Solved very high power usage
Octopain
7
4
44
Ehypt
I have very high power usage at a game I like to play sometimes
my Pc Specs at my Profile
Thank you ................
Not how it works Octopain :(
If you would like to enjoy the benefit of the free help that PCHF offer the least that you can do is post your computer specifications in your OP + as much information as you can about any problem/s that you may be having and any steps that you have tried already.
Reactions: Octopain
ok sorry for this
My Computer Specifications
ASUS ROG X570 Crosshair VIII Hero (Wi-Fi)
AMD Ryzen 9 3950X
ASUS ROG Strix AMD Radeon RX 5700XT
G.SKILLTrident Z DDR4-3200MHz 32G
EVGA SuperNOVA 1000 G3, 80 Plus Gold 1000W, Fully Modular
Sorry for annoying u I found the issue and its solved
it was an option in the game keep Rendering all the time in case if u are Streaming I was enable it
Reactions: phillpower2
I have 1 more Question about anti-virus may I ask about it here or I have to do another post ?
Thank you
No problem and thanks for sharing the solution so that it may be of help to others (y)
Reactions: Octopain
