Greetings everybody,
I have had this particular issue for as long as I can remember and I keep coming back to it trying to find a solution, but always to no avail.
This issue is this: I get massively slower internet speeds over WIFI on a particular machine despite numerous efforts to fix it. It is a Windows 10 PC, fully updated with the latest (available at time of writing) Microsoft updates. All network device drivers are updated. The machine runs the prepackaged Microsoft Windows security software but I do have Malwarebytes installed to run "on demand" (so not the paid version). I have run antivirus scans countless times each finding no problems. The PC has limited software applications installed, was built by a company that specializes in custom PC builds but not from a brand-name manufacturer (see specs below).
So, I was forced to revisit the matter again because I have received yet another speed boost from the ISP taking us up to 900 Mbps. All other connected devices - ranging from Apple iPhone(s) and iPad(s) to an XBOX and smart TV's are seeing close to this new speed (with the usual caveats) except for the problem W10 PC that tops out as if deliberately limited at 112 Mbps.
Physical location wise, this PC is situated on a desk, next to another older W10 PC both within direct line-of-sight of the Xfinity gateway at about 15 feet distance - no obstructions. There are no obvious nearby objects that might interfere with the signal and in any case I have previously moved the PC to different locations during troubleshooting and still see the same effect.
It seems to me like I have one of two problems: either there is a restriction at the gateway itself, somehow singling out this machine or there is some internal issue. So what I have done thus far? Over the 18 months I have done the following (or combinations thereof):
**One interesting thing that must be mentioned is that after initial bootup there is a window of about 60 seconds where if I run speed tests I get in the region of 600 Mbs (as with all other devices) and then after the 60 seconds if I run another test I'm back at 112 Mbs. Running an ethernet cable to it is not an option due to human and animal activity in the area.
All other devices including the other W10 machine, Surface Pro and handhelds all consistently see a healthy speed.
Its got so bad I'm about ready to invest in a new PC. On that note here are the specs:
Thanks
- Reinstalled Windows from fresh downloads (twice)
- Uninstalled and reinstalled WIFI device drivers (multiple times)
- Purchased three different WIFI receivers (PCIe, USB).
- Fully disabled antivirus
- Contacted ISP for technical advice, had a tech home visit and a new router/gateway
- Hardwire connected confirming this to be WIFI only issue
- Moved the PC to different locations and orientations relative to the router
- Shut off all other WIFI devices during testing
- Tested using different speed test providers (all exactly the same results)
- Test at different times of the day
- Disabled ALL startup programs (that is all shown available for disabling)
- Run TCP and connection optimizers
- Run Task manager to check for network activity (nothing stands out)
- Contacted the PC manufacturer
- Scoured the internet....
- Reset TCP using cmd prompt per internet instructions
- W10 Home
- Version 10.0.19043 Build 19043
- Intel Core i7 8086K @ 4.0Ghz
- 32 GB RAM
- GPU GTX 1080Ti
- Samsung NVME SSD
- Current WIFI solution is a PCIe installed remote double-antenna located about 3 feet away.
Thanks
