Solved Using 2 Different Manufacturers for RAM?
Brandon Byrnes
605
58
40
Wisconsin
I am looking to add some more RAM to my system. I currently have 16GB (2x8GB) of Corsair Vengeance LPX DDR4 3600 C18-22-22-42. I was going to go with the same exact RAM but it's sold out everywhere. So right now my only option is to go with a different manufacturer. I was looking at G.Skill Ripjaws V Series 16GB (2x8GB) DDR4 3600 C18-22-22-42. It's the same speed and same latency, but again a different manufacturer. I know it's best to stick with the same manufacturer but it's not going to be possible. Do you guys forsee any problems I might have with this choice. I currently have XMP enabled so I'm getting the advertised speed of 3600mhz.
