Not sure this is the right place or not..but need to know if using a flash drive to speed up your computer will only do it if you are low on RAM ? Or it will always speed it up..
Thanks;
hefs
Thanks;
hefs
ok..did a some clean up on files etc..driver and program updates...removed a couple of old programs...Hello @Hilton Heflin you have an update for us?
Why does IE come up as not responding on some web sites when I am using FireFox as my browser ?
sorry, I confused you...I want to keep FF as my default browser..what I meant is that every once in a while IE not responding pop up shows up when I am on a web page and I am on FF browser?Reset IE to default.
Then see if you can download and run the programs listed in this post with it.
Does this happen on certain web site(s)?
Have you set Firefox to check and make sure it is the default Browser?
Are you using the latest version of Firefox?
Could you post a screen shot?
Have you reset Firefox?
sorry,my old 75 yr old brain just realised I I was getting post from two different people...if I reset IE ...will it make it my default browser again?Not confused. Reset internet explorer to default and see if you are able to download and run the tools.
ok..done..thanks..hopefully we can put this one to bed...will see what happens for a few dats..If you reset it. It may ask to be default browser. Just decline the offer. It may resolve the issues you speak of.
