sky tv go
george0913
60
When i try to connect to this and also Virgin tv go this always comes up , don't know why or how to fix it , on this server.
Reference #18.cc4bdd58.1665928720.48882be
So other can assist lets get some information about the system.
Lets also get a Minitoolbox report and see what the errors are that could also be causing this.
You will need to download to a working system then use an external device to run on the affected system.
Download MiniToolBox and save the file to the Desktop. Right click on the file and select Run as Admin
Close the browser and run the tool, check the following options.
Select all
Click on Go.
copy and paste the contents of the file called MTB.txt or attach the file to your next post.
Are you a Sky TV customer or Virginmedia TV customer?
If Sky then Virginmedia Go will nto work. If VM customer then Sky Go will not work.
