Sony Vegas How to deal with large files while editing
Sketis
23
Hello guys, so i have been editing, and I have this problem.
Im using some large video files (1gb-10gb) per 1minute, and its super hard to edit it, because the sony vegas preview window is so laggy. I usually prerender the video and then everything seems fine, but every time I change something I need to rerender it once again. So any ideas, how it could be easier for me to edit ?
We will need more information on you system.
Please go HERE and download the portable version of Speccy. Save it to somewhere you can find, locate the file and as it comes as a Zip file use your favorite unzip application to decompress it. Open the newly created folder and double left click Speccy.exe if you have a 32 bit system or Speccy64.exe if yours is 64bit. If you are not sure what your system is click HERE.
Ow85
Speccy will open and after a short wait will display a summary of your system specs.
  1. Click on the file menu.
  2. Then click Publish snapshot.
fVjw
A dialogue box will ask you to confirm, select yes.
9dYl
Another dialogue box will open
  1. Click Copy to Clipboard.
  2. Then click Close.
Mynz
Now that your link has been copied please paste it into your next post. It should look something like the example below:)
http://speccy.piriform.com/results/6waAHapcLrZIVPakgxXXXXXXX
BTW: once you have finished with speccy and no longer want it removing it is easy because it is a portable app with no install. Simply delete the downloaded file and folder you created when you decompressed it. Gone:thumbsup:
