Upgrade help
Steven Martin
37
I think I may be due an upgrade
I am new to this kind of thing
My pc specs are as follows
Intel i5 -3470
16gb ram
Amd 570 graphics card .
Not sure if any more info need but please ask . I would like to upgrade but don't know where to start many I play warzone 2.0
Thank you
Welcome to PCHF. :)
When I was new into computers, somebody wiser than me said - "Never build based on a game, build based on your budget."
This is my advice to you, establish what you want to spend, and then you can assess how that will fall into your gaming wants.
As far as what you 'need' to run warzone, Activision has a whole page on the various specs to play their game at desired settings and refresh rates:
Knowing more about your PC would help us establish what parts are good and usable, and what would be better replaced-
Download and run the free version of speccy.
Once you have ran speccy, follow the instructions to upload a snapshot found here.
Please list your power supply unit
Reactions: veeg
Welcome to PCHF. :)
thank you for your quick replay
the speccy snapshot is as follows
thank you
Knowing a your budget and the make of you PSU is necessary.
I could suggest hundreds if not thousands of upgrades, but that doesn't make sense unless you are going to be able to use that/need it.
You should be able to find the PSU model either on the back of the computer where you plug it in or by pulling off the side panels and looking at it that way.
