Solved RGB LED lights
Josh12121212
21
Hi guys
Got an odd one.
Turned my PC on yesterday which I’ve had for 2 months bought pre built from Overclockers and randomly, the LED lights around the fans are going mad fast flickering all different colours.
I have a remote to control them and have the software on my pc but using neither of them stop the constant fast flickering of these lights. If i click the blue for example on my remote, the lights will slow down but still continue to change rapidly and all different colours. And then when i let go of the button its goes back to really quick random colours
Almost like it knows i’m telling the lights to change but it can’t. The Aronoury Crate software to change the lights makes no difference at all.
I opened the side of the case checked for loose connections n stuff but can’t find anything and don’t wanna go into it too much as worried about effecting my warranty.
Powrr supply issue maybe? Any ideas would be gr8 thanks
Hello Josh12121212,
RGB is not my thing so not able to really help but being that the computer is only two months old you would be best to open a ticket with Overclockers in case it is hardware related and therefore something that you can risk by trying to fix it yourself.
What you can do without voiding your warranty is uninstall and reinstall any software that controls you RGB lighting, we don`t know anything about your hardware so can`t look for any downloads that you may need.
Reactions: xrobwx71
Being that the OP revisited the forum but chose not to reply this thread will be marked and closed.
