Random PC Freezing Issues
airkon
5
42
I'm having this very random PC freezing issue for the past 6 months and never managed to diagnose the main issue.
It happens from once every few days to sometimes 3-4 times a day. And when it happens, usually I can move my mouse a bit but nothing on the screen reacts and a min later, everything is just frozen. No BSOD, everything looks healthy from the monitor (fans, memory, temperature).
The most common error I see inside the reliability monitor is some LiveKernelEvent 144 but I have tried a couple of fixes (from Googling) but nothing works. So far, online searches have mentioned anything from issues from the graphics card to SSD to windows 10.
Can I get some help on this?
Not sure why speccy doesn't attach but here are my specs
AMD Ryzen 5 5600X 6-Core Processor
ASUSTeK COMPUTER INC. TUF GAMING B550-PLUS (AM4)
4095MB NVIDIA GeForce RTX 3070 (ASUStek Computer Inc)
953GB SAMSUNG MZVLB1T0HBLR-00000 (Unknown (SSD))
1863GB TOSHIBA HDWD120 (SATA )
16GB Ram Corsair RGB Pro 3600
Windows 10 64 Bit
Not sure how you missed providing the above.
RAM
32.0GB Dual-Channel Unknown @ 1799MHz
Your RAM is being clocked past what the CPU can handle which is as stated by AMD here is 3200MHz
You need to go into the BIOS, disable XMP, manually set the RAM speed to 3200MHz, save the new settings, exit the BIOS, restart the PC and test by using the computer as you normally would.
PSU: NZXT C750 80+ Gold Certified PSU 750W
Still crashes after I updated the bios to limit to DDR-3200.
Decent enough PSU but you may want to make sure that none of the modular cables have come loose.
Can we have a new Speccy url + a MTB log.
List Installed Programs
List Devices (Only Problems)
Click on Go.
Being that the OP has re visited the forum but chose not to reply this thread will now be closed.
