Solved Sound problem
skawzy
3
34
Hi there!
I have a problem with Sound. Sometimes the sounds stop for about 2-3 seconds, I have the same problem on call via Skype and also on Youtube.
Any help with this issue?
Please give us your complete pc spec's... Including the type audio software you are using..
@Bastet
  1. CPU: AMD Ryzen 7 3700X
  2. MoBo: Aorus Elite B550 ( Bios version: F10 )
  3. RAM: HyperX Predator RGB 3200MHz 32GB
  4. VGA: AMD Radeon RX 5500 XT 8GB
  5. Case: (Seasonic CORE GM 650W)
  6. OS: Windows 10 Pro
