I'l start off by saying i've tried nearly everything i could think of. I come here in desperation. Built a new PC - fresh install of W10. From the start been having this issue. When i boot W10 everything is zippy fast and after a couple days gets really sluggish like opening "this pc" takes 3-4 seconds vs instantly.
- I've run memtest86 on each stick individually to see if problem wit RAM - came back 0 errors
- Manually set RAM frequency to 3200mhz in BIOS on auto set to 2200 i think
-Manually set NVMe to Gen 3 - Samsung Magician Results - Sequencial READ/WRITE (MB/s) - 3566/3028 - Random IOPS READ/WRITE - 280517/257080
- Checking Temp using HWMonitor - nothing above 40C - CPU will reach around the 60C if i'm doing heavy use Stock Cooler
-Basic stuff Task Manager Idle 2%CPU - Memory at 28% usage most taking up by Windows explorer at 260MB - GPU 1% - Disk 0% - Network 0%
-Tried turning page file on/off
-Windows is all up to date
-No A/V programs except W10 protection defaults
-Check Power Plan Settings
-Turned off nearly every Windows Service that didn't look essential.
-All background programs closed.
-Virus Scan with Malware bytes, bitdefender and spybot.
My Specs:
PSU - Thermatake 850w 80+Gold
Mobo - ASUS AM4 TUF Gaming X570-Plus
CPU - AMD Ryzen 7 3800x 3.9GHz
Ram - G.Skill Ripjaws V Series 16GB x 2 - (Connected to Proper Channels on Board)
SSD - Samsung 970 Evo Plus M.2 500Gb
Graphic - Gigabyte GTX1070
Edit - Samsung 840 evo SSD - Samsung Magician Results - Sequencial READ/WRITE (MB/s) - 7489/5653 - Random IOPS READ/WRITE - 158447/79833
(Faster read /write than m.2 but slower IOPS than m.2 if that means anything)
Any Suggestions or advice would be extremely helpful. Im not sure if it's Hardware or Software issue. I really don't know what else i can try.
Thanks
My Specs:
Thanks
