Solved USB
chuck davis
268
40
68
Iam not to great, with Linux. Heres my question, allthough this makes no sence at all to me.
I got Linux Mint on a USB ( not installed ) and it boots up fine with no problem,s I changed the ( bios ) boot order long ago.
I downloaded Puppy Linux to USB used Pen Drive, it downloaded fine with no problems. When i stick Puppy Linux in the laptop on a USB then boot the computer, it boots straight to my Windows 10, instead of Puppy Linux.
Thank,s Chuck
Let a staff member know if you need more help with this and the thread can be reopened for you.
