        Right Click FRST and run as Administrator.
                        Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
                        Attach it to your next message.
                        Code:
                        start::
                        SystemRestore: On
                        CreateRestorePoint:
                        EmptyTemp:
                        CloseProcesses:
                        EmptyEventLogs:
                        Hosts:
                        CMD: dism /online /cleanup-image /restorehealth
                        CMD: sfc /scannow
                        RemoveProxy:
                        CMD: del /s /q C:\Windows\SoftwareDistribution\download\*.*
                        CMD: del /s /q "%userprofile%\AppData\Local\temp\*.*"
                        C:\Windows\Temp\*.*
                        C:\WINDOWS\system32\*.tmp
                        C:\WINDOWS\syswow64\*.tmp
                        emptytemp:
                        Reboot:
                        End::
                        Adware Cleaner
                        [li]Download AdwCleaner and save it to your Desktop[/li][li]Right-click on AdwCleaner.exeand select, Run as Administrator[/li][li]Accept the EULA (I accept), then click on Scan Now[/li][li]Let the scan complete[/li][li]Once the scan completes, make sure that every item listed in the different tabs is checked and click on the Quarantine and delete.[/li][li]Once the cleaning process is complete, AdwCleaner will ask you to restart your computer[/li][li]Close all other open windows and allow it to restart[/li][li]After the restart, Notepad will open with the AdwCleaner cleaning log[/li][li]Please Attach the contents of that log into your next reply to me[/li][/ul]
                        It seems you posted the Addition.txt log twice, which is fine please run the fix provided then run the Adware cleaner, post both results.
                        [COLOR=rgb(184, 49, 47)]Then re run FRST and make sure you post FRST and Addition.txt logs. [/COLOR][/COLOR]
                        • Ginger-Overlord
                          • Jul 2024
                          • 61
                          #13
                          Hi,
                          I followed your instructions, here is my fixlog.txt:
                          [HEADING=1]Fix result of Farbar Recovery Scan Tool (x64) Version: 16.07.2024
                          Ran by chredge (18-07-2024 06:51:32) Run:1
                          Running from C:\Users\chredge\Desktop
                          Loaded Profiles: chredge & MsDtsServer110 & MSSQLServerOLAPService & ReportServer & MSSQLFDLauncher & MSSQLSERVER
                          Boot Mode: Normal[/HEADING]
                          fixlist content:
                          Code:
                          start::
                          SystemRestore: On
                          CreateRestorePoint:
                          EmptyTemp:
                          CloseProcesses:
                          EmptyEventLogs:
                          ShellIconOverlayIdentifiers: [ OneDrive1] → {BBACC218-34EA-4666-9D7A-C78F2274A524} => → No File
                          ShellIconOverlayIdentifiers: [ OneDrive2] → {5AB7172C-9C11-405C-8DD5-AF20F3606282} => → No File
                          ShellIconOverlayIdentifiers: [ OneDrive3] → {A78ED123-AB77-406B-9962-2A5D9D2F7F30} => → No File
                          ShellIconOverlayIdentifiers: [ OneDrive4] → {F241C880-6982-4CE5-8CF7-7085BA96DA5A} => → No File
                          ShellIconOverlayIdentifiers: [ OneDrive5] → {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E} => → No File
                          ShellIconOverlayIdentifiers: [ OneDrive6] → {9AA2F32D-362A-42D9-9328-24A483E2CCC3} => → No File
                          ShellIconOverlayIdentifiers: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
                          ShellIconOverlayIdentifiers: [00asw] → {472083B0-C522-11CF-8763-00608CC02F24} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive1] → {BBACC218-34EA-4666-9D7A-C78F2274A524} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive2] → {5AB7172C-9C11-405C-8DD5-AF20F3606282} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive3] → {A78ED123-AB77-406B-9962-2A5D9D2F7F30} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive4] → {F241C880-6982-4CE5-8CF7-7085BA96DA5A} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive5] → {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive6] → {9AA2F32D-362A-42D9-9328-24A483E2CCC3} => → No File
                          ShellIconOverlayIdentifiers-x32: [ OneDrive7] → {C5FF006E-2AE9-408C-B85B-2DFDD5449D9C} => → No File
                          ContextMenuHandlers1: [AimersoftUltimateFileOpreation] → {8E1459F9-DF5B-42A1-9217-32EDD944778F} => → No File
                          ContextMenuHandlers1: [AimersoftVideoConverterFileOpreation] → {1AACB93E-AA97-47F1-BD02-8D2AF2815436} => → No File
                          ContextMenuHandlers1: [cm_64bit] → {69E19770-EA24-49e2-B997-405EDBEF4C05} => → No File
                          ContextMenuHandlers1: [IObitUnstaler] → {B19ED566-D419-470b-B111-3C89040BC027} => → No File
                          ContextMenuHandlers1: [MagicISO] → {DB85C504-C730-49DD-BEC1-7B39C6103B7A} => C:\Program Files (x86)\MagicISO\misosh64.dll → No File
                          ContextMenuHandlers2: [cm_64bit] → {69E19770-EA24-49e2-B997-405EDBEF4C05} => → No File
                          ContextMenuHandlers4: [cm_64bit] → {69E19770-EA24-49e2-B997-405EDBEF4C05} => → No File
                          ContextMenuHandlers4: [IObitUnstaler] → {B19ED566-D419-470b-B111-3C89040BC027} => → No File
                          ContextMenuHandlers4: [MagicISO] → {DB85C504-C730-49DD-BEC1-7B39C6103B7A} => C:\Program Files (x86)\MagicISO\misosh64.dll → No File
                          ContextMenuHandlers4: [PowerISO] → {967B2D40-8B7D-4127-9049-61EA0C2C6DCE} => → No File
                          ContextMenuHandlers5: [Gadgets] → {6B9228DA-9C15-419e-856C-19E768A13BDC} => → No File
                          ContextMenuHandlers6: [Fast Explorer] → {693BE9C0-BEC3-11D2-B4C1-C33BBD3AD64B} => → No File
                          ContextMenuHandlers6: [IObitUnstaler] → {B19ED566-D419-470b-B111-3C89040BC027} => → No File
                          ContextMenuHandlers6: [MagicISO] → {DB85C504-C730-49DD-BEC1-7B39C6103B7A} => C:\Program Files (x86)\MagicISO\misosh64.dll → No File
                          ContextMenuHandlers6: [PowerISO] → {967B2D40-8B7D-4127-9049-61EA0C2C6DCE} => → No File
                          Shortcut: C:\Users\chredge\Desktop\wireless network watcher\Shortcuts\Valley Benchmark 1.0.lnk → C:\Program Files (x86)\Unigine\Valley Benchmark 1.0\valley.bat (No File)
                          HKLM\software\microsoft\Windows\CurrentVersion\Telephony\Providers => ProviderFileName2 → ndptsp.tsp (No File)
                          AlternateDataStreams: C:\ProgramData\Reprise:wupeogjxlctlfudivq[ICODE]qsp[/ICODE]29hfm [0]
                          Hosts:
                          CMD: sfc /scannow
                          RemoveProxy:
                          CMD: del /s /q C:\Windows\SoftwareDistribution\download*.*
                          CMD: del /s /q "%userprofile%\AppData\Local\temp*."
                          C:\Windows\Temp*.
                          C:\WINDOWS\system32*.tmp
                          C:\WINDOWS\syswow64*.tmp
                          emptytemp:
                          Reboot:
                          End::
                          [HR][/HR]
                          HKLM\SOFTWARE\Policies\Microsoft\Windows NT\SystemRestore => removed successfully
                          SystemRestore: On => completed
                          =========== EmptyEventLogs: ==========
                          1205 Event logs cleared.
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive1 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive2 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive3 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive4 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive5 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive6 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive7 => removed successfully
                          HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\00asw => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive1 => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive2 => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive3 => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive4 => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive5 => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive6 => removed successfully
                          HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\ShellIconOverlayIdentifiers\ OneDrive7 => removed successfully
                          HKLM\Software\Classes*\ShellEx\ContextMenuHandlers\AimersoftUltimateFileOpreation => removed successfully
                          HKLM\Software\Classes*\ShellEx\ContextMenuHandlers\AimersoftVideoConverterFileOpreation => removed successfully
                          HKLM\Software\Classes*\ShellEx\ContextMenuHandlers\cm_64bit => removed successfully
                          HKLM\Software\Classes\CLSID{69E19770-EA24-49e2-B997-405EDBEF4C05} => removed successfully
                          HKLM\Software\Classes*\ShellEx\ContextMenuHandlers\IObitUnstaler => removed successfully
                          HKLM\Software\Classes*\ShellEx\ContextMenuHandlers\MagicISO => removed successfully
                          HKLM\Software\Classes\CLSID{DB85C504-C730-49DD-BEC1-7B39C6103B7A} => removed successfully
                          HKLM\Software\Classes\Drive\ShellEx\ContextMenuHandlers\cm_64bit => removed successfully
                          HKLM\Software\Classes\Directory\ShellEx\ContextMenuHandlers\cm_64bit => removed successfully
                          HKLM\Software\Classes\Directory\ShellEx\ContextMenuHandlers\IObitUnstaler => removed successfully
                          HKLM\Software\Classes\Directory\ShellEx\ContextMenuHandlers\MagicISO => removed successfully
                          HKLM\Software\Classes\Directory\ShellEx\ContextMenuHandlers\PowerISO => removed successfully
                          HKLM\Software\Classes\Directory\Background\ShellEx\ContextMenuHandlers\Gadgets => removed successfully
                          HKLM\Software\Classes\Folder\ShellEx\ContextMenuHandlers\Fast Explorer => removed successfully
                          HKLM\Software\Classes\Folder\ShellEx\ContextMenuHandlers\IObitUnstaler => removed successfully
                          HKLM\Software\Classes\Folder\ShellEx\ContextMenuHandlers\MagicISO => removed successfully
                          HKLM\Software\Classes\Folder\ShellEx\ContextMenuHandlers\PowerISO => removed successfully
                          C:\Users\chredge\Desktop\wireless network watcher\Shortcuts\Valley Benchmark 1.0.lnk => moved successfully
                          HKLM\software\microsoft\Windows\CurrentVersion\Telephony\Providers => ProviderFileName2 → ndptsp.tsp (No File) => Error: No automatic fix found for this entry.
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\UDP Query User{DAA5DB73-4052-479F-B0A6-24FB388378F1}C:\program files (x86)\steam\steamapps\common\deep rock galactic\fsd\binaries\win64\fsd-win64-shipping.exe” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\TCP Query User{12BCA495-6C92-4E63-80D9-C87A62B12EFA}C:\program files (x86)\steam\steamapps\common\deep rock galactic\fsd\binaries\win64\fsd-win64-shipping.exe” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\UDP Query User{C32E4855-1C39-4A73-B459-1357CA8A3AAF}C:\program files (x86)\call of duty modern warfare\modernwarfare.exe” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\TCP Query User{FF8E08C0-7683-4AF0-9E0B-2E939E6522DB}C:\program files (x86)\call of duty modern warfare\modernwarfare.exe” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\UDP Query User{8AE40270-3EDD-4124-840E-5E16F6BC1FB7}C:\program files (x86)\steam\steamapps\common\grand theft auto v\gta5.exe” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\TCP Query User{20F52FCE-1081-4A54-ACA5-6BF775FF692F}C:\program files (x86)\steam\steamapps\common\grand theft auto v\gta5.exe” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\{AE945C2B-C7E9-48B4-970F-25F90844E287}” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\{37600027-4102-4872-BDD2-9AC184482607}” => removed successfully
                          “HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\{7EA52A89-72DE-42EF-AF1B-88D88B25A151}” => removed successfully
                          C:\ProgramData\Reprise => “:wupeogjxlctlfudivq[ICODE]qsp[/ICODE]29hfm” ADS removed successfully
                          C:\Users\Public\AppData => “:CSM” ADS removed successfully
                          C:\WINDOWS\system32\drivers\etc\hosts => moved successfully
                          Hosts restored successfully.
                          ========= dism /online /cleanup-image /restorehealth =========
                          Deployment Image Servicing and Management tool
                          Version: 10.0.19041.3636
                          Image Version: 10.0.19045.4651
                          [== 3.8% ]
                          [== 4.3% ]
                          [=== 5.3% ]
                          [=== 6.2% ]
                          [=== 6.7% ]
                          [==== 7.7% ]
                          [===== 8.7% ]
                          [===== 9.4% ]
                          [===== 10.2% ]
                          [====== 10.6% ]
                          [====== 11.5% ]
                          [======= 12.5% ]
                          [======= 13.4% ]
                          [======== 14.0% ]
                          [======== 14.3% ]
                          [======== 15.2% ]
                          [========= 16.2% ]
                          [========= 17.2% ]
                          [========== 18.0% ]
                          [=========== 19.0% ]
                          [=========== 19.6% ]
                          [=========== 20.4% ]
                          [============ 21.4% ]
                          [============ 22.1% ]
                          [============ 22.3% ]
                          [============= 22.4% ]
                          [============= 22.5% ]
                          [============= 22.6% ]
                          [============= 22.9% ]
                          [============= 23.9% ]
                          [============== 24.9% ]
                          [=============== 25.9% ]
                          [=============== 26.6% ]
                          [=============== 27.5% ]
                          [================ 28.5% ]
                          [================ 29.1% ]
                          [================ 29.2% ]
                          [================= 29.6% ]
                          [================= 29.8% ]
                          [================= 30.1% ]
                          [================= 30.2% ]
                          [================= 30.9% ]
                          [================== 31.8% ]
                          [=================== 32.8% ]
                          [=================== 33.7% ]
                          [==================== 34.6% ]
                          [==================== 35.2% ]
                          [==================== 36.2% ]
                          [===================== 37.1% ]
                          [===================== 37.4% ]
                          [====================== 38.4% ]
                          [====================== 38.6% ]
                          [====================== 39.1% ]
                          [======================= 40.0% ]
                          [======================= 40.2% ]
                          [======================= 40.5% ]
                          [======================= 40.6% ]
                          [======================= 40.9% ]
                          [======================= 41.1% ]
                          [======================== 41.4% ]
                          [======================== 41.6% ]
                          [======================== 42.0% ]
                          [======================== 42.4% ]
                          [======================== 42.6% ]
                          [======================== 42.7% ]
                          [======================== 42.9% ]
                          [======================== 43.1% ]
                          [========================= 43.5% ]
                          [========================= 43.8% ]
                          [========================= 44.0% ]
                          [========================= 44.1% ]
                          [========================= 44.2% ]
                          [========================= 44.4% ]
                          [========================= 44.5% ]
                          [========================= 44.7% ]
                          [========================= 44.8% ]
                          [========================== 44.8% ]
                          [========================== 45.7% ]
                          [===========================46.6% ]
                          [===========================47.6% ]
                          [===========================48.6% ]
                          [===========================49.6% ]
                          [===========================50.6% ]
                          [===========================51.5% ]
                          [===========================52.5% ]
                          [===========================53.3% ]
                          [===========================53.5% ]
                          [===========================53.6% ]
                          [===========================53.7% ]
                          [===========================53.8% ]
                          [===========================53.9% ]
                          [===========================54.0% ]
                          [===========================54.1% ]
                          [===========================54.2% ]
                          [===========================54.3% ]
                          [===========================54.4% ]
                          [===========================54.5% ]
                          [===========================54.6% ]
                          [===========================54.7% ]
                          [===========================54.8% ]
                          [===========================54.9% ]
                          [===========================55.8% ]
                          [===========================56.1% ]
                          [===========================56.4% ]
                          [===========================56.5% ]
                          [===========================57.1%= ]
                          [===========================58.0%= ]
                          [===========================59.0%== ]
                          [===========================60.0%== ]
                          [===========================62.3%==== ]
                          [===========================84.9%================= ]
                          [==========================100.0%==========================]
                          The restore operation completed successfully.
                          The operation completed successfully.
                          ========= sfc /scannow =========
                          Beginning system scan. This process will take some time.
                          Beginning verification phase of system scan.
                          Verification 0% complete.
                          Verification 1% complete.
                          Verification 2% complete.
                          Verification 3% complete.
                          Verification 4% complete.
                          Verification 5% complete.
                          Verification 6% complete.
                          Verification 7% complete.
                          Verification 8% complete.
                          Verification 9% complete.
                          Verification 10% complete.
                          Verification 11% complete.
                          Verification 12% complete.
                          Verification 13% complete.
                          Verification 14% complete.
                          Verification 15% complete.
                          Verification 16% complete.
                          Verification 17% complete.
                          Verification 18% complete.
                          Verification 19% complete.
                          Verification 20% complete.
                          Verification 21% complete.
                          Verification 22% complete.
                          Verification 23% complete.
                          Verification 24% complete.
                          Verification 25% complete.
                          Verification 26% complete.
                          Verification 27% complete.
                          Verification 28% complete.
                          Verification 29% complete.
                          Verification 30% complete.
                          Verification 31% complete.
                          Verification 32% complete.
                          Verification 33% complete.
                          Verification 34% complete.
                          Verification 35% complete.
                          Verification 36% complete.
                          Verification 37% complete.
                          Verification 38% complete.
                          Verification 39% complete.
                          Verification 40% complete.
                          Verification 41% complete.
                          Verification 42% complete.
                          Verification 43% complete.
                          Verification 44% complete.
                          Verification 45% complete.
                          Verification 46% complete.
                          Verification 47% complete.
                          Verification 48% complete.
                          Verification 49% complete.
                          Verification 50% complete.
                          Verification 51% complete.
                          Verification 52% complete.
                          Verification 53% complete.
                          Verification 54% complete.
                          Verification 55% complete.
                          Verification 56% complete.
                          Verification 57% complete.
                          Verification 58% complete.
                          Verification 59% complete.
                          Verification 60% complete.
                          Verification 61% complete.
                          Verification 62% complete.
                          Verification 63% complete.
                          Verification 64% complete.
                          Verification 65% complete.
                          Verification 66% complete.
                          Verification 67% complete.
                          Verification 68% complete.
                          Verification 69% complete.
                          Verification 70% complete.
                          Verification 71% complete.
                          Verification 72% complete.
                          Verification 73% complete.
                          Verification 74% complete.
                          Verification 75% complete.
                          Verification 76% complete.
                          Verification 77% complete.
                          Verification 78% complete.
                          Verification 79% complete.
                          Verification 80% complete.
                          Verification 81% complete.
                          Verification 82% complete.
                          Verification 83% complete.
                          Verification 84% complete.
                          Verification 85% complete.
                          Verification 86% complete.
                          Verification 87% complete.
                          Verification 88% complete.
                          Verification 89% complete.
                          Verification 90% complete.
                          Verification 91% complete.
                          Verification 92% complete.
                          Verification 93% complete.
                          Verification 94% complete.
                          Verification 95% complete.
                          Verification 96% complete.
                          Verification 97% complete.
                          Verification 98% complete.
                          Verification 99% complete.
                          Verification 100% complete.
                          Windows Resource Protection did not find any integrity violations.
                          HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer => removed successfully
                          HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Policies\Microsoft\Internet Explorer => removed successfully
                          “HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\DefaultConnectionSettings” => removed successfully
                          “HKU.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\SavedLegacySettings” => removed successfully
                          “HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\DefaultConnectionSettings” => removed successfully
                          “HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\SavedLegacySettings” => removed successfully
                          ========= del /s /q C:\Windows\SoftwareDistribution\download*.* =========
                          Deleted file - C:\Windows\SoftwareDistribution\download\05e506ada11ad5bcafe9a0ad11e341112c2ef267
                          Deleted file - C:\Windows\SoftwareDistribution\download\80896f4c1a4e8dd71e7cd9ebcbec1a30f2761f8c
                          Deleted file - C:\Windows\SoftwareDistribution\download\a6257623e091e5fe6c3d8e71effd4a8fa6f180f9
                          Deleted file - C:\Windows\SoftwareDistribution\download\b76cb1c0fc9e3604407557c8781099e4ac61f863
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\7270ec06-f01f-4cda-8db5-a29207141a43.AggregatedMetadata.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\ActionList.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\DesktopDeployment.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\PFL_Package_for_ServicingStack_4585amd6419041.4585.1.2.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\SSU-19041.4585-x64-express.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\windlp.state-old.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\windlp.state.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Windows10.0-KB5040427-x64.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\7270ec06-f01f-4cda-8db5-a29207141a43.AggregatedMetadata.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ar-sa.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ar-sa.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_bg-bg.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_bg-bg.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ca-es.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ca-es.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_cs-cz.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_cs-cz.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_da-dk.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_da-dk.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_de-de.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_de-de.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_el-gr.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_el-gr.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_en-gb.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_en-gb.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_en-us.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_en-us.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_es-es.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_es-es.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_es-mx.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_es-mx.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_et-ee.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_et-ee.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_fi-fi.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_fi-fi.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_fr-ca.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_fr-ca.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_fr-fr.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_fr-fr.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_he-il.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_he-il.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_hr-hr.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_hr-hr.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_hu-hu.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_hu-hu.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_id-id.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_id-id.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_it-it.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_it-it.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ja-jp.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ja-jp.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ko-kr.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ko-kr.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_lt-lt.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_lt-lt.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_lv-lv.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_lv-lv.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_nb-no.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_nb-no.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_Neutral.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_Neutral.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_nl-nl.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_nl-nl.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_pl-pl.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_pl-pl.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_pt-br.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_pt-br.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_pt-pt.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_pt-pt.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ro-ro.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ro-ro.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ru-ru.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_ru-ru.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sk-sk.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sk-sk.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sl-si.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sl-si.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sr-latn-rs.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sr-latn-rs.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sv-se.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_sv-se.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_th-th.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_th-th.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_tr-tr.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_tr-tr.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_uk-ua.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_uk-ua.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_vi-vn.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_vi-vn.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_zh-cn.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_zh-cn.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_zh-tw.CompDB.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopBaselessCompDB_zh-tw.CompDB.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ar-sa.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ar-sa.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_bg-bg.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_bg-bg.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ca-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ca-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_corecountryspecific_zh-cn.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_corecountryspecific_zh-cn.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_bg-bg.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_bg-bg.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_cs-cz.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_cs-cz.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_da-dk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_da-dk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_de-de.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_de-de.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_el-gr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_el-gr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_en-gb.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_en-gb.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_en-us.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_en-us.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_es-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_es-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_et-ee.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_et-ee.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_fi-fi.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_fi-fi.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_fr-fr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_fr-fr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_hr-hr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_hr-hr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_hu-hu.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_hu-hu.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_it-it.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_it-it.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_lt-lt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_lt-lt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_lv-lv.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_lv-lv.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_nb-no.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_nb-no.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_nl-nl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_nl-nl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_pl-pl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_pl-pl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_pt-pt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_pt-pt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_ro-ro.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_ro-ro.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_sk-sk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_sk-sk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_sl-si.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_sl-si.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_sv-se.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_coren_sv-se.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ar-sa.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ar-sa.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_bg-bg.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_bg-bg.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_cs-cz.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_cs-cz.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_da-dk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_da-dk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_de-de.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_de-de.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_el-gr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_el-gr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_en-gb.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_en-gb.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_en-us.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_en-us.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_es-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_es-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_es-mx.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_es-mx.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_et-ee.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_et-ee.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_fi-fi.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_fi-fi.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_fr-ca.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_fr-ca.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_fr-fr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_fr-fr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_he-il.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_he-il.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_hr-hr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_hr-hr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_hu-hu.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_hu-hu.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_it-it.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_it-it.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ja-jp.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ja-jp.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ko-kr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ko-kr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_lt-lt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_lt-lt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_lv-lv.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_lv-lv.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_nb-no.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_nb-no.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_nl-nl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_nl-nl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_pl-pl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_pl-pl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_pt-br.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_pt-br.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_pt-pt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_pt-pt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ro-ro.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ro-ro.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ru-ru.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_ru-ru.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sk-sk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sk-sk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sl-si.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sl-si.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sr-latn-rs.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sr-latn-rs.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sv-se.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_sv-se.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_th-th.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_th-th.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_tr-tr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_tr-tr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_uk-ua.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_uk-ua.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_zh-cn.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_zh-cn.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_zh-tw.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_core_zh-tw.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_cs-cz.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_cs-cz.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_da-dk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_da-dk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_de-de.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_de-de.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_el-gr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_el-gr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_en-gb.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_en-gb.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_en-us.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_en-us.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_es-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_es-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_es-mx.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_es-mx.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_et-ee.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_et-ee.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_fi-fi.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_fi-fi.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_fr-ca.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_fr-ca.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_fr-fr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_fr-fr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_he-il.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_he-il.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_hr-hr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_hr-hr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_hu-hu.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_hu-hu.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_id-id.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_id-id.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_it-it.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_it-it.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ja-jp.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ja-jp.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ko-kr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ko-kr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_lt-lt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_lt-lt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_lv-lv.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_lv-lv.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_nb-no.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_nb-no.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_Neutral.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_Neutral.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_nl-nl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_nl-nl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_pl-pl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_pl-pl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ar-sa.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ar-sa.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_bg-bg.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_bg-bg.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_cs-cz.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_cs-cz.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_da-dk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_da-dk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_de-de.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_de-de.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_el-gr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_el-gr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_en-gb.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_en-gb.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_en-us.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_en-us.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_es-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_es-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_es-mx.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_es-mx.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_et-ee.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_et-ee.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_fi-fi.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_fi-fi.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_fr-ca.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_fr-ca.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_fr-fr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_fr-fr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_he-il.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_he-il.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_hr-hr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_hr-hr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_hu-hu.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_hu-hu.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_it-it.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_it-it.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ja-jp.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ja-jp.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ko-kr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ko-kr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_lt-lt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_lt-lt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_lv-lv.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_lv-lv.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_nb-no.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_nb-no.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_nl-nl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_nl-nl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_pl-pl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_pl-pl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_pt-br.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_pt-br.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_pt-pt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_pt-pt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ro-ro.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ro-ro.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ru-ru.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_ru-ru.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sk-sk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sk-sk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sl-si.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sl-si.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sr-latn-rs.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sr-latn-rs.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sv-se.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_sv-se.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_th-th.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_th-th.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_tr-tr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_tr-tr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_uk-ua.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_uk-ua.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_zh-cn.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_zh-cn.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_zh-tw.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_PPIPro_zh-tw.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_bg-bg.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_bg-bg.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_cs-cz.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_cs-cz.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_da-dk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_da-dk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_de-de.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_de-de.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_el-gr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_el-gr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_en-gb.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_en-gb.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_en-us.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_en-us.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_es-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_es-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_et-ee.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_et-ee.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_fi-fi.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_fi-fi.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_fr-fr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_fr-fr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_hr-hr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_hr-hr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_hu-hu.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_hu-hu.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_it-it.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_it-it.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_lt-lt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_lt-lt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_lv-lv.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_lv-lv.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_nb-no.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_nb-no.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_nl-nl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_nl-nl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_pl-pl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_pl-pl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_pt-pt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_pt-pt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_ro-ro.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_ro-ro.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_sk-sk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_sk-sk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_sl-si.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_sl-si.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_sv-se.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professionaln_sv-se.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ar-sa.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ar-sa.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_bg-bg.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_bg-bg.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_cs-cz.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_cs-cz.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_da-dk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_da-dk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_de-de.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_de-de.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_el-gr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_el-gr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_en-gb.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_en-gb.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_en-us.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_en-us.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_es-es.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_es-es.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_es-mx.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_es-mx.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_et-ee.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_et-ee.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_fi-fi.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_fi-fi.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_fr-ca.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_fr-ca.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_fr-fr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_fr-fr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_he-il.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_he-il.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_hr-hr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_hr-hr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_hu-hu.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_hu-hu.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_it-it.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_it-it.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ja-jp.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ja-jp.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ko-kr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ko-kr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_lt-lt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_lt-lt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_lv-lv.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_lv-lv.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_nb-no.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_nb-no.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_nl-nl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_nl-nl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_pl-pl.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_pl-pl.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_pt-br.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_pt-br.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_pt-pt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_pt-pt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ro-ro.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ro-ro.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ru-ru.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_ru-ru.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sk-sk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sk-sk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sl-si.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sl-si.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sr-latn-rs.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sr-latn-rs.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sv-se.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_sv-se.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_th-th.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_th-th.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_tr-tr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_tr-tr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_uk-ua.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_uk-ua.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_zh-cn.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_zh-cn.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_zh-tw.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_professional_zh-tw.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_pt-br.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_pt-br.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_pt-pt.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_pt-pt.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ro-ro.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ro-ro.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ru-ru.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_ru-ru.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sk-sk.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sk-sk.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sl-si.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sl-si.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sr-latn-rs.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sr-latn-rs.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sv-se.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_sv-se.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_th-th.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_th-th.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_tr-tr.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_tr-tr.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_uk-ua.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_uk-ua.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_vi-vn.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_vi-vn.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_zh-cn.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_zh-cn.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_zh-tw.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetCompDB_zh-tw.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetServicedCompdb_Neutral.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DesktopTargetServicedCompDB_Neutral.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\DeviceInventory.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\dpx.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\EKBUpdateCompDB_KB5015684.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\EKBUpdateCompDB_KB5015684.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\LCUCompDB_KB5040427.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\LCUCompDB_KB5040427.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\Mitigation.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\ReserveManager.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSUCompDB_KB5039336-express.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSUCompDB_KB5039336-express.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSUCompDB_KB5039336.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSUCompDB_KB5039336.xml.cab
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\TurboStack.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\UAOneSettings.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\UpdateAgent.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\wcp.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\WinREAgent.dll
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\amd64_deployment-6e710f5b..a0ddce01dfe91b4d1c4_31bf3856ad364e35_10.0.19041.4585_none_d14b9a8b2022e4a1.manifest
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\amd64_deployment-c995b4d9..c0f4133a83c9316fe2a_31bf3856ad364e35_10.0.19041.4585_none_2be5d8b9e79ec253.manifest
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Shared-185F83B20D6B70B86A59D81CF0B716A308823E956A7ECEEB3EFE2617DD25F703~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Shared-185F83B20D6B70B86A59D81CF0B716A308823E956A7ECEEB3EFE2617DD25F703~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\update.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\update.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-03237BD85903D35BEE99025D016BEC9729848B441607CCDBAD75374EC925CA66~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-03237BD85903D35BEE99025D016BEC9729848B441607CCDBAD75374EC925CA66~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-0ECD5FCB48035C59A4004D3F9E83B9D81B8D92CC684A25472E0F3D5C0204700C~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-0ECD5FCB48035C59A4004D3F9E83B9D81B8D92CC684A25472E0F3D5C0204700C~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-35BED1F27996D69A07B2764DB2F96E6BC8A2D97FF139F210DAC5AD62C6C61A99~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-35BED1F27996D69A07B2764DB2F96E6BC8A2D97FF139F210DAC5AD62C6C61A99~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-40A5907B3EDA6BD19A23EF06ECC79557CB04C2945ACA5B0C325BEB4990D44CE3~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-40A5907B3EDA6BD19A23EF06ECC79557CB04C2945ACA5B0C325BEB4990D44CE3~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-5B5EF33E1C1081A0A5EE725F135E0197EA2C6C5C654FE7AAB30CA3BC37184B63~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-5B5EF33E1C1081A0A5EE725F135E0197EA2C6C5C654FE7AAB30CA3BC37184B63~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-5BEA7455C5B5EABCCFFA9ADDDEFD61314222F745E919FF0BF4AD1C6AC919DF97~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-5BEA7455C5B5EABCCFFA9ADDDEFD61314222F745E919FF0BF4AD1C6AC919DF97~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-75831BA46CCC1EAD5BFA608606747C50868DAF03B0331FFDF0BC5A2B53B79138~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-75831BA46CCC1EAD5BFA608606747C50868DAF03B0331FFDF0BC5A2B53B79138~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-7680662BBB81F24597E56ECCEA9296FCC506F6225CFB85C4C220D9E2EED58066~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-7680662BBB81F24597E56ECCEA9296FCC506F6225CFB85C4C220D9E2EED58066~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-BC9388B846B0E9227FBEFD012ED7A83C41337BAFEC58D1A598B5EDC0A6C74F84~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-BC9388B846B0E9227FBEFD012ED7A83C41337BAFEC58D1A598B5EDC0A6C74F84~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-CBF43811570827466A2F7DE337A6F385EB07D6F0BD1BC30307F3791BB69FFC8C~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-CBF43811570827466A2F7DE337A6F385EB07D6F0BD1BC30307F3791BB69FFC8C~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-E0217EEF40F15C7F1296154B8B5C5F5A03F23E690708BD8EAC6AE25052B11743~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-E0217EEF40F15C7F1296154B8B5C5F5A03F23E690708BD8EAC6AE25052B11743~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-E031DC733D02E725E7C0B32DB752BA9EB54153E84E8E748E468291C30C7E8B98~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-E031DC733D02E725E7C0B32DB752BA9EB54153E84E8E748E468291C30C7E8B98~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-E6476B8CD9BF068AD34897BA9561C8D16359443813EF1ED1680F9312D30B9BEF~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-E6476B8CD9BF068AD34897BA9561C8D16359443813EF1ED1680F9312D30B9BEF~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-F7E661B1C3F0416899DDEA2E0CB8C8AE38373543091E3DEC4561BA0538CC3265~31bf3856ad364e35~amd6410.0.19041.4585.cat
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Metadata\SSU-19041.4585-x64-express\Wrapper-F7E661B1C3F0416899DDEA2E0CB8C8AE38373543091E3DEC4561BA0538CC3265~31bf3856ad364e35~amd6410.0.19041.4585.mum
                          Deleted file - C:\Windows\SoftwareDistribution\download\866c81dc840d55ae287b958b3a21c75e\Package_for_ServicingStack_4585amd6419041.4585.1.2$dpx$.tmp\job.xml
                          Deleted file - C:\Windows\SoftwareDistribution\download\Install\AM_Delta_Patch_1.415.147.0.exe
                          Deleted file - C:\Windows\SoftwareDistribution\download\SharedFileCache\3800574bf055ef770d10e7999b3ea0eca0a69cc8f55966c23d890213df0c80a9
                          Deleted file - C:\Windows\SoftwareDistribution\download\SharedFileCache\e4dd67bb7574a5ed326fd8c0391dfd41c0c43e90c8eef190a71233ec93c91e35
                          ========= del /s /q “%userprofile%\AppData\Local\temp*.*” =========
                          Deleted file - C:\Users\chredge\AppData\Local\temp\01b49a34-41e8-47ed-a730-81560346d184.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\099ab9ae-463e-40b0-8a05-a5e38b9d96ff.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\3b09e5ac-6359-4002-8899-65b8a51176e0.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\4f4cd874-da5d-4495-8868-7275c24168df.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\51e25bca-e722-43eb-87b1-5f4e3be8eed1.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\5c63c48a-9a1b-4f24-aaa5-e25276d48105.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\61a56f4b-d954-4c3d-9843-91f13b09af2c.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\61a60803-637a-42fe-8e19-7080c72e0080.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\69c94b4d-91e4-4082-881d-7b23cfb89399.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\7c94cf8b-48bf-4cf9-99fd-1358b5de0d5f.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\83806501-362b-401f-a7dc-06a627d1a7e9.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\8b9c10f1-84a1-4818-a91f-a13e9698e339.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\9c7b8667-ac0f-4458-ac90-6ef114ee6eb3.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\9fcb6aac-6057-431f-b924-cfefa6a8761e.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\a18a8545-8819-4568-9946-d3c461ce6f3e.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\a4789566-3ba3-4096-a9ac-628a964dfeaa.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\a57be303-82a1-4fea-8cc3-1ca25cc7b330.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\a9db30f2-48c9-43ad-81e0-929d776a2d92.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\a9dd848d-043e-4156-a286-93b511941506.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\a9e80e82-7d2c-4cfe-814a-4b82c0afdc0e.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\adc47a8f-130a-4ae9-8678-42289f30b319.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\adfde31b-fba0-4096-b995-fb0a40289ace.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\af71f96d-9f84-44fd-a792-44ffbf851abb.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\AMDLinkDriverUpdate.xml
                          Deleted file - C:\Users\chredge\AppData\Local\temp\bc14cc8e-ec51-45b6-98cf-b4bb3db816cc.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\c06f47af-4b8d-4269-a33c-acba4b95b55c.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\ca8b22d2-db59-4ab4-aee4-b3c9515b14e5.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\ccbf9333-07c6-4b60-80a4-0c39eba0cf15.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\cv_debug.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\d0e459bb-791f-4c07-8a58-c426fa170ce3.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\e537fdbb-cd83-42ac-ab28-c8261f0f2bf1.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\e6b3fc5a-748e-4c48-9b22-5e93353e6bd6.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\e717e58e-11ca-4239-8bd0-b3e5bf738e2b.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\f335266d-6fae-4ecf-b543-df80326f1f94.tmp
                          Deleted file - C:\Users\chredge\AppData\Local\temp\geek64.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\GetSystemInfoServiceLog.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\JavaDeployReg.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\jusched.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\AppxProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\AssocProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\CbsProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\DismCore.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\DismCorePS.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\DismHost.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\DismProv.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\DmiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\FfuProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\FolderProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\GenericProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\IBSProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\ImagingProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\IntlProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\LogProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\MsiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\OfflineSetupProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\OSProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\ProvProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\SetupPlatformProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\SmiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\SysprepProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\TransmogProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\UnattendProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\VhdProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\WimProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\AppxProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\AssocProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\CbsProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\DismCore.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\DismProv.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\DmiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\FfuProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\FolderProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\GenericProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\IBSProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\ImagingProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\IntlProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\LogProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\MsiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\OfflineSetupProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\OSProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\ProvProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\SetupPlatformProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\SmiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\SysprepProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\TransmogProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\UnattendProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\VhdProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0ACA1C75-F504-4B48-9B78-25120FF9FA71\en-US\WimProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\AppxProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\AssocProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\CbsProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\DismCore.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\DismCorePS.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\DismHost.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\DismProv.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\DmiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\FfuProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\FolderProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\GenericProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\IBSProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\ImagingProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\IntlProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\LogProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\MsiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\OfflineSetupProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\OSProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\ProvProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\SetupPlatformProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\SmiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\SysprepProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\TransmogProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\UnattendProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\VhdProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\WimProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\AppxProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\AssocProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\CbsProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\DismCore.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\DismProv.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\DmiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\FfuProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\FolderProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\GenericProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\IBSProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\ImagingProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\IntlProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\LogProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\MsiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\OfflineSetupProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\OSProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\ProvProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\SetupPlatformProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\SmiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\SysprepProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\TransmogProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\UnattendProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\VhdProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\0C705611-6F1D-4DD2-966D-5D7F4A21705E\en-US\WimProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\AppxProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\AssocProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\CbsProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\DismCore.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\DismCorePS.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\DismHost.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\DismProv.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\DmiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\FfuProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\FolderProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\GenericProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\IBSProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\ImagingProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\IntlProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\LogProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\MsiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\OfflineSetupProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\OSProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\ProvProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\SetupPlatformProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\SmiProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\SysprepProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\TransmogProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\UnattendProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\VhdProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\WimProvider.dll
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\AppxProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\AssocProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\CbsProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\DismCore.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\DismProv.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\DmiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\FfuProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\FolderProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\GenericProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\IBSProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\ImagingProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\IntlProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\LogProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\MsiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\OfflineSetupProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\OSProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\ProvProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\SetupPlatformProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\SmiProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\SysprepProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\TransmogProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\UnattendProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\VhdProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\20336660-9452-40AB-B69F-4B7D83860BDC\en-US\WimProvider.dll.mui
                          Deleted file - C:\Users\chredge\AppData\Local\temp\5941B725-1F07-47D4-9E3F-80AC227F7C4D\DismHost.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\CCD5E1BC-F7EF-44C5-9E7C-62354E46D8AD\DismHost.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_1016_2024_07_15_06_41_11.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_1172_2024_07_15_22_25_30.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_1256_2024_07_17_06_30_37.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_1484_2024_07_12_07_02_12.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_1660_2024_07_11_06_50_21.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_3844_2024_07_14_06_42_15.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_3988_2024_07_13_05_59_19.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_4024_2024_07_16_20_56_27.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_4836_2024_07_17_07_49_31.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_4936_2024_07_15_22_34_25.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_5276_2024_07_15_09_16_13.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_5604_2024_07_15_09_56_58.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_5604_2024_07_15_13_06_54.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6308_2024_07_13_11_22_30.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6380_2024_07_11_21_24_56.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6536_2024_07_14_12_27_54.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6668_2024_07_15_14_08_40.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6692_2024_07_15_14_49_06.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6872_2024_07_18_06_28_13.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_6992_2024_07_13_13_37_20.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_7012_2024_07_17_17_14_14.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\InstallManagerApp\AMDInstallManagerApp_7080_2024_07_16_06_57_28.log
                          Deleted file - C:\Users\chredge\AppData\Local\temp\Rar$EXa5356.548\geek.exe
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00000
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00001
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00002
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00003
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00004
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00005
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00006
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00007
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00008
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00009
                          Deleted file - C:\Users\chredge\AppData\Local\temp\WindowsUpdateLog\wuetl.CSV.tmp.00010
                          Deleted file - C:\Users\chredge\AppData\Local\temp~nsuA.tmp\Un_A.exe
                          =========== “C:\Windows\Temp*.*” ==========
                          C:\Windows\Temp.ses => moved successfully
                          C:\Windows\Temp\bb3a785178f443fda931098a5a9a306b.db.ses => moved successfully
                          C:\Windows\Temp\chrome_installer.log => moved successfully
                          C:\Windows\Temp\FXSAPIDebugLogFile.txt => moved successfully
                          C:\Windows\Temp\FXSTIFFDebugLogFile.txt => moved successfully
                          C:\Windows\Temp\mb_errors999.log => moved successfully
                          C:\Windows\Temp\MpCmdRun.log => moved successfully
                          C:\Windows\Temp\MpSigStub.log => moved successfully
                          C:\Windows\Temp\msedge_installer.log => moved successfully
                          ========= End → “C:\Windows\Temp*.*” ========
                          =========== “C:\WINDOWS\system32*.tmp” ==========
                          not found
                          ========= End → “C:\WINDOWS\system32*.tmp” ========
                          =========== “C:\WINDOWS\syswow64*.tmp” ==========
                          not found
                          ========= End → “C:\WINDOWS\syswow64*.tmp” ========
                          FlushDNS => completed
                          BITS transfer queue => 1310720 B
                          DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 102673041 B
                          Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 953066998 B
                          Windows/system/drivers => 0 B
                          Edge => 0 B
                          Chrome => 1546198851 B
                          Firefox => 1178390550 B
                          Opera => 0 B
                          Default => 12800 B
                          ProgramData => 12800 B
                          Public => 12800 B
                          systemprofile => 12800 B
                          systemprofile32 => 12800 B
                          LocalService => 18328 B
                          NetworkService => 97888 B
                          chredge => 4221153 B
                          MsDtsServer110 => 4233953 B
                          MSSQLServerOLAPService => 4246753 B
                          ReportServer => 4259553 B
                          MSSQLFDLauncher => 4272353 B
                          MSSQLSERVER => 4285153 B
                          DefaultAppPool.IIS APPPOOL => 4297953 B
                          RecycleBin => 177160 B
                          EmptyTemp: => 3.6 GB temporary data Removed.
                          The system needed a reboot.
                          ==== End of Fixlog 07:00:55 ====
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #14
                            @Ginger-Overlord Only having the addition.txt log from your machine really leaves a lot on the table…
                            Ok. adware cleaner log then fresh FRST and Addition.txt logs.
                            • Ginger-Overlord
                              • Jul 2024
                              • 61
                              #15
                              Hi Malnutrition,
                              Can only run this when I get in from work tonight. Is the adware cleaner log created via FRST?
                              Cheers for your help.
