Solved USB-to-VGA and USB-to-DVI adapters working not together
MIRKOSOFT
204
21
45
Hi!
I'm using my PC with 3 desktops.
2 desktops are connected to nVidia GeForce 210 by DVI and HDMI.
I had connected one desktop by USB-to-VGA adapter by Manhattan - this desktop had max.resolution 1600x1200.
I changed display to 24" 1920x1200 display and adapter written above supports max. widescreen 1680x1050, so I bought new one.
I connected new USB-to-DVI adapter by DisplayLink to display and it works.
Everybody knows that these adapters can be connected up to 6 to one computer, so I wanted to use 4th desktop.
I could do mirroring of nVidia, but when I tried mirroring long time ago, resolution was limited by the lower LCD resolution - so, it affected new display (if was this changed, let me know please).
So, I connected USB-to-VGA again to computer and to old 1600x1200 LCD, but problem - works not. LCD is found but no one option is available and checked is turned off LCD. I look into device manager and found problem - here are results:
New USB2DVI
USB Display Adapters category
Device: USB3.0 to DVI Adapter
Manufacturer: Display Link
Status:
Device working properly
Old USB2VGA
Device: Trigger USB Graphics Chipset Family (1P-E)* / (1P-M)*
Manufacturer: Magic Control Technology Corp.
Status:
Windows cannot initialize this hardware driver (Code 37)
A device which does not exist was specified.
*1P-E and 1P-M are devices with same status and values in device manager separately
Can anybody explain me why it works not and how to solve it?
For correction: OS - Windows 10.1511 Pro x64
Thank you for all.
Miro
  • Download drivecleanup.zip to your desktop.
  • CLICK HERE to determine whether you’re running 32-bit or 64-bit for Windows.
  • Once the determination has been made open either the 32-bit or 64-bit folder.
  • Remove All usb items from the computer, only leave the mouse and keyboard installed.
  • Right Click the .exe on the inside of the folder and run as admin. 32-bit or 64-bit
  • A command prompt window will open telling you what has been removed upon completion.
  • Reboot your machine.
  • Check the issue and report back.
I'm not newbie in Windows and in post above is written Windows version, now total exactly:
Windows 10.1511 Build 10586.545 Pro x64
My Q is now - is Driver Cleanup only one way? I got many drivers hardly, old MB, and cleaning system can do many problems or?
Miro
Reactions: Malnutrition
This program will remove trouble drivers. It will not remove anything else. Run it with instructions provided reboot, and plug your devices back in and plug & play will take care of the rest.
Not sure what you mean, please elaborate.
Explain please.
This is a Contradictionary statement
Please see first sentence of post 4
Is there anything else you wish to question? If so, please create a restore point prior to trying anything we suggest and then give us your feedback on the outcome.
