Rtx 3080 mobile clock speed stuck at 210hmz
Koren Gabizon
24
I have an MSI GP66 Leopard with an RTX 3080. My GPU utilization is stuck at 100% while gaming, and my core clock is stuck at 210MHz, memory clock is stuck at 7000MHz, and voltage shows 752W, which is unrealistic. My temperature stays around 51C, and in the Heaven benchmark, I get very low FPS, like 20.It's like the clock speed is locked somehow. When I overclock with MSI Afterburner, the clock speed goes up and I get higher FPS, but otherwise, I don't see anything. Any idea how to fix this without overclocking? I read on the internet that it's a common issue.
