Thanks for the recommendation..the problem is the shop is far away to claim for warranty..i rather check first than last resort claim for warrantyIf i were you i would the warranty and take the pc back.
Some things that we may have you do will VOID the warranty.
Can you call them there maybe some things that they can walk you through over the phone. They may have a technician on staff or one close by that you could have the system checked by.
Check to make sure that you do not have a USB drive attached it could be reading form that.
Also what beeping (pattern) and or any other sounds do you hear coming from the system?
Thanks for the advice..already take off all usb attached and still the same error..probably because of virus from my external hard disk.
Will try to call them. Previously manage to msg them and they prefer to remote the pc however i could not enter windows and it is not possible..maybe should install temporary windows to connect first than foemat it and install back all
Too bad..maybe the antivirus is not working..
attached
What is the brand and model name or number of the computer.
What version of Windows is on the drive, 7, 8.1 or 10.
How to install using usb can you help to guide
Something for you to try first, check to see if there is still a recovery partition on the HDD.
Turn on the computer and repeatedly press the F11 key and hope that the HP Recovery Manager opens, if it does , follow the on screen prompts, if not post back and let us know.
Tq will try to download from other pcgood guide on how to burn an image to USB here; https://www.microsoft.com/en-au/software-download/windows10
