Solved Random performance drops possibly due to cooling problems
mcnugget
11
I can run most games on high graphics settings most of the time but once every few minutes my frames will drop into the tens, upon watching the resource monitor and looking at the CPU and GPU temperatures it appears that the FPS drops happen at the points when the CPU is hottest (50-60 c), also all of the cores are active but stuck at 20% ish usage, this lasts about 10 secs and when it is finished the CPU has been cooled down to 30-35 c and the cores go back to being used normally and the FPS goes back up. The higher the graphics settings are the more often the drops happen. I think it is something to do with over heating but don't know what to do about it.
Specs:
Gigabyte GTX 1060 6GB
AMD FX(tm)-8350 Eight-Core Processor
16GB RAM (8GB x2)
c drive: KINGSTON SH103S3120G SATA Disk Device
d drive: ST1000DM 003-ER162 SATA Disk Device
With regards to air flow I have a Bitfenix Neos case and I think the GPU fan sucks air from the space between it and the PSU (the PSU also sucks from this air) and blows it into the CPU fan that then blows it onto the top of the case where it is sucked out of the case by the exhaust fan if that is what you call it.
If anyone has any other ideas about what the problem could be instead of overheating it would greatly appreciated to hear them and if anyone has a solution to the over heating problem it would also be very helpful, thanks :)
Hi mcnugget and welcome to PCHF :)
Let's get some info about your machine shall we?
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
I would also like some screenshots of your temps using Speedfan. :)
Ran by Jake (administrator) on 15-03-2017 at 18:18:27
Running from "C:\Users\Jake\Desktop"
Model: To be filled by O.E.M. Manufacturer: To be filled by O.E.M.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
LogMeIn Hamachi Virtual Ethernet Adapter = Ethernet (Connected)
Realtek PCIe GBE Family Controller = Local Area Connection (Connected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
add route prefix=0.0.0.0/0 interface="Local Area Connection* 10" nexthop=25.0.0.1 publish=Yes
add route prefix=0.0.0.0/0 interface="Hamachi" nexthop=25.0.0.1 publish=Yes
add route prefix=0.0.0.0/0 interface="Ethernet" nexthop=25.0.0.1 publish=Yes
set interface interface="Local Area Connection* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Hamachi" forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 10" forwarding=disabled advertise=disabled metric=9000 siteprefixlength=0 nud=disabled routerdiscovery=disabled managedaddress=disabled otherstateful=disabled weakhostsend=disabled weakhostreceive=disabled ignoredefaultroutes=disabled advertisedrouterlifetime=0 advertisedefaultroute=disabled currenthoplimit=0 forcearpndwolpattern=disabled enabledirectedmacwolpattern=disabled ecncapability=ecndisabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
set subinterface interface= subinterface=ethernet_32769 mtu=1404
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Jake-pc
DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : LogMeIn Hamachi Virtual Ethernet Adapter
Physical Address. . . . . . . . . : 7A-79-19-95-FF-BB
IPv6 Address. . . . . . . . . . . : 2620:9b::1995:ffbb(Preferred)
Link-local IPv6 Address . . . . . : fe80::e519:b004:dc28:575f%16(Preferred)
IPv4 Address. . . . . . . . . . . : 25.149.255.187(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Obtained. . . . . . . . . . : Wednesday, March 15, 2017 6:12:58 PM
Lease Expires . . . . . . . . . . : Thursday, March 15, 2018 6:12:58 PM
Default Gateway . . . . . . . . . : 2620:9b::1900:1
25.0.0.1
DHCP Server . . . . . . . . . . . : 25.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 117592306
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-76-D3-C2-40-16-7E-AF-53-3E
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Connection-specific DNS Suffix . : home
Physical Address. . . . . . . . . : 40-16-7E-AF-53-3E
Link-local IPv6 Address . . . . . : fe80::5463:3c06:73d4:6892%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.82(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, March 15, 2017 6:12:55 PM
Lease Expires . . . . . . . . . . : Thursday, March 16, 2017 6:12:55 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 255858302
DNS Servers . . . . . . . . . . . : 192.168.1.254
Tunnel adapter Reusable ISATAP Interface {7EF89E06-BE6B-47E9-8E6E-A0F17A25F33F}:
Tunnel adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Tunnel adapter isatap.home:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Server: BThomehub.home
Address: 192.168.1.254
Addresses: 2a00:1450:4009:80f::200e
216.58.213.78
Pinging google.com [216.58.212.78] with 32 bytes of data:
Reply from 216.58.212.78: bytes=32 time=17ms TTL=50
Ping statistics for 216.58.212.78:
Minimum = 17ms, Maximum = 17ms, Average = 17ms
Addresses: 2001:4998:58:c02::a9
2001:4998:c:a06::2:4008
2001:4998:44:204::a7
206.190.36.45
98.139.183.24
98.138.253.109
Pinging yahoo.com [98.138.253.109] with 32 bytes of data:
Reply from 98.138.253.109: bytes=32 time=127ms TTL=45
Reply from 98.138.253.109: bytes=32 time=126ms TTL=45
Ping statistics for 98.138.253.109:
Minimum = 126ms, Maximum = 127ms, Average = 126ms
Interface List
16...7a 79 19 95 ff bb ......LogMeIn Hamachi Virtual Ethernet Adapter
14...40 16 7e af 53 3e ......Realtek PCIe GBE Family Controller
8...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
15...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
10...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.82 25
0.0.0.0 0.0.0.0 25.0.0.1 25.149.255.187 9256
25.0.0.0 255.0.0.0 On-link 25.149.255.187 9256
25.149.255.187 255.255.255.255 On-link 25.149.255.187 9256
25.255.255.255 255.255.255.255 On-link 25.149.255.187 9256
192.168.1.0 255.255.255.0 On-link 192.168.1.82 281
192.168.1.82 255.255.255.255 On-link 192.168.1.82 281
192.168.1.255 255.255.255.255 On-link 192.168.1.82 281
224.0.0.0 240.0.0.0 On-link 192.168.1.82 281
224.0.0.0 240.0.0.0 On-link 25.149.255.187 9256
255.255.255.255 255.255.255.255 On-link 192.168.1.82 281
255.255.255.255 255.255.255.255 On-link 25.149.255.187 9256
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 25.0.0.1 Default
IPv6 Route Table
Active Routes:
16 9015 ::/0 2620:9b::1900:1
1 331 ::1/128 On-link
16 271 2620:9b::/96 On-link
16 271 2620:9b::1995:ffbb/128 On-link
14 281 fe80::/64 On-link
16 271 fe80::/64 On-link
14 281 fe80::5463:3c06:73d4:6892/128
On-link
16 271 fe80::e519:b004:dc28:575f/128
On-link
1 331 ff00::/8 On-link
14 281 ff00::/8 On-link
16 271 ff00::/8 On-link
Persistent Routes:
0 4294967295 2620:9b::/96 On-link
0 9000 ::/0 2620:9b::1900:1
Catalog5 01 C:\WINDOWS\SysWoW64\napinsp.dll [55808] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWoW64\NLAapi.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWoW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67584] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
Application errors:
Error: (03/09/2017 10:56:58 PM) (Source: YSearchUtilSvc) (User: )
Description: YSearchUtilSvc error: The operation completed successfully. (0x0)Could not open service (1060)
Error: (03/09/2017 10:52:30 PM) (Source: Application Error) (User: )
Description: Faulting application name: Battle.net.exe, version: 1.7.1.8423, time stamp: 0x58af33ec
Faulting module name: libGLESv2.dll, version: 2.1.0.0, time stamp: 0x56ec7f41
Exception code: 0xc0000409
Fault offset: 0x00289f4f
Faulting process id: 0x1a88
Faulting application start time: 0xBattle.net.exe0
Faulting application path: Battle.net.exe1
Faulting module path: Battle.net.exe2
Report Id: Battle.net.exe3
Faulting package full name: Battle.net.exe4
Faulting package-relative application ID: Battle.net.exe5
Error: (03/09/2017 10:52:08 PM) (Source: Application Error) (User: )
Description: Faulting application name: microsoftedgecp.exe, version: 11.0.14393.82, time stamp: 0x57a55786
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000604
Fault offset: 0x0000000000000000
Faulting process id: 0x648
Faulting application start time: 0xmicrosoftedgecp.exe0
Faulting application path: microsoftedgecp.exe1
Faulting module path: microsoftedgecp.exe2
Report Id: microsoftedgecp.exe3
Faulting package full name: microsoftedgecp.exe4
Faulting package-relative application ID: microsoftedgecp.exe5
Error: (03/09/2017 10:52:06 PM) (Source: Application Error) (User: )
Error: (03/09/2017 10:29:20 PM) (Source: SideBySide) (User: )
Description: Activation context generation failed for "UccApi,processorArchitecture="AMD64",type="win32",version="16.0.0.0"1".Error in manifest or policy file "UccApi,processorArchitecture="AMD64",type="win32",version="16.0.0.0"2" on line UccApi,processorArchitecture="AMD64",type="win32",version="16.0.0.0"3.
Component identity found in manifest does not match the identity of the component requested.
Reference is UccApi,processorArchitecture="AMD64",type="win32",version="16.0.0.0".
Definition is UccApi,processorArchitecture="x86",type="win32",version="16.0.0.0".
Please use sxstrace.exe for detailed diagnosis.
Error: (03/09/2017 10:20:20 PM) (Source: SideBySide) (User: )
Error: (03/09/2017 10:11:06 PM) (Source: SideBySide) (User: )
Error: (03/09/2017 10:02:37 PM) (Source: Application Error) (User: )
Faulting process id: 0x798
Error: (03/09/2017 10:02:35 PM) (Source: Application Error) (User: )
Error: (03/09/2017 09:20:36 AM) (Source: Application Error) (User: )
Description: Faulting application name: ShellExperienceHost.exe, version: 10.0.14393.447, time stamp: 0x5819bf85
Faulting module name: Windows.UI.ActionCenter.dll, version: 10.0.14393.693, time stamp: 0x585a25f7
Exception code: 0xc0000005
Fault offset: 0x00000000000a3750
Faulting process id: 0xe80
Faulting application start time: 0xShellExperienceHost.exe0
Faulting application path: ShellExperienceHost.exe1
Faulting module path: ShellExperienceHost.exe2
Report Id: ShellExperienceHost.exe3
Faulting package full name: ShellExperienceHost.exe4
Faulting package-relative application ID: ShellExperienceHost.exe5
System errors:
Error: (03/15/2017 06:13:00 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}{F72671A9-012C-4725-9D2F-2A4D32D65169}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Error: (03/14/2017 11:16:48 PM) (Source: Microsoft-Windows-Kernel-Power) (User: )
Description: 5
Error: (03/14/2017 06:38:11 PM) (Source: Service Control Manager) (User: )
Description: The Steam Client Service service failed to start due to the following error:
%%1053 = The service did not respond to the start or control request in a timely fashion.
Description: A timeout was reached (30000 milliseconds) while waiting for the Steam Client Service service to connect.
Error: (03/14/2017 06:35:55 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (03/13/2017 11:18:24 PM) (Source: Microsoft-Windows-Kernel-Power) (User: )
Description: 5
Error: (03/13/2017 07:35:49 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (03/13/2017 07:28:50 PM) (Source: Service Control Manager) (User: )
Description: The NetTcpActivator service depends on the NetTcpPortSharing service which failed to start because of the following error:
%%1058 = The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
Error: (03/13/2017 07:28:49 PM) (Source: EventLog) (User: )
Description: The previous system shutdown at 10:48:18 PM on ‎3/‎12/‎2017 was unexpected.
Error: (03/13/2017 07:28:35 PM) (Source: Microsoft-Windows-Kernel-Boot) (User: NT AUTHORITY)
Description: 32212256841088704
Microsoft Office Sessions:
Error: (03/09/2017 10:56:58 PM) (Source: YSearchUtilSvc)(User: )
Error: (03/09/2017 10:52:30 PM) (Source: Application Error)(User: )
Description: Battle.net.exe1.7.1.842358af33eclibGLESv2.dll2.1.0.056ec7f41c000040900289f4f1a8801d299198e5f8ee6D:\Battle.net\Battle.net.8423\Battle.net.exeD:\Battle.net\Battle.net.8423\libGLESv2.dllc580c0c9-b257-4140-88ac-09ca1c6fa82b
Error: (03/09/2017 10:52:08 PM) (Source: Application Error)(User: )
Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0.0.000000000c0000604000000000000000064801d29927c22f3887C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\microsoftedgecp.exeunknown8763938e-3938-4e3c-a555-5904d779caaaMicrosoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbweMicrosoftEdge
Error: (03/09/2017 10:52:06 PM) (Source: Application Error)(User: )
Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0.0.000000000c0000604000000000000000064801d29927c22f3887C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\microsoftedgecp.exeunknown132db0ac-f7ba-4d35-9f0b-24c2bd37d717Microsoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbweMicrosoftEdge
Error: (03/09/2017 10:29:20 PM) (Source: SideBySide)(User: )
Description: UccApi,processorArchitecture="AMD64",type="win32",version="16.0.0.0"UccApi,processorArchitecture="x86",type="win32",version="16.0.0.0"C:\Program Files (x86)\Microsoft Office\root\Office16\lync.exe.ManifestC:\Program Files (x86)\Microsoft Office\root\Office16\UccApi.DLL1
Error: (03/09/2017 10:20:20 PM) (Source: SideBySide)(User: )
Error: (03/09/2017 10:11:06 PM) (Source: SideBySide)(User: )
Error: (03/09/2017 10:02:37 PM) (Source: Application Error)(User: )
Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0.0.000000000c0000604000000000000000079801d29920daffc581C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\microsoftedgecp.exeunknown3e7353b8-e962-4d2f-91c0-338956f02ee3Microsoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbweMicrosoftEdge
Error: (03/09/2017 10:02:35 PM) (Source: Application Error)(User: )
Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0.0.000000000c0000604000000000000000079801d29920daffc581C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\microsoftedgecp.exeunknown9899590a-5e89-4e8a-8336-188a0cb9b0afMicrosoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbweMicrosoftEdge
Error: (03/09/2017 09:20:36 AM) (Source: Application Error)(User: )
Description: ShellExperienceHost.exe10.0.14393.4475819bf85Windows.UI.ActionCenter.dll10.0.14393.693585a25f7c000000500000000000a3750e8001d298b65aca685eC:\WINDOWS\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exeC:\Windows\ShellExperiences\Windows.UI.ActionCenter.dll16d51a41-b528-497d-8eba-15566939c758Microsoft.Windows.ShellExperienceHost_10.0.14393.693_neutral_neutral_cw5n1h2txyewyApp
CodeIntegrity Errors:
Date: 2017-03-09 22:37:51.338
Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume4\Windows\System32\nvspcap64.dll that did not meet the Store signing level requirements.
Date: 2017-03-09 22:37:47.892
Date: 2017-03-09 21:14:52.285
Date: 2017-03-08 20:34:00.760
Date: 2017-03-08 20:33:59.617
Date: 2017-02-17 21:37:12.526
Date: 2017-02-17 21:34:43.950
Date: 2017-02-16 15:19:28.364
Date: 2017-02-15 22:34:23.068
Date: 2017-02-15 22:34:20.952
7 Days to Die (HKLM-x32\...\Steam App 251570) (Version: - The Fun Pimps)
ACA & MEP 2016 Object Enabler (HKLM\...\{5783F2D7-F004-0000-5102-0060B0CE6BBA}) (Version: 7.8.41.0 - Autodesk) Hidden
ACAD Private (HKLM\...\{5783F2D7-F001-0000-3102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
Adobe Flash Player 24 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 24.0.0.221 - Adobe Systems Incorporated)
AMD Catalyst Install Manager (HKLM\...\{5DDB9EF7-1BC0-C9C1-9829-6B9CF68AC357}) (Version: 8.0.903.0 - Advanced Micro Devices, Inc.)
AMD System Monitor (HKLM-x32\...\{6EFD0C42-4CC1-4716-A0CA-21C1A062CF34}) (Version: 1.0.9 - Advanced Micro Devices, Inc.)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 378.78 - NVIDIA Corporation) Hidden
Arma 3 (HKLM-x32\...\Steam App 107410) (Version: - Bohemia Interactive)
Armored Warfare MyCom (HKCU\...\Armored Warfare MyCom) (Version: 1.108 - My.com B.V.)
Asmedia ASM104x USB 3.0 Host Controller Driver (HKLM-x32\...\{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.12.0 - Asmedia Technology)
AutoCAD 2016 - English (HKLM\...\{5783F2D7-F001-0409-2102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
AutoCAD 2016 (HKLM\...\{5783F2D7-F001-0000-0102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
AutoCAD 2016 Language Pack - English (HKLM\...\{5783F2D7-F001-0409-1102-0060B0CE6BBA}) (Version: 20.1.49.0 - Autodesk) Hidden
Autodesk Advanced Material Library Image Library 2016 (HKLM-x32\...\{94AD53E7-493B-4291-8714-7A3B761D2783}) (Version: 6.3.0.15 - Autodesk)
Autodesk App Manager 2016 (HKLM-x32\...\{4ECF9E00-2978-46AF-BD80-455EFEAB7A93}) (Version: 2.0.0 - Autodesk)
Autodesk AutoCAD 2016 - English (HKLM\...\AutoCAD 2016 - English) (Version: 20.1.49.0 - Autodesk)
Autodesk AutoCAD Performance Feedback Tool 1.2.4 (HKLM-x32\...\{4E20873D-BC20-495C-AFD9-B18877B7F9BB}) (Version: 1.2.4.0 - Autodesk)
Autodesk BIM 360 Glue AutoCAD 2016 Add-in 64 bit (HKLM\...\{4BEE127E-95C4-434D-ABAC-65155192BB24}) (Version: 4.35.1742 - Autodesk)
Autodesk Content Service (HKLM\...\{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F}) (Version: 3.2.0.0 - Autodesk) Hidden
Autodesk Content Service (HKLM\...\Autodesk Content Service) (Version: 3.2.0.0 - Autodesk)
Autodesk Content Service Language Pack (HKLM\...\{A37CDB58-AAE8-0001-8C13-E0F7BACB0D5F}) (Version: 3.2.0.0 - Autodesk) Hidden
Autodesk Featured Apps 2016 (HKLM-x32\...\{D42F37CD-9AF9-4435-A474-B387C5BB6B47}) (Version: 2.0.0 - Autodesk)
Autodesk Material Library 2016 (HKLM-x32\...\{29A7D6EC-63C2-42FD-8143-5812ABD2923F}) (Version: 6.3.0.15 - Autodesk)
Autodesk Material Library Base Resolution Image Library 2016 (HKLM-x32\...\{6B4CFC6E-ECB0-47FE-95D3-65C680ED0687}) (Version: 6.3.0.15 - Autodesk)
Autodesk ReCap 2016 (HKLM\...\{F6FD1651-0000-1033-0102-387BAF9B3B0A}) (Version: 1.5.0.33 - Autodesk) Hidden
Autodesk ReCap 2016 (HKLM\...\Autodesk ReCap 2016) (Version: 1.5.0.33 - Autodesk)
Battlefield 4™ (HKLM-x32\...\{ABADE36E-EC37-413B-8179-B432AD3FACE7}) (Version: 1.7.2.45672 - Electronic Arts)
Battlefield™ 1 (HKLM-x32\...\{335B50BC-6130-4BAF-9A6A-F1561270587B}) (Version: 1.0.49.14731 - Electronic Arts)
Besiege (HKLM-x32\...\Steam App 346010) (Version: - Spiderling Studios)
Bethesda.net Launcher (HKLM-x32\...\{3448917E-E4FE-4E30-9502-9FD52EABB6F5}_is1) (Version: 1.0 - Bethesda Softworks)
Blender (HKLM-x32\...\{472ADEE9-937F-4796-B50B-273CEABFCED3}) (Version: 2.75.1 - Blender Foundation)
BoltonsEveningWithV1 (HKLM-x32\...\{EBFF5494-9626-4D12-9E06-70F335A90C6A}) (Version: 1.0.0 - Default Company Name)
Borderlands 2 (HKLM\...\Steam App 49520) (Version: - Gearbox Software)
Cities: Skylines (HKLM-x32\...\Steam App 255710) (Version: - Colossal Order Ltd.)
ClipGrab 3.6.2 (HKLM-x32\...\{8A1033B0-EF33-4FB5-97A1-C47A7DCDD7E6}_is1) (Version: - Philipp Schmieder Medien)
Counter-Strike: Global Offensive (HKLM-x32\...\Steam App 730) (Version: - Valve)
Creation Kit: Fallout 4 (HKLM-x32\...\Creation Kit: Fallout 4) (Version: - Bethesda Softworks)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
DayZ (HKLM\...\Steam App 221100) (Version: - Bohemia Interactive)
Discord (HKCU\...\Discord) (Version: 0.0.297 - Hammer & Chisel, Inc.)
Don't Starve (HKLM-x32\...\Steam App 219740) (Version: - Klei Entertainment)
Don't Starve Together Beta (HKLM-x32\...\Steam App 322330) (Version: - Klei Entertainment)
DOOM (HKLM\...\Steam App 379720) (Version: - id Software)
Dropbox (HKLM-x32\...\Dropbox) (Version: 21.4.25 - Dropbox, Inc.)
Dropbox Update Helper (HKLM-x32\...\{099218A5-A723-43DC-8DB5-6173656A1E94}) (Version: 1.3.59.1 - Dropbox, Inc.) Hidden
Fallout 4 (HKLM-x32\...\Steam App 377160) (Version: - Bethesda Game Studios)
FARO LS 1.1.502.0 (64bit) (HKLM-x32\...\{66D83FE0-D798-4B38-86FE-FB48151E5AEF}) (Version: 5.2.0.35213 - FARO Scanner Production)
Garry's Mod (HKLM-x32\...\Steam App 4000) (Version: - Facepunch Studios)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 56.0.2924.87 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.32.7 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
Hi-Rez Studios Authenticate and Update Service (HKLM-x32\...\{3C87E0FF-BC0A-4F5E-951B-68DC3F8DF1FC}) (Version: 3.0.0.0 - Hi-Rez Studios)
Java 8 Update 121 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
Kerbal Space Program (HKLM-x32\...\Steam App 220200) (Version: - Squad)
League of Legends (HKLM-x32\...\{B2777235-FDF0-4371-9D1E-0CD24DFE3579}) (Version: 4.2.1 - Riot Games) Hidden
League of Legends (HKLM-x32\...\League of Legends 4.2.1) (Version: 4.2.1 - Riot Games)
LogMeIn Hamachi (HKLM-x32\...\{91B5DF26-717A-4A5F-AB10-CD450FAD428C}) (Version: 2.2.0.541 - LogMeIn, Inc.) Hidden
LogMeIn Hamachi (HKLM-x32\...\LogMeIn Hamachi) (Version: 2.2.0.541 - LogMeIn, Inc.)
Mafia III (HKLM\...\Steam App 360430) (Version: - Hangar 13)
McAfee LiveSafe (HKLM-x32\...\MSC) (Version: - )
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Chart Controls for Microsoft .NET Framework 3.5 (HKLM-x32\...\{41785C66-90F2-40CE-8CB5-1C94BFC97280}) (Version: 3.5.30730.0 - Microsoft Corporation)
Microsoft Expression Encoder 4 (HKLM-x32\...\Encoder_4.0.1651.0) (Version: 4.0.1651.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32\...\{01db25f3-1b76-4d97-88c8-1c90634d88fb}) (Version: 11.0.60610.1 - Корпорация Майкрософт)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32\...\{95716cce-fc71-413f-8ad5-56c2892d4b3a}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32\...\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32\...\{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 4.0 (HKLM-x32\...\{2BFC7AA0-544C-4E3A-8796-67F3BE655BE9}) (Version: 4.0.20823.0 - Microsoft Corporation)
Monaco (HKLM-x32\...\Steam App 113020) (Version: - Pocketwatch Games)
Movie Maker (HKLM-x32\...\{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{EB3DF0F0-0525-4C5A-A2F8-DEC868A3075D}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
MPC-HC 1.7.9 (64-bit) (HKLM\...\{2ACBF1FA-F5C3-4B19-A774-B22A31F231B9}_is1) (Version: 1.7.9 - MPC-HC Team)
My.com Game Center (HKCU\...\MyComGames) (Version: 3.187 - My.com B.V.)
NVIDIA 3D Vision Controller Driver 369.04 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 378.78 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 378.78 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.4.0.70 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.4.0.70 - NVIDIA Corporation)
NVIDIA Graphics Driver 378.78 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.78 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.23 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.23 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.4.0.70 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.3.16.0 - NVIDIA Corporation) Hidden
NvvHci (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
Origin (HKLM-x32\...\Origin) (Version: 10.4.5.25153 - Electronic Arts, Inc.)
Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment)
Poly Bridge (HKLM-x32\...\Steam App 367450) (Version: - Dry Cactus)
PunkBuster Services (HKLM-x32\...\PunkBusterSvc) (Version: 0.993 - Even Balance, Inc.)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.67.1226.2012 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7535 - Realtek Semiconductor Corp.)
Rising Storm/Red Orchestra 2 Multiplayer (HKLM-x32\...\Steam App 35450) (Version: - Tripwire Interactive)
ShellShock Live (HKLM\...\Steam App 326460) (Version: - kChamp Games)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0351 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.4.0.70 - NVIDIA Corporation) Hidden
SimplePlanes (HKLM-x32\...\Steam App 397340) (Version: - Jundroo, LLC)
Skype Click to Call (HKLM-x32\...\{873F8E7C-10E6-449F-BD7E-5FBA7C8E1C9B}) (Version: 8.5.0.9167 - Microsoft Corporation)
Skype™ 7.32 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.32.104 - Skype Technologies S.A.)
Space Engineers (HKLM-x32\...\Steam App 244850) (Version: - )
Steam (HKLM-x32\...\Steam) (Version: - Valve Corporation)
SteelSeries Engine 3.8.5 (HKLM\...\SteelSeries Engine 3) (Version: 3.8.5 - SteelSeries ApS)
Team Fortress 2 (HKLM-x32\...\Steam App 440) (Version: - Valve)
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.0.16 - TeamSpeak Systems GmbH)
Terraria (HKLM-x32\...\Steam App 105600) (Version: - Re-Logic)
The Binding of Isaac (HKLM-x32\...\Steam App 113200) (Version: - Edmund McMillen and Florian Himsl)
The Binding of Isaac: Rebirth (HKLM-x32\...\Steam App 250900) (Version: - Nicalis, Inc.)
Tom Clancy's Rainbow Six Siege (HKLM-x32\...\Steam App 359550) (Version: - Ubisoft Montreal)
Undertale (HKLM-x32\...\Steam App 391540) (Version: - tobyfox)
Unity (HKLM-x32\...\Unity) (Version: - Unity Technologies ApS)
Unity Web Player (HKCU\...\UnityWebPlayer) (Version: - Unity Technologies ApS)
Uplay (HKLM-x32\...\Uplay) (Version: 13.0 - Ubisoft)
Vulkan Run Time Libraries 1.0.39.1 (HKLM\...\VulkanRT1.0.39.1) (Version: 1.0.39.1 - LunarG, Inc.)
War Thunder (HKLM-x32\...\Steam App 236390) (Version: - Gaijin Entertainment)
War Thunder Launcher 1.0.1.340 (HKLM-x32\...\{abc8eea4-29fa-3932-9612-e2122d8a62d9}}_is1) (Version: - Gaijin Entertainment)
Windows 10 Upgrade Assistant (HKLM-x32\...\{D5C69738-B486-402E-85AC-2456D98A64E4}) (Version: 1.4.9200.17354 - Microsoft Corporation)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
WinPcap 4.1.3 (HKLM-x32\...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
WinRAR 5.31 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.31.0 - win.rar GmbH)
XTREME GAMING ENGINE (HKLM-x32\...\GIGABYTE XTREME GAMING ENGINE_is1) (Version: 1.0.5.3 - GIGABYTE Technology Co.,Inc.)
Percentage of memory in use: 22%
Total physical RAM: 16298.84 MB
Available physical RAM: 12599.15 MB
Total Virtual: 32682.84 MB
Available Virtual: 28565.37 MB
1 Drive c: () (Fixed) (Total:110.83 GB) (Free:34.04 GB) NTFS
2 Drive d: () (Fixed) (Total:931.51 GB) (Free:317.39 GB) NTFS
User accounts for \\JAKE-PC
Jake
**** End of log ****
Screen shot was taken whilst only discord was open in case that effects anything, do you want another screen shot whilst under stress?
This was whilst playing a game of over watch on medium
Hope you don`t mind the interjection folks :)
Do you have a link to your specific case type, there are various models of the Bitfenix Neos case some of which have a better cooling system supplied as standard.
When you post back can you let us know the brand and model name or number of your PSU.
An observation from your second Speedfan screenshot, fan 2 is running marginally slower when the computer is under load when ideally it should be running faster as fan 1 is shown to be.
Download then run HWMonitor and post a screenshot so that we have a comparison to the Speedfan results, details from here we will hopefully get some voltage readings.
Thanks for the additional info (y)
Your case specs here show that there may not be a front cooling fan, if yes, I would suggest that you fit an appropriate 120mm cooling fan to draw in cool, clean air and while fitting it the removable front and PSU dust filters should be removed and cleaned.
PSU is a decent brand and spec and has an adequate output for your hardware.
Most of the HWMonitor readings are fine but there is high CPU usage for a computer not under load and the voltage to the memory slots possibly marginally high, can you tell us the brand, spec and number of memory modules you have so we can check what the voltage should be, get back to us with this info first please, I don`t want to overload you with things to do.
Thanks, that explains the high CPU usage.
Still a couple of marginally high voltages for the RAM and CPU, are you or have you overclocked anything, do you know how to restore the MBs default factory settings in the BIOS.
Check the AMD FX-8350 specifications here then compare them with both sets of your screenshots and you will see the slight difference, likewise check the HWMonitor VIN readings and you will see that they exceed the max of 1.65V of your RAM, the readings may not look like much but the additional voltage will increase the heat which needs to be expelled from inside the case asap, the pull/push method of drawing cool, clean air in at the front and having an exhaust fan at the rear works best, any top or side fans are an added bonus when you have front and rear chassis fans.
I chose the parts for this PC on Overclockers and then they built it and sent it too me, I remember there being an option to have it over clocked but I am not sure if I decided to do it or not, and I don't know how to restore the MBs factory settings in the BIOS
Easiest way is in the BIOS menu, see example guide here
Please note that if you have two options as in load fail safe or optimal settings you should choose the load fail safe option, this is also sometimes listed as most stable or factory default settings, in this instance the optimal settings should not be selected as it is a form of overclocking and can lead to instability.
I am having trouble finding the option to reset to factory defaults, there are plenty of options to set to optimised settings but none that i can see to reset to factory defaults, the closest I have found is reset to previous settings (or something along those lines)
Your MB may only have the optimised settings option and if so it = the same as the factory default settings and can be safely selected.
I have set to optimised settings, do you want screen shots of CPUID whilst under load and idle again?
Check them for yourself by all means but see how the computer behaves first, don`t believe in making work for people unless necessary.
Have you looked into the front cooling fan yet.
Also I cleaned the front intake filter and it was not pretty, I plan on getting some fans for the front in order to improve air flow and I am also going to clean my CPU heat sink since it has so much dust on it that most of the air is blowing out the sides instead of through it.
Dude, this has completely fixed the problem :), thank you so much
That is good news and thank you for letting us know (y)
Sounds like a plan:thumbsup: the pull/push method of cooling allows the cool, clean air to be drawn in across the hardware and exhausted out of the back of the chassis taking a lot of the dust etc with it.
You are welcome btw and thanks again for the follow up :)
Reactions: veeg
