I bought a custom built PC for my GF off of Facebook. Everything seemed solid, I did my due diligence and felt confident in buying it. The PC worked fine for about 2 months and then the issue started. The problem is that the display will go blank. Sometimes, black, sometimes light blue, I've gotten even a yellow screen, and sometimes, not often, the display will come back but most times it won't. Sometimes it's 10 minutes of using it, sometimes an hour, and sometimes before I can even log in. If I'm on the BIOS settings, in safe mode, idle on the desktop, or the PC boot options screen, it seems fine but as soon as I do almost anything, it goes blank. The computer doesn't shut off but the display just goes blank. Monitor doesn't turn off either when screen goes blank.
Below are the Specs and tried troubleshooting steps I have taken.
The specs:
The specs:
- MOBO: Gigabye GA-X99-Designare EX
- GPU: Gigabyte RTX 2070
- CPU: Intel Core i7-6850k @ 3.60Hz
- Liquid Cooled
- RAM: 36 GB on DDR4 Corsaire Vengence
- First and foremost I tested HDMI cables to the monitor and the monitor itself.
- Checked to make sure everything in PC was seated properly, GPU, RAM, all cables and that all fans worked.
- Did a reset of PC, reinstalled everything.
- Did a clean install of Windows and wiped all drives.
- Made sure drivers and bios were updated.
- Temperatures all look fine.
