Telefunken FULL HD LCD - FPS drops, ms timing
Jashinv2
4
34
Hey Guys.
I've got a problem with small fps drops resulting in stutter (from 60fps vsync to 57/56 and when going into ingame menu it drops to 59, all drops only last for about a second.
It happens in all games at every resolution and high or low settings.
Someone recommended checking on vsynctester and my TV is slightly off regarding fps and ms-timing (58/59 @ 17,0 ms) while on youtube I saw someone with propper results
like 16,6 ms and 60 fps and pretty stable at that.
I can almost certainly rule out my pc components, no thermal throttling and the hardware is good enough for those games (as it happens even on older less demanding games)
I7 8700k
gxt 1070
seasonic 650w
strix z390-e
here a few screenshots, you can ignore the cpu-z screenshot, the 2 screenshots below it are important.
