Wireless headset audio + mic problem
MihaiMalos
23
Hi, i have a Sony WH-CH500 headset and i got a little problem there. I hear the sound very well when i'm not using the headset's mic, but when i enter in a discord channel the audio freeze and just the microphone is working, but the audio is still working, but i can't hear it. And it shows a pictogram that says discord is using the mic
No, it is on every app that use my microphone. On my phone it's working properly, but on windows not
so when you pair the headphones into your smartphone, audio and mic work fine.
but paired to your PC and the audio stops once the mic is used - is that all correct?
what is the PC device?
is the headset only bluetooth connection?
what versions of bluetooth do both devices run?
