Solved Refresh rate problems
Hrc
4
24
Whenever my refresh rate is above 120hz the bottom of my screen goes black.
Ive installed the latest drivers and nothing changed.
Dont know what to do.
Let's get some more information:
Download and run speccy.
Once you have ran speccy, follow the instructions to upload a snapshot found here.
Please list your power supply unit
Unplug your other monitor and see if that helps, having monitors of varying refresh rates is known to cause issues.
Reactions: phillpower2
My PSU is EVGA 600W W1, 80+
There are a couple of things of note flagged up in Speccy but the most pressing issue is the weak PSU, which is rated as Tier F • Replace immediately here
The OP needs to get themselves a minimum of a 550W Gold efficiency rated PSU from the Corsair RM range, EVGA or Seasonic.
Do you have a "cheap" recommendation?
You have been advised as to what is required, we don`t do cheap only appropriate and you will need to get any prices local to you.
Reactions: Pyro
