Solved virtual box
rustys link is right on the money.
you may have removed the software but the virtual PC you created still lives on.
you need to kill the virtual hard drive it created, a VHD file from memory.
if you can't remember the folder location, get WizTree to find large files on your PC, the VHD will be about 5GB's or more.
