W10 booting problem
CeSium
24
Hi!
I've reinstalled Windows about 2 month ago, and all that time I had one problem:
When I'm turning on my PC, I see screen with my motherboard logo, keyboard and mouse starts blinking (they have LED). However, the boot process stops on this moment....
So, I occasionally discovered how turn my PC on : when I see the screen with motherboard logo, I need to press Ctrl+Alt+Del, PC starts rebooting, and then it boots windows 10 normally, like it should be.....
According to eventViewer: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
The driver detected an internal driver error on \Device\VBoxNetLwf.
The driver \Driver\WUDFRd failed to load for the device HID\VID...........
Unable to start a DCOM Server: {....}
as Unavailable/Unavailable. The error:
"0"
Happened while starting this command:
C:\Windows\System32\rundll32.exe C:\Windows\System32\shell32.dll,SHCreateLocalServerRunDll
My PC spec:
Motherboard: Gigabyte B450 Aorus Pro
CPU: Ryzen 1600x
RAM: HyperX 2666 MHz, 2x8Gb
(I don't think that other components are so important)
My PC spec:
CPU: Ryzen 1600x
Knowing the type of device that you are booting from would be helpful as would knowing the following.
Is the boot device first in the boot order.
What type of media was used to install Windows and from where was it obtained, DVD or downloaded ISO from Microsoft for example.
The two are unrelated, your OP tells us that you are having boot issues whereas the Event Viewer suggests that Windows has not been correctly shut down, thermal shut downs and power loss are two typical causes of this.
