Hi guys,
I'm just about to be upgrading my broadband provider and will now be able to get speeds of up to 1200mbps and so want to upgrade the internal WiFi card in my motherboard (installed in one of the M2 slots) as it appears to max out at 433mbps.
www.msi.com
The specs for the motherboard are there. Can someone please send me some examples of the sort of card I would need to buy? I'm a little confused about what I'd actually need.
www.scan.co.uk
I've found these, but I have no idea what "No VPRO" and "VPRO" mean and I've also seen "CNVio2" and "CNVio" mentioned in saying that CNVio2 is not backward compatible with CNVio, which I honestly have no idea on what that's supposed to mean haha.
Any help much appreciated. Cheers!
MPG X570 GAMING EDGE WIFI
Worth buying AMD AM4 X570 ATX gaming motherboard, lightning PCIe 4.0, lightning M.2, lightning M.2, Frozr heatsink, WiFi, USB 3.2 Gen 2, M.2 heatsink, good overclocking, extended heatsink, pre-install I/O, MSI GAMING
M.2 Network Cards - Network Card M.2 Adapter Wireless AC AX WiFi 6 Dual Band 2.4GHz 5GHz | SCAN UK
Welcome to our M.2 Network Cards - Network Card M.2 Adapter Wireless AC AX WiFi 6 Dual Band 2.4GHz 5GHz page. Here you will find leading brands such as Dell, Intel.
