Solved slow wifi
chuck davis
268
40
68
I have Windows 10 and Linux Mint 17.3 on the same computer. My Windows 10 WIFI is very strong, but when i insert Linux Cinnamon 17.3 USB in to run Linux it,s
very weak. I dont have any acsess to the WIFI reciever, iam in a resthome. Thank,s Chuck
There are a few commands that we can use in Terminal that will give us some basic information. You can copy and past the commands into terminal and copy and past the information back into the post.
Also have you tried removing and re-adding the connection. Sometimes that helps if they made changes to the system
Will tell us the make and model of the WIFI device
Code:
lspci | grep -i wireless
This command will tell us the link and signal quality.
Code:
# iwconfig wlan0 | grep -i --color quality
This will retrieve the driver information
sudo lspci -nn -v -s your socket
Code:
Code:
Rustys i have noway of noing the WIFI name. It,s a good 100 ft away infact thay WIFI pickups in each hall. Theres 3 halls.
I run the codes you give me in the terminal.
!st code says, ( Qualcomm Atheros ) AR 9462 wireless net work adapter ( rev 01 )
2nd code says ( iwconfig wlan0 grep-i--color quality Link quality=55/70 Signal level=55 dBm )
3rd code sudo lspci -nn -v -s your socket lspci -s: invalid slot number.
Thank,s Chuck
Try this to produce the driver information.
Code:
ethtool -i wlan0
You can tell the WIFI name by clicking on the WIFI symbol on the right (near the time) it will be the one on the list with a bullet next to it.
Code:
ethtool -i wlan0
( Visio Cast Display 1393 ) i hope this will help you. Thank,s Chuck
Have you tried turning off then on the WIFI on the system? Which can be done form the same place you located the name of the WIFI. From what I can see you have a good link and connection signal.
Has this affected you speed at all? Have you ran any speed test? What were the results?
Mine will sometimes show a lower signal that my windows system. Other times it will be the other way. There are times that I can be next the transmitter and have low signal.
I use ( WIFI Speed Test Program ) it shows ( ping-16ms ) ( download speed- 41.56mbps )
( upload speed 5.81 mbps )
I can only shut the internet off at the computer, when i reconnect WIFI Speed Test shows
( ping 31ms ) ( download speed-37.36 mbps ) ( upload speed-5.97 mbps )
My Linux never disconnects, its just slow sometimes, not all the time though.
Linux boots up is fine and shuts down is fine, is that ok? And to be expected?
Thanks Chuck
Chuck
Yes this is normal for there to be a difference in signal strengths between Linux and Windows.
The upload and download speed look good as well.
You are welcome
Rustys
Chuck
You are welcome
Rustys
Thank You Rustys for your help. I understand this now Thank,s to you. Thank,s Chuck
