USB Wifi dongle Need help
XP Over GF
3
So U have been using this USB wifi dongle for a while now and a few months ago a built a pc but ever time I plug it into the motherboard or the front panel of my case it runs terribly slow e.g 11mbps down/10mbps up were if I plug it into my keyboard (Keyboard has a USB port on it) it works fine and I get normal speeds 40mbps down/25mbps up they dongle works on every other computer just fine except this one and i can't figure out why any help would be nice :D
Can you also tell us the brand and model name or number of the motherboard and the computer case, if an OEM computer such as Dellor HP etc, post the exact model name and number.
And my wifi dongle is TP Link Model TL-WN725N and i just got a new case today aswell its the NZXT H500i and it even does it on that case to so im not sure whats wrong it works on ever other computer fine and i dont get why it works through my keyboard usb slot
Check the power plan settings for the USB ports, some info on this here
We could do with a Speccy url, we are aware that you have Speccy already and the canned info below is just to save time with the typing :)
Not what Speccy is telling us I`m afraid :(
Network
You are connected to the internet
Connected through: Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter
Adapter Type: IEEE 802.11 wireless
NetBIOS over TCP/IP: Enabled via DHCP
NETBIOS Node Type: Hybrid node
Link Speed: 2.1 KBps
Computer Name
NetBIOS Name: DESKTOP-N1NAHS8
There are a couple of other things of note in Speccy, some will affect performance and one could result in you losing important data.
Power Profile
Active power scheme: High performance This is a form of overclocking that generates heat and causes instability, change it to Balanced in the Windows Power Plan.
The following hard drive is warning of imminent failure, test it before saving anything important to it.
Hard drives
ST250DM000-1BD141
Manufacturer: Seagate
Heads: 16
Cylinders: 30,401
Tracks: 7,752,255
Sectors: 488,392,065
SATA type: SATA-III 6.0Gb/s
Device type: Fixed
ATA Standard: ATA8-ACS
Serial Number: 9VYGYY5E
Firmware Version Number: HP73
LBA Size: 48-bit LBA
Power On Count: 1456 times
Power On Time: 981.9 days
Speed: 7200 RPM
Features: S.M.A.R.T., NCQ
Max. Transfer Mode: SATA III 6.0Gb/s
Used Transfer Mode: SATA III 6.0Gb/s
Interface: SATA
Capacity: 232 GB
Real size: 250,059,350,016 bytes
RAID Type: None
S.M.A.R.T
Status: Warning
There is also a lot of keyboard, mouse and other drivers installed, you need to get rid of any that are unneeded and the same for any needless software.
NB: Please note that the CAM software can affect your internet connection.
and what is your keyboard make/model.
speccy shows some Corsair and Logitech details but more info would be helpful.
