SSD problem
Nathanjack
6
24
My SSD is not showing up on my computer it was working fine then after I downloaded a game the SSD didn’t show up on the computer.
Hi,
If you open up Disk Management in Windows, do you see it listed there? Do you see it listed in your motherboards BIOS?
when I switch the sata ports it shows up in bios, but when I go into windows to create a new partition it’s not there, and then when I restart the pc it is no longer in bios unless I switch to another sata port.
