Solved What power supply is a good balance between cost and reliability?
I would recommend finding the cheapest that meets your power requirements now and into the near future and is about 20% more than you need - then check it has a 10 year warranty.
or at least 7 years.
then you can't go wrong.
if you need a better PSU, than get a better one!
don't go into it with half measures and end up with something you didn't want/need just because you had a budget to stick to. :)
the PSU is often the part most overlooked but the part that should be at the heart of every build.
to get you started, any high-end unit from eVGA, Seasonic or Corsair would be good.
My previous power supply was 500w, so do you recommend sticking to that or upgrading to 750w for example in case I want to upgrade another power intensive part
500w is the bare minimum for a standard, non-gaming, no add-on GPU rig.
anything above and beyond that and yes, 750w would be my choice.
if there is a high-end GPU installed, or multiple fans, drives, peripherals, etc - than go at least 850w and beyond!
also, as a minimum, get 80+ Gold cert units - Platinum and Titanium if budget allows - but their prices are unusually only justifiable if the rig is of a similar standard. (y)
Well, I have multiple drives and fans but only mid range gpu so is the 850w still worth it? I don't want to overspend because the pc doesn't even work at the moment because of the power supply issue and I was originally going to buy a 750w from somewhere
A spec list would be helpful for coming up with a good number. :)
Intel Core i7 3770 @ 3.40GHz
XUM Enterprise Ltd B75
RAM 16.0GB Dual-Channel DDR3 @ 798MHz
 Nvidia GeForce GTX 1650 4GB
931GB Seagate ST31000525SV (SATA) + 238GB Hitachi HX256GSSDM2-PCIE (Unknown (SSD))
GP500 500W 80 Plus Bronze Wired Power Supply
Operating System (OS)Windows 10 Home 64-bit
ok thanks guys, I'll probably have a look for a 750w as my 500w was unreliable, but what companies sell the best power supplies? I don't want to risk buying from a company with a bad reputation
a company that offers a 10 year warranty are the ones to look at.
to get you started, I like the ones by Corsair, eVGA and Seasonic.
Fwiw, the OP was appropriately advised in their previous thread here and predominantly my reply #7, no need or point in them spending a fortune on a system that dates back to 2012.
OK I'll definitely have a look at some power supplies from corsair, evga and seasonic
again, thanks for the help
