SLI - GTX 1080Ti Aorus Extreme Edition + GTX 1080Ti Aorus (not extreme edition)
reddytesckio
3
32
HI EVERYONE!! :-)
yesterday i tried to connect in SLI, one GTX 1080Ti AORUS EXTREME EDITION with one GTX 1080Ti AORUS (not extreme edition).
In the Nvidia Control Panel, SLI is enabled... But, when i tried to make 3d Mark FIRESTRIKE demo BENCHMARK the Score is the same that with only one Graphic Card... Can you Please know if it is normal... Or how to fix that? Thnx...
Hi here the specs:
Motherboard: Asus Rog Maximus Hero IX
CPU: I7 7700K
16 GB Ram rgb TRIDENT
Power Supply : Corsair TX750M
Hdd 1 tb
SSD 250 gb with Windows 10 home
2x Aorus Gtx 1080ti one Extreme eme Ed, one "standard edition"
SLI : Hb bridge included in the motherboard..
Uf i forget something i can tell you...If helply here the link of Speccy.. http://speccy.piriform.com/results/xJJMTXP8yZpvaTybM1SIAnI
Thank you
Sorry but the only thing that I know about Sli is that a single GPU is sometimes better than two in Sli, other than that all I can see is that a more powerful PSU is required and no less than 1000W.
Thank you guys! I'm trying to understand the problem... If i get a solution i will share it with you! thnx :)
