Screen resolution problem
Kane
35
30
Hi all my screen turns off when I leave it for a while for power saving and I left my computer alone for a while and the screen powered down as usual but this time after moving my mouse and the screen came back on the resolution was all messed up and I checked the settings and the resolution hadn't changed and it was still on the recommended setting, I have tried to change the resolution to a different one and then back to my normal one and still no luck I have updated drivers and restarted the PC and the resolution is still messed up, any ideas to why this has happened and how to get my screen back to normal?
I have uploaded a picture so you can all see the problem, looking at the picture I have uploaded you cant really see the problem but the screen is pushed up and cuts off parts of everything you open and there is a big black line at the bottom of the display and everything is a lot bigger then it should be.
Thank you all.
Hi Kane, Welcome to PCHF! :)
Based on that picture it looks like you are using an 800 X 600 resolution for some reason. Try adjusting the size of all display elements back to a lower percentage using this link, How to make text, apps, and other items bigger or smaller in Windows 10. Follow the instructions under the resize everything section and see if there is any improvement.
Thank you for getting back to me and the display is in 1280x1024 because that's the only display the fits my screen okayish at the moment it still chops of the bottom of the taskbar under this resolution and still displays terrible quality :( my PC lately has been running SUPER slow too taking ages to load up anything and it lags all the time.
here is my url for "speccy" http://speccy.piriform.com/results/nGmV1yekiTFbWJJ1oggVwcV.
Thank again.
Hope you don't mind me butting in here but that version of Speccy is soooo old, suggest you update it, hopefully that is the reason its showing your OS as Windows 7, and not 10 as per your picture in your first post?
i didn't actually download speccy I just went on there website and clicked on something and it displayed that to me :s
okay thank you so much for the help here is the url: http://speccy.piriform.com/results/IoIpoY5L3StmGzrj8mETyHt
Also every time I go to shutdown my computer it says "update then shutdown" so when I click that my computer just shuts down it doesn't update and shutdown.
and a while a go the fan in my computer stopped making noise too and doesn't activate anymore at all.
Thank you for all your help with this.
Which fan are you referring to.
Speccy shows that Windows auto-update is not configured.
Only other thing that I am seeing in Speccy is that you have high memory usage, use resource Monitor to see if it highlights anything hogging the memory (I have a feeling it may be the integrated video chip).
Press Windows +R, type Resmon.exe in the Open text box then press Enter > in the Resource Monitor user interface select the Memory tab then check under Processes to identify the biggest users of the memory and get back to us.
Here's a picture showing the processes because I don't really know what I'm looking at with this lol, and as for which fan has stopped working I'm really not sure what one has stopped working I just know I used to hear a constant quite fan in the pc and now I don't hear one at all.
my pc when I go to shut down all ways say's "update and shutdown" and when I click it it just shuts down without updating.
Edge is the culprit, would suggest that you use Chrome as your default browser and unpin Edge from the task bar, cant stand either Edge or Cortana tbh :sick:
If you check your Windows update history you will see the following;
23-Nov-17 Advanced Micro Devices, Inc. - Display - 7/25/2017 12:00:00 AM - 22.19.128.0
Create a new system restore point then go back in to the Windows update history, uninstall the above update, test and then get back to us.
Reactions: gus
I never use tana how would I turn that off and should I uninstall edge then and download chrome?
Did you check for that AMD update.
Click on Cortana and then choose the Hide option.
Edge cannot be uninstalled only disabled, download Chrome and make that your default browser.
Yeah especially when there is no warning or official announcement from Microsoft on this. If I had an update to Windows 10 and all of a sudden my resolution was all messed up, I would think that my video drivers were having issues and not realize that it was a new build of Windows 10 causing the incompatibility. :(
MS really needs to be more thorough when releasing a new build of Windows 10 and state clearly what hardware devices will no longer function so us tech's don't keep spinning our wheels trying to fix an issue when it was MS's fault all along.
Reactions: DOUGIE and gus
iv'e hidden Cortana now and I will download chrome and start using chrome too, how do I fix my resolution problem though I'm still having to currently use 1280x1024.
