Solved taking long time to establish network connection(Ethernet Lan)
gobi15
7
57
hi,I am facing an internet connection issue after windows boot,There is delay about 90 seconds.sometimes around 2 minutes between reaching the desktop(when desktop appears&the network icon start spinning) & finally establishing network connection.
I tried several solutions found in the net but nothing worked,Finally I narrowed it down to the Avira Free antivirus. I thoroughly uninstalled Avira(though i should have tested in Safe Mode first)& network connection is immediate.
FYI I did not instalL Microsoft Security Essentials.
Is there any work around or solution so that Avira does not conflict with network connection & causing delay.Or can anyone who had faced the same problem recommend another antivirus.
Since its a free version Avira does not offer technical support.
Would appreciate if someone can help solve this matter.Thanks.
Specifications:Motherboard:Intel DG43NB
Processor:Intel(R)Core(TM)2 Quad Cpu Q8200 @2.33Ghz
Ram:4GB
Operating System:Windows 7 Ultimate SP1 64 bit
Network Adapter:Intel(R)82567V-2 Gigabit Network Connection
Here are some places to start while waiting for other to post.
Here is the tool to remove the leftovers of Avira.
Run that then post a speccy report.
Have you tried resetting the entire network or the computers network configuration back to factory?
What happens when the system starts under a clean boot?
Reactions: gobi15
I'd suggest reinstalling Avira, then use Geekuninstaller, force mode to remove it.\
Then use the Avira removal tool.
You can then search Avira with the Everything search engine and remove any remnants that way.
Also, check with Autoruns tool, to see if any drivers for Avira are still loading. They like to stick around sometimes, even after removed....
Download adwarecleaner
Save it to the desktop run as admin.
Go to setting tab and make sure these are all on.
Turn on the following.
Delete IFEO Keys.
Delete Tracing Keys.
Delete Prefetch Files.
Reset Proxy.
Reset Chrome Policies.
Reset TCP/IP
Reset Hosts Files.
Reset Winsock
Reset IE Policies
Reset IPsec
Reset Firewall.
Now go back to the dashboard, make a scan then when complete make certain everything is ticked.
Then click on Clean.
Then your machine should reboot.
Check the issue after the machine restarts.
Then tidy up the machine.....
  1. Download CCleaner from here.
  2. After installing click options.
  3. Go to monitoring.
  4. Uncheck all monitoring items.
  5. Go to advanced tab -- Click close program after cleaning.
  6. Go to settings -- Click run Ccleaner when the computer starts.
  7. Now that you have Ccleaner installed and set-up:
  8. Open the program.
  9. Go to Tools
  10. Go to Startup
  11. Now double click each item. To Disable.
  12. Leave only your antivirus enabled & the programs mentioned before.
  13. Then disable All items in your Scheduled Task as well.
  14. Unless they are related to Windows Defender -- Or your Antivirus.
Additional info:The network detection lag was minimal (normal)after installation of Avira antivirus when connected using wirelessN ADSL 2+ router combined with modem(modem router) but increase to more than 1 minute when I recently migrated to fiber broadband which utilise separate modem & wifi router.
Router:DLINK DIR-830M Dual Band AC1200 Gigabit Wifi Router.
Modem:HG6240A GPON Optical Network Unit Code:M6240000001B Version: A.
PSU:Cooler Master RS-460-PCAR-A3 ATX12V V2.3
*Speccy result url http://speccy.piriform.com/results/kva7O7ksd25oDl8Z4UMA4Mj
The heading says trouble with Ethernet lan
Post #6 says wireless
What are we trying to fix here
Not using wifi adapter for desktop pc but connected with ethernet cable from pc to Lan 1 port of wireless router & router Wan port also linked with ethernet cable to Lan 1 port of modem/optical network unit.
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Please post the log in your next reply
Security Check Scan.
  • Download Security Check to your desktop.
  • Right click it run as administrator.
  • When the program completes, the tool will automatically open a log file.
  • Please post that log here in your next post
Think I go this route.Instead of sticking to an already unsupported system,better to install Linux Mint to this ancient motherboard.Also anti virus companies including Avira had either already ended support for Windows 7 or planning to.
Sorry to all you guys for wasting your precious time.Admin, please mark this case as closed.
