WiFi access point
nigel cook
29
4
56
Hi. To try and extend my WiFi back to front of a long bungalow I've setup a WiFi access point from a previous router
It all works perfectly. Question though
Connected WiFi to main network 200 Mbps
Connected to new access point from a router. 30 Mbps
Is that normal to get such a vast drop off. Or am I missing something?
Thanks
Nigel
Apologies I missed replying.
The main router is a Virgin hub -- On both Hard wiired and wifi - i can get 200 mbps
The secondary router is quite old, and suspect that this is the cause It is a Belkin N150, F6D4630-4 It is not dual band - which I suspect might be the main issue when connected through mobile phone to secondary router, and then running a speed test,.
