Solved sound issues
shane54
3
my new biuld pc sound works fine on speakers (external) but if i try to setup monitor sound just get nothing..i can see the bar moving in the sound mixer window etc but no sound comes out of the monitor speakers ..if I plug the hdmi cable into the tv I get sound straight away??
Monitor ASUS VP28U (3840x2160@60Hz)
Operating System
Windows 10 Pro 64-bit
CPU
AMD Ryzen 5
RAM
16.0GB
Motherboard
ASUSTeK COMPUTER INC. PRIME X570-P (AM4) 32 °C
Graphics
8176MB ATI AMD Radeon RX 5700 XT (XFX Pine Group)
Storage
119GB NVME SSD 128GB (Unknown (SSD))
232GB Western Digital WDC WDS250G1B0C-00S6U0 (Unknown (SSD))
Optical Drives
HP DVD Writer 1070d
Audio
Realtek High Definition Audio
Suggestion, with your screen hooked up to a HDMI port on the computer/GPU try your headphones in the headphone port on the monitor then get back to us with an update.
Reason why the above has been suggested is because I don`t think that your monitor has internal speakers and that the volume control that the monitor has is to control the earphones and HDMI source on the PC.
Checked the monitor specs here and noticed the absence of any speaker specification, if there were onboard speakers you would see something like the following;
Audio Features Stereo Speakers : 1.5W x 2 Stereo RMS
hi plugwd headphones in ..and set sound to monitor and I get sound through headset..ok so it seems that the monitor has no speakers?? sorry to waist your time...
Not ideal but you have at least determined the reason for the lack of audio.
You have not wasted anyone's time, we are here to help if and when we can.
Reactions: shane54
