Hi, I have the following spec. of PC:
Operating System
Windows 10 Pro 64-bit
CPU
AMD Ryzen 9 3950X 35 °C
Matisse 7nm Technology
RAM
128GB Dual-Channel DDR4 @ 1064MHz (15-15-15-36)
Motherboard
ASUSTeK COMPUTER INC. ROG CROSSHAIR VIII HERO (AM4) 30 °C
Graphics
XXX (3840x2160@60Hz)
2047MB NVIDIA GeForce GT 1030 (ASUStek Computer Inc) 39 °C
Storage
7452GB Seagate ST8000DM004-2U9188 (SATA ) 28 °C
7452GB Seagate ST8000DM004-2ZD188 (SATA ) 26 °C
14902GB TOSHIBA MG08ACA16TE (SATA ) 24 °C
14902GB TOSHIBA MG08ACA16TE (SATA ) 23 °C
7452GB Seagate ST8000DM004-2CX188 (SATA ) 28 °C
7452GB Seagate ST8000DM004-2U9188 (SATA ) 31 °C
232GB Samsung SSD 970 EVO Plus 250GB (Unknown (SSD))
1788GB Force MP510 (Unknown (SSD))
Optical Drives
ASUS SDRW-08D2S-U USB Device
Audio
Realtek High Definition Audio
I am trying to copy one of my 8TB Seagate drives to a new 8TB Seagate drive, with FreeFileSync.
At the beginning, the drive was copying at a speed of between 70MB/s to 130MB/s, varying up and down, presumably depending on what size of files it was copying, and other reasons, but after I left the computer copying the files overnight, the next day I noticed that the copying wasn't as far through as it should have been (I think it predicted something like 16 hours initially, but now it said there were several days left to complete the copying, and only maybe a third of the files had been copied, after about 16 hours.)
Then I noticed that the copying process was going down to 0B/sec, for maybe half a minute, then speeding back up to maybe 30MB/s to 50MB/s, for maybe ten seconds, then it would slow down to zero, in another ten seconds.
I also had freezing problems with my PC, where I couldn't get a browser window in Firefox to refresh, then I found it wouldn't refresh any browser windows. Then I opened Microsoft Edge, and found that wouldn't load any websites. Then I tried to open Task Manager by pressing CTRL-ALT-DEL, and the screen went blank, except for a Youtube video that I had been watching in a pop out window - that carried on working. If I pressed Alt-Tab, I could see the window thumbnails and cycle through them, but none of them would appear when I stopped Alt-Tabbing on them, and still the Youtube video window was working. Then that froze, and then after maybe five minutes, suddenly all the windows came back. But FreeFileSync was now at 0B/s all the time, I waited several minutes and nothing happened, so I thought I would turn off the PC and turn it back on, but when I used the Start button Power command, and chose 'Shut Down', nothing happened, and I eventually had to use the power button on the front of the PC to turn it off.
Now I've turned it back on, and I'm using FreeFileSync again, to try to complete the last ten percent of the 8TB drive copying, and it worked fine for about five minutes (when I started this post), copying at between 70MB/s and 130MB/s, but now it's going from 50MB/s down to 0B/s, but at the moment it only stays at 0B/s for about two seconds, then goes back up to about 5MB/s, and it's copying at about 40-90 files a second when it's doing 5MB/s. (I realise it takes longer to copy lots of smaller files, than fewer, large files).
I know that the PC came with a load of 'Armoury Crate' software, which I can see in Task Manager, and is something to do with it being a gaming PC - but I didn't buy it for gaming, so if I can turn all of that ASUS stuff of, I will be happy to, if it will help..
I'll try copying the files using Windows Explorer, just to see if I have the same slowdown problem. I've been using FreeFileSync for about ten years, and I've always used it on this PC, which I've had for just over a year now, and I haven't had this bad a problem before. I have had times when the whole PC froze when I tried to save a webpage as a PDF from Firefox - nothing would work for maybe a minute, maybe two minutes, as if it was looking for hard drives and couldn't find them or something - that's been going on maybe once a month since I got the PC last year.
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
