Solved [URGENT] Need help go choose between 2 PCs
Milenko
10
23
They both have a same price, 1st one:
i5 3550
R9 380 4gb gigabyte g1
8GB Ram
500GB HDD
2nd one:
i5 3550
Gtx 660 2GB Gainward
8GB ram
120GB SSD and 1TB HDD
R9 is a bit better card than 660 but this one has ssd and more hdd
I would use it to play GTA V and Minecraft
I need help to decide which one to choose, thank you guys
No question about it. The first one.
Does not matter if you have an SSD for games as it mostly matters with boot time but not playing. You can add HDD's or SSD's anytime. Should always have 2 storage in your PC. One for backup. While the second one has 2, the SSD is not large enough for GTA V to install on with the OS ( you could but don't fill up your OS SSD as it does not like that). Boot times on the game on the HDD will be the same for either PC.
GPU 4Gb is better than 2Gb everyday.
Both PC's are weak for GTA V but as long as you are happy with that. I might save more money and buy something along the lines of a gaming PC. Save lots! Have fun
GTA 5 Minimum PC Requirements List​
  • Operating System: Windows 8.1 64 Bit, Windows 8 64 Bit, Windows 7 64 Bit Service Pack 1
  • Processor: Intel Core 2 Quad CPU Q6600 @ 2.40GHz (4 CPUs) / AMD Phenom 9850 Quad-Core Processor (4 CPUs) @ 2.5GHz
  • Memory: 4GB
  • Video Card: NVIDIA 9800 GT 1GB / AMD HD 4870 1GB (DX 10, 10.1, 11)
  • Sound Card: 100% DirectX 10 compatible
  • HDD Space: 65GB
Also Read: GTA 5: How to download GTA 5 on PC and Android smartphones from Steam and Epic Games store?
GTA 5 Recommended PC Requirements List​
  • Processor: Intel Core i5 3470 @ 3.2GHZ (4 CPUs) / AMD X8 FX-8350 @ 4GHZ (8 CPUs)
  • Memory: 8GB
  • Video Card: NVIDIA GTX 660 2GB / AMD HD7870 2GB
  • HDD Space: 65GB
Reactions: Milenko
