Windows 10 cannot start, the system repair options do not work, starting from the installation disk does would not help
Qwertyn
9
57
Windows 10 cannot start, the system repair options do not work, starting from the installation disk does would not help. Recovery point was not created. What to do?
No Blue screen
Windows 10 Startup Problem
Parts:
1)
Case - Thermaltake V100 ATX Case w/500W - new
2)
HD - Seagate 8TB Barracuda SATA 256MB - new
3)
Motherboard - ASUS H170 PRO Gaming - Used from another PC in our home
4)
Processor i5-6600 - Used from another PC in our home
5)
G. SKILL VS NT D4 2666MHz 8Gx2 - new
can you get into the system BIOS?
does the Windows splash screen show?
have you tried starting into Safe Mode?
can you get into the Advanced Startup Options menu?
have you tried using a live Linux distro on a bootable USB stick?
can you identify any failed hardware components?
