Hi all,
A family member has a Dell Studio 1540 desktop which currently has Windows 7 installed; I've taken it off their hands to hopefully upgrade it to Windows 10.
I have switched the PC on and I'm currently stuck in a startup repair loop i.e. startup repair reports it cannot repair the issue and my options are to shutdown or restart, doing so takes me back to startup repair.
The problem event name given is "StartupRepairOffline". Is this because the PC is not connected to the internet?
The diagnosis and repair details report an error code of 0x490.
Please note that as part of the upgrade to Windows 10 I was going to replace the hard drive because when the PC previously loaded properly a scan of the hard drive using SeaTools indicated the hard drive was failing; this is perhaps contributing to the problem.
What do you think my best course of action is?
Thanks.
Thanks.
