Windows 7 freezing up after changing power supply.
jayncc1701
8
48
Ok hold on, this will take a bit to explain but Id appreciate any advice...
I changed out my sons power supply in his pc. I removed a 600w evga and installed a 750w evga.
I changed it out because once in a while when it would boot windows it would just lose power, plus the power supply was about 4 years old. So I switched it out(ive done this a hundred times before with no problems).
I went to boot windows 10 and it took a little longer then normal but then started up. I then noticed that whenever I would start up a program or a game or would download something, windows would get real slow, and sometimes it would even freeze up to where the task manager wouldnt even come up.
So this is all ive tried to fix the issues:
I went into bio and reset all settings to default settings for the motherboard.
I formatted the HD and did a reinstall of windows 7. It got through the install with no problems. Once in a while during updates it would freeze up. And then when I tried to install programs and run them, the same issue. Slowed down or froze up all together.
I have another HD, so I formatted it and installed Windows on it, same problem.
I put the old power supply back in, same problem. Then I did a reinstall of windows with that power supply, same problem.
I have ran every disk scan, repair program available to windows with no help. I have defragged and ran registry health checks with no results.
Some specs(mind you, all of this was working just fine before the first switch of the power supply.)
Sorry, I should have added that the temps have been good the entire time.
FX-8300 processor
Asus M5a78L mother board
PNY 1060 graphics card(but for all the windows reinstalls, we just ran graphics off the mobo)
EVGA 750 watt power supply
Any advice would be great! Thanks!
Hi jayncc1701 and welcome to PCHF :)
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Ran by jake (administrator) on 20-05-2017 at 15:26:34
Running from "C:\Users\jake\Downloads"
Microsoft Windows 7 Home Premium Service Pack 1 (X64)
Model: System Product Name Manufacturer: System manufacturer
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Realtek PCIe GBE Family Controller = Local Area Connection (Connected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : jake-PC
Physical Address. . . . . . . . . : 30-5A-3A-0E-13-75
Link-local IPv6 Address . . . . . : fe80::e9ba:e496:beb5:9a4%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.240(Preferred)
Lease
Ran by jake (administrator) on 20-05-2017 at 17:20:45
Boot Mode: Normal
reset
popd
Lease Obtained. . . . . . . . . . : Saturday, May 20, 2017 5:14:53 PM
Lease Expires . . . . . . . . . . : Sunday, May 21, 2017 5:14:52 PM
DHCPv6 IAID . . . . . . . . . . . : 238049850
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-AD-5F-39-30-5A-3A-0E-13-75
Tunnel adapter isatap.{806DEBDF-F565-4224-A07B-74429A2F43B7}:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:3418:1aa9:5d05:29e2(Preferred)
Link-local IPv6 Address . . . . . : fe80::3418:1aa9:5d05:29e2%12(Preferred)
Default Gateway . . . . . . . . . : ::
Server: router.asus.com
Address: 192.168.1.1
Addresses: 2607:f8b0:4009:803::200e
4.59.40.108
4.59.40.123
4.59.40.103
4.59.40.114
4.59.40.89
4.59.40.118
4.59.40.119
4.59.40.109
4.59.40.88
4.59.40.99
4.59.40.93
4.59.40.84
4.59.40.104
4.59.40.94
4.59.40.113
4.59.40.98
Pinging google.com [4.59.40.98] with 32 bytes of data:
Reply from 4.59.40.98: bytes=32 time=4ms TTL=58
Reply from 4.59.40.98: bytes=32 time=5ms TTL=58
Ping statistics for 4.59.40.98:
Minimum = 4ms, Maximum = 5ms, Average = 4ms
Addresses: 2001:4998:58:c02::a9
2001:4998:44:204::a7
2001:4998:c:a06::2:4008
98.138.253.109
98.139.183.24
206.190.36.45
Pinging yahoo.com [206.190.36.45] with 32 bytes of data:
Reply from 206.190.36.45: bytes=32 time=65ms TTL=50
Reply from 206.190.36.45: bytes=32 time=60ms TTL=50
Ping statistics for 206.190.36.45:
Minimum = 60ms, Maximum = 65ms, Average = 62ms
Interface List
10...30 5a 3a 0e 13 75 ......Realtek PCIe GBE Family Controller
11...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
12...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.240 10
192.168.1.0 255.255.255.0 On-link 192.168.1.240 266
192.168.1.240 255.255.255.255 On-link 192.168.1.240 266
192.168.1.255 255.255.255.255 On-link 192.168.1.240 266
224.0.0.0 240.0.0.0 On-link 192.168.1.240 266
255.255.255.255 255.255.255.255 On-link 192.168.1.240 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
12 58 ::/0 On-link
1 306 ::1/128 On-link
12 58 2001::/32 On-link
12 306 2001:0:9d38:953c:3418:1aa9:5d05:29e2/128
On-link
10 266 fe80::/64 On-link
12 306 fe80::/64 On-link
12 306 fe80::3418:1aa9:5d05:29e2/128
On-link
10 266 fe80::e9ba:e496:beb5:9a4/128
On-link
1 306 ff00::/8 On-link
12 306 ff00::/8 On-link
10 266 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
Application errors:
Error: (05/19/2017 10:19:03 PM) (Source: .NET Runtime) (User: )
Description: Application: Twitch.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an internal error in the .NET Runtime at IP 7792D15B (77910000) with exit code 80131506.
Error: (05/19/2017 09:23:36 PM) (Source: MsiInstaller) (User: jake-PC)
Description: Product: Elgato Game Capture HD -- Error 1500. Another installation is in progress. You must complete that installation before continuing this one.
Error: (05/19/2017 09:21:58 PM) (Source: MsiInstaller) (User: jake-PC)
Description: Product: Elgato Game Capture HD -- This application is only supported on Windows 8 or higher.
Error: (05/19/2017 06:50:51 PM) (Source: Application Error) (User: )
Description: Faulting application name: Battle.net Helper.exe, version: 0.0.0.0, time stamp: 0x591b9deb
Faulting module name: libcef.dll, version: 3.2623.1433.0, time stamp: 0x590b8573
Exception code: 0x80000003
Fault offset: 0x0019afa9
Faulting process id: 0x165c
Faulting application start time: 0xBattle.net Helper.exe0
Faulting application path: Battle.net Helper.exe1
Faulting module path: Battle.net Helper.exe2
Report Id: Battle.net Helper.exe3
Error: (05/18/2017 06:33:23 PM) (Source: Application Error) (User: )
Description: Faulting application name: chrome.exe, version: 58.0.3029.110, time stamp: 0x59114e27
Faulting module name: ntdll.dll, version: 6.1.7601.23796, time stamp: 0x590296ce
Exception code: 0xc0000005
Fault offset: 0x00000000000181ed
Faulting process id: 0x1108
Faulting application start time: 0xchrome.exe0
Faulting application path: chrome.exe1
Faulting module path: chrome.exe2
Report Id: chrome.exe3
Error: (05/18/2017 04:32:42 PM) (Source: .NET Runtime) (User: )
Description: The process was terminated due to an internal error in the .NET Runtime at IP 73A9D15B (73A80000) with exit code 80131506.
Error: (05/18/2017 04:26:45 PM) (Source: Application Error) (User: )
Description: Faulting application name: ts3client_win64.exe, version: 3.1.2.0, time stamp: 0x58ee0528
Faulting module name: ucrtbase.DLL, version: 10.0.10586.788, time stamp: 0x5879ab76
Exception code: 0x40000015
Fault offset: 0x000000000006990f
Faulting process id: 0xa0c
Faulting application start time: 0xts3client_win64.exe0
Faulting application path: ts3client_win64.exe1
Faulting module path: ts3client_win64.exe2
Report Id: ts3client_win64.exe3
Faulting process id: 0xee8
Faulting process id: 0xcf0
System errors:
Error: (05/20/2017 05:17:05 PM) (Source: Service Control Manager) (User: )
Description: The aswbIDSAgent service failed to start due to the following error:
%%1053 = The service did not respond to the start or control request in a timely fashion.
Description: A timeout was reached (30000 milliseconds) while waiting for the aswbIDSAgent service to connect.
Error: (05/20/2017 04:08:31 PM) (Source: DCOM) (User: )
Description: {E10F6C3A-F1AE-4ADC-AA9D-2FE65525666E}
Error: (05/20/2017 03:32:08 PM) (Source: DCOM) (User: )
Error: (05/20/2017 12:55:26 PM) (Source: DCOM) (User: )
Error: (05/20/2017 12:50:20 PM) (Source: DCOM) (User: )
Description: {995C996E-D918-4A8C-A302-45719A6F4EA7}
Error: (05/20/2017 10:56:13 AM) (Source: Service Control Manager) (User: )
Error: (05/20/2017 10:53:48 AM) (Source: EventLog) (User: )
Description: The previous system shutdown at 10:52:28 AM on ‎5/‎20/‎2017 was unexpected.
Error: (05/20/2017 10:42:13 AM) (Source: Service Control Manager) (User: )
Description: A timeout (30000 milliseconds) was reached while waiting for a transaction response from the Browser service.
Microsoft Office Sessions:
Error: (05/19/2017 10:19:03 PM) (Source: .NET Runtime)(User: )
Error: (05/19/2017 09:23:36 PM) (Source: MsiInstaller)(User: jake-PC)
Description: Product: Elgato Game Capture HD -- Error 1500. Another installation is in progress. You must complete that installation before continuing this one.(NULL)(NULL)(NULL)(NULL)(NULL)
Error: (05/19/2017 09:21:58 PM) (Source: MsiInstaller)(User: jake-PC)
Description: Product: Elgato Game Capture HD -- This application is only supported on Windows 8 or higher.(NULL)(NULL)(NULL)(NULL)(NULL)
Error: (05/19/2017 06:50:51 PM) (Source: Application Error)(User: )
Description: Battle.net Helper.exe0.0.0.0591b9deblibcef.dll3.2623.1433.0590b8573800000030019afa9165c01d2d10b7f67ee55C:\Program Files (x86)\Blizzard App\Battle.net.8800\Battle.net Helper.exeC:\Program Files (x86)\Blizzard App\Battle.net.8800\libcef.dllc0a31423-3cfe-11e7-bd4b-305a3a0e1375
Error: (05/18/2017 06:33:23 PM) (Source: Application Error)(User: )
Description: chrome.exe58.0.3029.11059114e27ntdll.dll6.1.7601.23796590296cec000000500000000000181ed110801d2d03fe6354936C:\Program Files (x86)\Google\Chrome\Application\chrome.exeC:\Windows\SYSTEM32\ntdll.dll2555c481-3c33-11e7-9cb1-305a3a0e1375
Error: (05/18/2017 04:32:42 PM) (Source: .NET Runtime)(User: )
Error: (05/18/2017 04:26:45 PM) (Source: Application Error)(User: )
Description: ts3client_win64.exe3.1.2.058ee0528ucrtbase.DLL10.0.10586.7885879ab7640000015000000000006990fa0c01d2d02db561fdf5C:\Program Files\TeamSpeak 3 Client\ts3client_win64.exeC:\Windows\system32\ucrtbase.DLL74b23950-3c21-11e7-ab7b-305a3a0e1375
Description: ts3client_win64.exe3.1.2.058ee0528ucrtbase.DLL10.0.10586.7885879ab7640000015000000000006990fee801d2d02e0c1b4629C:\Program Files\TeamSpeak 3 Client\ts3client_win64.exeC:\Windows\system32\ucrtbase.DLL74b34ac4-3c21-11e7-ab7b-305a3a0e1375
Description: ts3client_win64.exe3.1.2.058ee0528ucrtbase.DLL10.0.10586.7885879ab7640000015000000000006990f165c01d2d02dfe444929C:\Program Files\TeamSpeak 3 Client\ts3client_win64.exeC:\Windows\system32\ucrtbase.DLL74b127dc-3c21-11e7-ab7b-305a3a0e1375
Description: ts3client_win64.exe3.1.2.058ee0528ucrtbase.DLL10.0.10586.7885879ab7640000015000000000006990fcf001d2d02deca1b6feC:\Program Files\TeamSpeak 3 Client\ts3client_win64.exeC:\Windows\system32\ucrtbase.DLL74b100cc-3c21-11e7-ab7b-305a3a0e1375
CodeIntegrity Errors:
Date: 2017-05-16 17:29:17.463
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\AtihdW76.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2017-05-16 17:19:48.951
Date: 2017-05-16 17:11:14.524
Date: 2017-05-16 17:08:24.446
Date: 2017-05-16 17:03:19.820
Adobe Flash Player 25 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 25.0.0.171 - Adobe Systems Incorporated)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 378.78 - NVIDIA Corporation) Hidden
Avast Free Antivirus (HKLM-x32\...\Avast Antivirus) (Version: 17.4.2294 - AVAST Software)
BitTorrent (HKCU\...\BitTorrent) (Version: 7.10.0.43581 - BitTorrent Inc.)
Blizzard App (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
CCleaner (HKLM\...\CCleaner) (Version: 5.30 - Piriform)
Defraggler (HKLM\...\Defraggler) (Version: 2.21 - Piriform)
Dual Monitor 1.22 (HKLM-x32\...\{64AA3F94-ED4A-4A4B-B72C-B7A1481ED5D8}_is1) (Version: 1.22.021813 - Cristi Diaconu)
Elgato Game Capture HD (HKLM\...\{4281A206-158E-4C28-B078-397188759F60}) (Version: 3.20.33.1533 - Elgato Systems GmbH)
Game Capture HD v2.3.3.40 (HKLM-x32\...\Software_Elgato_Game Capture HD) (Version: 2.3.3.40 - Elgato Systems)
Game Capture HD60 Pro v1.1.0.149 (HKLM-x32\...\Software_Elgato_Game Capture HD60 Pro) (Version: 1.1.0.149 - Elgato Systems)
Game Capture HD60 S v1.1.0.160 (HKLM-x32\...\Software_Elgato_Game Capture HD60 S) (Version: 1.1.0.160 - Elgato Systems)
Game Capture HD60 v2.1.1.4 (HKLM-x32\...\Software_Elgato_Game Capture HD60) (Version: 2.1.1.4 - Elgato Systems)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 58.0.3029.110 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
Microsoft .NET Framework 4.6.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32\...\{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23506 (HKLM-x32\...\{3ee5e5bb-b7cc-4556-8861-a00a82977d6c}) (Version: 14.0.23506.0 - Microsoft Corporation)
Mozilla Firefox 53.0.3 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 53.0.3 (x86 en-US)) (Version: 53.0.3 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 53.0.2 - Mozilla)
MSXML 4.0 SP3 Parser (KB2758694) (HKLM-x32\...\{1D95BA90-F4F8-47EC-A882-441C99D30C1E}) (Version: 4.30.2117.0 - Microsoft Corporation)
NVIDIA 3D Vision Driver 378.78 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 378.78 - NVIDIA Corporation)
NVIDIA Graphics Driver 378.78 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.78 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.23 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.23 - NVIDIA Corporation)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.107.323.2017 - Realtek)
SafeZone Stable 3.55.2393.596 (HKLM-x32\...\SafeZone 3.55.2393.596) (Version: 3.55.2393.596 - Avast Software) Hidden
Space Engineers (HKLM\...\Steam App 244850) (Version: - Keen Software House)
Speccy (HKLM\...\Speccy) (Version: 1.30 - Piriform)
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.1.4 - TeamSpeak Systems GmbH)
Transmission 2.92 (14714) (x64) (HKLM\...\{E2B281FA-6236-4F0D-B710-ECDB6B60EB5E}) (Version: 2.92.0 - Transmission Project)
Twitch (HKLM-x32\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 6.0.0.0 - Twitch Interactive, Inc.)
Vegas Pro 13.0 (64-bit) (HKLM\...\{D264BD11-6A9B-11E4-A4F7-F04DA23A5C58}) (Version: 13.0.428 - Sony)
Vulkan Run Time Libraries 1.0.39.1 (HKLM\...\VulkanRT1.0.39.1) (Version: 1.0.39.1 - LunarG, Inc.)
WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
Name: Universal Serial Bus (USB) Controller
Description: Universal Serial Bus (USB) Controller
Class Guid:
Manufacturer:
Service:
Device ID: PCI\VEN_1B21&DEV_1142&SUBSYS_85BF1043&REV_00\4&AB0F605&0&0038
Problem: : The drivers for this device are not installed. (Code 28)
Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
Percentage of memory in use: 15%
Total physical RAM: 16366.12 MB
Available physical RAM: 13867.59 MB
Total Virtual: 32730.42 MB
Available Virtual: 30012.5 MB
1 Drive c: () (Fixed) (Total:465.66 GB) (Free:295.65 GB) NTFS
User accounts for \\JAKE-PC
Administrator Guest jake
**** End of log ****
Thanks for the log :)
I see a lot of CodeIntegrity Errors in your log. Are you able to run chkdsk /r and post the results back?
Where and what is the system plugged into? Try a different wall socket see if that helps.
Some thing may have come loose so lets trace and re-seat the data and power cables to all the drives, CPU fan, (DO NOT remove the heat sink), RAM and any add on cards. If water cooled check the lines.
With the side off are all the fan coming on and running?
Download and run Memtester86+ for several runs and hours. The RAM may pass the first time or x time and fail the next. Usually suggest over night.
I did have it plugged into a battery back up, but when all the trouble started, I plugged it directly into the wall. And I have tried another outlet with no change. Also I did take out all the RAM sticks, gently blew out the sockets and reinstalled the sticks.
