MiniToolBox by Farbar Version: 13-05-2022
Ran by acco5 (administrator) on 05-11-2023 at 20:14:27
Running from "C:\Users\acco5\Desktop"
Model: ROG Strix G513IC_G513IC Manufacturer: ASUSTeK COMPUTER INC.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
"network.proxy.type", 0
127.0.0.1 localhost
MediaTek Wi-Fi 6 MT7921 Wireless LAN Card = WiFi (Connected)
Realtek PCIe GbE Family Controller = Ethernet (Media disconnected)
Speedify Virtual Adapter = Local Area Connection (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="WiFi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 12" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set subinterface interface=?o?????? subinterface=iftype53_32768 mtu=1280
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : LAPTOP-6ODOHNQP
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 04-42-1A-85-B2-3D
Unknown adapter Local Area Connection:
Description . . . . . . . . . . . : Speedify Virtual Adapter
Physical Address. . . . . . . . . : 00-FF-29-E6-92-AA
Wireless LAN adapter Local Area Connection* 1:
Physical Address. . . . . . . . . : 4A-E7-DA-53-E0-21
Wireless LAN adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3
Physical Address. . . . . . . . . : 4A-E7-DA-53-E0-31
Wireless LAN adapter WiFi:
Description . . . . . . . . . . . : MediaTek Wi-Fi 6 MT7921 Wireless LAN Card
Physical Address. . . . . . . . . : 48-E7-DA-53-E0-31
Link-local IPv6 Address . . . . . : fe80::51ba:aa4e:3551:39d7%20(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.105(Preferred)
Lease Obtained. . . . . . . . . . : 05 November 2023 20:02:50
Lease Expires . . . . . . . . . . : 06 November 2023 20:02:50
DHCPv6 IAID . . . . . . . . . . . : 340322266
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-28-A1-C3-CE-04-42-1A-85-B2-3D
192.168.1.1
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.1
Addresses: 2a00:1450:4007:81a::200e
142.250.75.238
Pinging google.com [142.250.75.238] with 32 bytes of data:
Request timed out.
Reply from 142.250.75.238: bytes=32 time=40ms TTL=112
Ping statistics for 142.250.75.238:
Packets: Sent = 2, Received = 1, Lost = 1 (50% loss),
Minimum = 40ms, Maximum = 40ms, Average = 40ms
Server: Bbox.nomad
Addresses: 2001:4998:124:1507::f001
2001:4998:124:1507::f000
2001:4998:24:120d::1:1
2001:4998:44:3507::8000
2001:4998:44:3507::8001
2001:4998:24:120d::1:0
98.137.11.164
74.6.143.25
74.6.231.20
74.6.231.21
74.6.143.26
98.137.11.163
Pinging yahoo.com [98.137.11.164] with 32 bytes of data:
Reply from 98.137.11.164: bytes=32 time=191ms TTL=46
Reply from 98.137.11.164: bytes=32 time=192ms TTL=46
Ping statistics for 98.137.11.164:
Minimum = 191ms, Maximum = 192ms, Average = 191ms
Interface List
19...04 42 1a 85 b2 3d ......Realtek PCIe GbE Family Controller
5...00 ff 29 e6 92 aa ......Speedify Virtual Adapter
29...4a e7 da 53 e0 21 ......Microsoft Wi-Fi Direct Virtual Adapter
35...4a e7 da 53 e0 31 ......Microsoft Wi-Fi Direct Virtual Adapter #3
20...48 e7 da 53 e0 31 ......MediaTek Wi-Fi 6 MT7921 Wireless LAN Card
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.105 50
192.168.1.0 255.255.255.0 On-link 192.168.1.105 306
192.168.1.105 255.255.255.255 On-link 192.168.1.105 306
192.168.1.255 255.255.255.255 On-link 192.168.1.105 306
224.0.0.0 240.0.0.0 On-link 192.168.1.105 306
255.255.255.255 255.255.255.255 On-link 192.168.1.105 306
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 331 ::1/128 On-link
20 306 fe80::/64 On-link
20 306 fe80::51ba:aa4e:3551:39d7/128
On-link
1 331 ff00::/8 On-link
20 306 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\NLAapi.dll [71168] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\winrnr.dll [34304] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [70144] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\NLAapi.dll [97280] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\winrnr.dll [49152] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 14 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
Application errors:
Error: (11/05/2023 08:01:59 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
Description: Event-ID 86
Error: (11/05/2023 08:01:21 PM) (Source: VSS) (EventID: 8193) (User: )
Description: Volume Shadow Copy Service error: Unexpected error calling routine CoCreateInstance. hr = 0x8007045b, A system shutdown is in progress.
Error: (11/05/2023 08:01:21 PM) (Source: VSS) (EventID: 13) (User: )
Description: Volume Shadow Copy Service information: The COM Server with CLSID {4e14fba2-2e22-11d1-9964-00c04fbbb345} and name CEventSystem cannot be started. [0x8007045b, A system shutdown is in progress.
Error: (11/05/2023 08:01:20 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: gameinputsvc.exe, version: 0.2210.22621.1863, time stamp: 0x90d61c52
Faulting module name: gameinputsvc.exe, version: 0.2210.22621.1863, time stamp: 0x90d61c52
Exception code: 0xc0000005
Fault offset: 0x0000000000004c9d
Faulting process ID: 0x3d0c
Faulting application start time: 0x01da101a765b0c57
Faulting application path: C:\Program Files (x86)\Microsoft GameInput\x64\gameinputsvc.exe
Faulting module path: C:\Program Files (x86)\Microsoft GameInput\x64\gameinputsvc.exe
Report ID: 6423664d-502e-495b-85b2-6ed44cf9820d
Faulting package full name:
Error: (11/05/2023 04:31:01 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
Description: Event-ID 2
Error: (11/04/2023 03:54:17 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
Error: (11/04/2023 03:54:17 PM) (Source: Firefox Default Browser Agent) (EventID: 12007) (User: )
Description: Event-ID 12007
Error: (11/04/2023 03:54:17 PM) (Source: Firefox Default Browser Agent) (EventID: 0) (User: )
Description: Event-ID 0
Error: (11/03/2023 03:40:08 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
Error: (11/02/2023 03:40:08 PM) (Source: Firefox Default Browser Agent) (EventID: 2) (User: )
System errors:
Error: (10/29/2023 05:42:01 PM) (Source: DCOM) (EventID: 10010) (User: LAPTOP-6ODOHNQP)
Description: Event-ID 10010
Error: (10/27/2023 02:38:52 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Description: Miniport Microsoft Wi-Fi Direct Virtual Adapter #3, {3453b32d-1ecc-413d-9629-4af7469e1a2f}, had event 74
Error: (10/22/2023 09:40:58 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Error: (10/22/2023 03:52:20 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Error: (10/21/2023 02:09:53 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Error: (10/19/2023 03:17:58 PM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Error: (10/16/2023 01:04:37 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Error: (10/14/2023 02:43:27 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: NT AUTHORITY)
Error: (10/12/2023 04:56:16 AM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Error: (10/09/2023 12:53:17 PM) (Source: Microsoft-Windows-NDIS) (EventID: 10317) (User: )
Windows Defender:
Date: 2023-11-05 09:43:56
Description:
Microsoft Defender Antivirus scan has been stopped before completion.
Scan Type: Antimalware
Scan Parameters: Quick Scan
Date: 2023-11-04 08:09:01
Description:
Date: 2023-11-03 04:24:00
Description:
Date: 2023-11-02 07:08:26
Description:
Date: 2023-11-01 04:44:11
Description:
Event[0]:
Date: 2023-10-25 12:42:40
Description:
Microsoft Defender Antivirus has encountered an error trying to update security intelligence.
New security intelligence Version:
Previous security intelligence Version: 1.399.1226.0
Update Source: Microsoft Malware Protection Center
Security intelligence Type: AntiVirus
Update Type: Full
Current Engine Version:
Previous Engine Version: 1.1.23090.2007
Error code: 0x80072efe
Error description: The connection with the server was terminated abnormally
Description:
Security intelligence Type: AntiSpyware
Update Type: Full
Description:
Update Type: Full
Description:
Update Type: Full
Error code: 0x80072ee2
Error description: The operation timed out
Description:
Update Type: Full
CodeIntegrity Errors:
Date: 2023-10-30 07:43:23
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.23090.2008-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2023-10-23 07:58:26
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\Program Files (x86)\Microsoft\EdgeWebView\Application\118.0.2088.46\msedgewebview2.exe) attempted to load \Device\HarddiskVolume3\Windows\System32\nvspcap64.dll that did not meet the Microsoft signing level requirements.
Date: 2023-10-04 15:31:11
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.23080.2006-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2023-08-26 14:26:50
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.23070.1004-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
Adobe Acrobat (64-bit) (HKLM\...\{AC76BA86-1033-1033-7760-BC15014EA700}) (Version: 23.006.20360 - Adobe)
AI Noise Cancelation Audio Software (HKLM-x32\...\{ab5f014e-883d-470d-bc2d-127ef91e5611}) (Version: 2.0.3 - ASUSTek Computer Inc.)
AI Noise Cancelation Audio Software SDK (HKLM\...\{9B441197-6389-46FC-BE60-56C8B6E5ADE9}) (Version: 1.0.6 - ASUSTeK COMPUTER INC.)
Amys Greenmart 2 - Crimson Island (HKLM-x32\...\Amys Greenmart 2 - Crimson IslandFinal) (Version: Final - Game Owl)
ARMOURY CRATE Service (HKLM\...\{01378DC3-088F-4F55-AAFA-DC6A9CCA292A}) (Version: 5.4.8 - ASUS)
ASUS Aac_GmAcc HAL (HKLM\...\{998249B1-6913-447E-AA37-F445B8CA33D0}) (Version: 1.0.0.0 - ASUSTek COMPUTER INC.) Hidden
ASUS Aac_GmAcc HAL (HKLM-x32\...\{fd4cf3d0-9937-417e-89b4-56658158819a}) (Version: 1.0.0.0 - ASUSTek COMPUTER INC.) Hidden
ASUS Aac_NBDT HAL (HKLM\...\{01D3B7AA-D078-4506-B460-60877FCDDBD6}) (Version: 2.5.24.0 - ASUSTek COMPUTER INC.) Hidden
ASUS Aac_NBDT HAL (HKLM-x32\...\{ba95a7ce-ede3-4308-a5d6-6c08a15bff04}) (Version: 2.5.24.0 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA Display Component (HKLM\...\{AFD1CF98-FE97-434C-A095-9F27C5BEA53C}) (Version: 1.2.12.0 - ASUSTek COMPUTER INC. ) Hidden
ASUS AURA Display Component (HKLM-x32\...\{fe2996bf-7174-4ad7-af8c-3e8e510c8263}) (Version: 1.2.12.0 - ASUSTek COMPUTER INC. ) Hidden
ASUS AURA Headset Component (HKLM\...\{A3C4120D-8096-4307-91A2-FFE37EBD5A3D}) (Version: 1.3.26.0 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA Headset Component (HKLM-x32\...\{b351ae91-a5dd-4741-8830-883dddd22eb7}) (Version: 1.3.26.0 - ASUSTek COMPUTER INC.) Hidden
ASUS Aura SDK (HKLM\...\{CF8E6E00-9C03-4440-81C0-21FACB921A6B}) (Version: 3.04.39 - ASUSTek COMPUTER INC.) Hidden
ASUS Framework Service (HKLM-x32\...\{339A6383-7862-46DA-8A9D-E84180EF9424}) (Version: 3.1.0.2 - ASUSTeK Computer Inc.)
ASUS Framework Service (HKLM-x32\...\{80f60ecc-98e1-474b-aee2-0c470f02dbbc}) (Version: 2.0.2.6 - ASUSTek COMPUTER INC.)
ASUS Framework Service (HKLM-x32\...\{EA6A87BE-8AD3-40D2-944C-9DF5FBFF4332}) (Version: 2.0.2.6 - ASUSTek COMPUTER INC.) Hidden
ASUS Keyboard HAL (HKLM\...\{0FA0CDEE-5DC8-421E-A97D-C74FA6E66FC3}) (Version: 1.1.48.0 - ASUSTek COMPUTER INC.) Hidden
ASUS Keyboard HAL (HKLM-x32\...\{79497ebd-229a-42ac-9410-87264af2e929}) (Version: 1.1.48.0 - ASUSTek COMPUTER INC.) Hidden
ASUS MB Peripheral Products (HKLM\...\{BFED9861-7D96-4528-89F1-B090ABBF11A7}) (Version: 1.0.35 - ASUSTeK Computer Inc.) Hidden
ASUS MB Peripheral Products (HKLM-x32\...\{193a2068-8738-4276-ab1b-9133f9403487}) (Version: 1.0.35 - ASUSTeK Computer Inc.) Hidden
ASUS Mouse HAL (HKLM\...\{B8F984F2-7887-4DD2-8D96-F9A4BC5A4AC5}) (Version: 1.1.0.45 - ASUSTek COMPUTER INC.) Hidden
ASUS Mouse HAL (HKLM-x32\...\{559342ce-3e0f-4daf-bd9f-dfb67f065c28}) (Version: 1.1.0.45 - ASUSTek COMPUTER INC.) Hidden
ASUS MultiAntenna Service (HKLM\...\{EBB02F2E-0856-4B8A-9E70-980102C90BBA}) (Version: 3.2.2 - ASUSTeK COMPUTER INC.)
ASUS Smart Display Control (HKLM-x32\...\{8714A8D1-0F08-4681-9DF6-A8C4607A58B4}) (Version: 1.2.0 - ASUSTek COMPUTER INC.)
ASUS Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.107.107 - ASUSTeK Computer Inc.) Hidden
AURA lighting effect add-on (HKLM-x32\...\{1E2EA04B-FCA7-457E-B6F4-F33E1858E859}) (Version: 0.0.28 - ASUS)
AURA lighting effect add-on x64 (HKLM\...\{C5A4A164-4428-4931-B728-96EEF0FA3C44}) (Version: 0.0.28 - ASUS)
AURA Service (HKLM-x32\...\{0fcadbd2-1a6a-4a4a-a56d-fc7163d9b3fa}) (Version: 3.07.25 - ASUSTeK Computer Inc.)
AURA Service (HKLM-x32\...\{56EEEF7D-0AE3-401A-898B-581719D005AE}) (Version: 3.07.25 - ASUSTeK Computer Inc.) Hidden
FreeWriter (HKLM-x32\...\{6BB5F8AA-0329-400C-B4B9-82DBE033746F}) (Version: 1.0.7 - Lifestyle Toolbox)
GameSDK Service (HKLM-x32\...\{021d69c3-d686-4a94-8fb5-fd1ee782fb14}) (Version: 1.0.5.0 - ASUSTek COMPUTER INC.)
GameSDK Service (HKLM-x32\...\{7160DA8D-3F25-4F6E-ABC8-F693551D82FA}) (Version: 1.0.5.0 - ASUSTek COMPUTER INC.) Hidden
Golden Rails 3 - Road to Klondike Collector's Edition (HKLM-x32\...\Golden Rails 3 - Road to Klondike Collector's EditionFinal) (Version: Final - Game-Owl)
Golden Rails 4- World's Fair CE (HKLM-x32\...\Golden Rails 4- World's Fair CEFinal) (Version: Final - Game Owl)
LibreOffice 7.1.3.2 (HKLM\...\{76B2DBF3-5773-4463-9EEB-D4A099EB6265}) (Version: 7.1.3.2 - The Document Foundation)
Malwarebytes version 4.6.3.282 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 4.6.3.282 - Malwarebytes)
Microsoft 365 - en-us (HKLM\...\O365HomePremRetail - en-us) (Version: 16.0.16924.20124 - Microsoft Corporation)
Microsoft Update Health Tools (HKLM\...\{89581302-705F-42C5-99B0-E368A845DAD5}) (Version: 3.70.0.0 - Microsoft Corporation)
Mozilla Firefox (x64 en-US) (HKLM\...\Mozilla Firefox 119.0 (x64 en-US)) (Version: 119.0 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 110.0 - Mozilla)
MusicBee 3.5.8447 (HKLM-x32\...\MusicBee) (Version: 3.5.8447 - Steven Mayall)
NVIDIA FrameView SDK 1.1.4923.29548709 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.1.4923.29548709 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.21.0.36 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.21.0.36 - NVIDIA Corporation)
NVIDIA Graphics Driver 462.06 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 462.06 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.38.40 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.40 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.20.0221 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.20.0221 - NVIDIA Corporation)
Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.16924.20124 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.16924.20078 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.13127.20616 - Microsoft Corporation) Hidden
Rainlendar2 (remove only) (HKLM-x32\...\Rainlendar2) (Version: - )
RefreshRateService (HKLM-x32\...\{7E5E84CB-B190-4658-A4DC-166779C329D1}) (Version: 2.1.0 - ASUSTeK COMPUTER INC.)
ROG CustomHotkey (HKLM-x32\...\{374883e6-b31d-4a3c-9c4a-2685a840aed4}) (Version: 1.1.1 - ASUSTek Computer Inc.)
ROG Live Service (HKLM\...\{2D87BFB6-C184-4A59-9BBE-3E20CE797631}) (Version: 2.0.4.0 - ASUSTek COMPUTER INC.)
Roman Adventures - Britons 2 (HKLM-x32\...\Roman Adventures - Britons 2Final) (Version: Final - Game-Owl)
Shotcut (HKLM\...\Shotcut) (Version: 21.10.31 - Meltytech, LLC)
Speccy (HKLM\...\Speccy) (Version: 1.32 - Piriform)
Speedify (HKLM\...\Speedify) (Version: 12.8.0.10689 - Connectify)
TreeSize Free V4.6.3 (64 bit) (HKLM\...\TreeSize Free_is1) (Version: 4.6.3 - JAM Software)
Undercover - Blood Bonds (HKLM-x32\...\Undercover - Blood BondsFinal) (Version: Final - Game Owl)
Waterfox (x64 en-US) (HKLM\...\Waterfox 102.5.0 (x64 en-US)) (Version: 102.5.0 - WaterfoxLimited)
Welcome to Primrose Lake 2 Premium Edition (HKLM-x32\...\Welcome to Primrose Lake 2 Premium EditionFinal) (Version: Final - Game Owl)
Welcome to Primrose Lake 3 (HKLM-x32\...\Welcome to Primrose Lake 3Final) (Version: Final - Game Owl)
Windows PC Health Check (HKLM\...\{6798C408-2636-448C-8AC6-F4E341102D27}) (Version: 3.6.2204.08001 - Microsoft Corporation)
WinRAR 6.02 (64-bit) (HKLM\...\WinRAR archiver) (Version: 6.02.0 - win.rar GmbH)
WizTree v4.12 (HKLM\...\WizTree_is1) (Version: 4.12 - Antibody Software)
Packages:
Adobe Acrobat Reader -> C:\Program Files\Adobe\Acrobat DC [2023-10-29] (0)
AMD Radeon Software -> C:\Program Files\WindowsApps\advancedmicrodevicesinc-2.amdradeonsoftware_10.21.30024.0_x64__0a9344xs7nr4m [2022-09-12] (Advanced Micro Devices Inc.) [Startup Task]
ARMOURY CRATE -> C:\Program Files\WindowsApps\B9ECED6F.ArmouryCrate_5.4.8.0_x64__qmba6cd70vzyy [2023-09-14] (ASUSTeK COMPUTER INC.)
AURA Creator -> C:\Program Files\WindowsApps\B9ECED6F.AURACreator_3.5.6.0_x64__qmba6cd70vzyy [2023-02-01] (ASUSTeK COMPUTER INC.)
Disney+ -> C:\Program Files\WindowsApps\Disney.37853FC22B2CE_1.45.5.0_x64__6rarf9sa4v8jt [2023-02-02] (Disney)
Dolby Access -> C:\Program Files\WindowsApps\DolbyLaboratories.DolbyAccess_3.16.345.0_x64__rz1tebttyb220 [2023-01-23] (Dolby Laboratories)
Microsoft Whiteboard -> C:\Program Files\WindowsApps\Microsoft.Whiteboard_53.10114.505.0_x64__8wekyb3d8bbwe [2023-01-20] (Microsoft Corporation)
MyASUS -> C:\Program Files\WindowsApps\B9ECED6F.ASUSPCAssistant_3.1.13.0_x64__qmba6cd70vzyy [2022-12-23] (ASUSTeK COMPUTER INC.)
NVIDIA Control Panel -> C:\Program Files\WindowsApps\NVIDIACorp.NVIDIAControlPanel_8.1.963.0_x64__56jybvy8sckqj [2022-10-29] (NVIDIA Corp.)
Realtek Audio Control -> C:\Program Files\WindowsApps\RealtekSemiconductorCorp.RealtekAudioControl_1.37.275.0_x64__dt26b99r8h8gj [2022-11-14] (Realtek Semiconductor Corp)
Solitaire & Casual Games -> C:\Program Files\WindowsApps\Microsoft.MicrosoftSolitaireCollection_4.15.12020.0_x64__8wekyb3d8bbwe [2023-02-02] (Microsoft Studios) [MS Ad]
Spotify Music -> C:\Program Files\WindowsApps\SpotifyAB.SpotifyMusic_1.203.1115.0_x86__zpdnekdrzrea0 [2023-01-20] (Spotify AB) [Startup Task]
Percentage of memory in use: 56%
Total physical RAM: 15792.36 MB
Available physical RAM: 6868.79 MB
Total Virtual: 31584.73 MB
Available Virtual: 19364.09 MB
1 Drive c: (OS) (Fixed) (Total:453.5 GB) (Free:19.98 GB) NTFS
User accounts for \\LAPTOP-6ODOHNQP
acco5 Administrator DefaultAccount
Guest WDAGUtilityAccount
**** End of log ****
