Solved Yellow light on motherboard for dram AND cpu.
Mr. Rosy
46
24
My brand new PC build with only new components shows a yellow dram and CPU light when turned on. when first turned on the CPU light is on, then after a few seconds it switches to dram. I've tried reseating the RAM in different slots, reseating the CPU, unplugging and replugging power cables, using the reset switch, and I fear it could be because of a faulty component. Any ideas on what I should do?
Sorry but you have post on a tech forum asking for help but have provided zero information about your computer or it`s hardware, this makes it impossible for anyone to even hazard a guess as to what is going on.
First and foremost, have these parts ever worked or is this a new build.
To be able to help you we will need you to post the brand and model name or number for the CPU, MB, the RAM ( including the amount, number of sticks and speed ) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better help you.
Sorry, I am new to PC building. No, none of the components for my PC have ever worked, and I haven't been able to boot it up yet. When I plug it into my monitor with HDMI, it says that my device doesn't have a signal. As for the parts, I am using an Intel Core i9-13900KF, a Gigabyte Z790 Aorus Elite AX ATX LGA1700 motherboard, Corsair Vengeance 32 GB (2 x 16 GB) RAM, a RTX 4070 Founders Edition, and a be quiet! Dark Power 13 850W Titanium Certifed power supply. As for chipset drivers, I have not even been able to add Windows 10, because I haven't been able to get the PC to send a signal to my monitor.
In addition to the above;
Have you checked that the screen is connected to the add on GPU and not a video port on the MB, this is a very common mistake.
2x PCIe 8-pin cables (adapter in box) OR 300 W or greater PCIe Gen 5 cable.
Certain manufacturer models may use 1x PCIe 8-pin cable.
Have you checked that the GPU power connections correspond to one of the above.
What are you using for a screen, a dedicated computer screen or a TV.
Do you have a keyboard connected.
Yes, my screen is connected to my GPU HDMI port, and my GPU is using the supplied 2x PCIe 8-pin cable adapter. I am using a dedicated Dell 27 monitor, but i did not attempt to connect my keyboard yet. Does my PC need to be connected to a keyboard in order to connect properly? I didn't attempt to connect it yet because I'm under the impression that it wouldn't affect my PC's ability to send an HDMI signal, and I needed to get that resolved first so that I could actually use the keyboard. As for my RAM's speed, it is 5600 MT/s.
I"m very sorry, I don"t seem to understand. Are you saying that my RAM is not compatible with my MB? I'm not incredibly well versed in technical terms, sorry.
My RAM is DDR5, but as for grounding I'm now concerned I didn't ground myself properly. I never noticed a discharge, I kept my PC completely unplugged, the surfaces I was on were all hard, non-static surfaces, and I kept all my hardware in bags until I was ready to use it. However, I did not wear any anti-static wrist straps or use any matting, so I worry that I might have damaged something. Is there a way to tell if a component is damaged?
Yes, when first turned on the motherboard will usually show the CPU light, and then it will switch over to dram. After staying on dram for a while, it will flash back to CPU for a few seconds before going back to dram.
Ok ddr5 5 5600 is ok.
Power off.
Remove ram
insert 1 stick only into slot A2
Power on
Because you cannot get bios to tell the version.
MIGHT have to flash the bios
This shows a2
